Question about Kenmore Dryers
Sears Gas Dryer - All lights lit, won't run
I am helping my mother with a problem on her dryer. She was out of town this past weekend. She returned and found her Sears Gas Dryer had all the indicator lights lit and is non responsive. I told her to unplug it for a day and see if it clears itself. It did not. Is there something that could reset the machine, or something we can do that would point to what is wrong? The model is 110.70092990 . Thanks for your help.
  • 4 Answers
SOURCE: Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
Posted on Jan 10, 2008
  • 61 Answers
SOURCE: dryer makes squeaking noise ,then dryer shuts off. mdl.#CYG4000AWW
Hello, sounds like the rear drum rollers are in need of replacement which is causing the motor to get hot and cut out on the thermal cut out. It can be tricky to service if you not handy. Good Luck
Posted on Dec 26, 2008
  • 6 Answers
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Posted on Dec 28, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore Dryer model #66912690 The dryer stops
replace motor drive,,,defective motor...onthejob
Posted on Feb 09, 2009
SOURCE: Kenmore Oasis dryer F40 error code
I had this same issue. My dryer would run and heat up but then stop and give me the f40. I measured all thermisters and everything was in range. The tech sheet stated that I needed to buy a new control board and I did. Same problem.
The solution was a loose connection on for p4. I took needle nose pliers and squeezed the connector to make it fit tight on the board and everything is working now.
Bottom line, expensive dryer with cheap connectors.
Posted on Apr 21, 2009
The igniter heats and the flame lights, but it shuts off after just a minute or two. It won't go back on until the dryer has cooled down completely. Could it be the high-limit thermostat? With the...
What your describing sounds pretty much like the sympthons of weak coils that open the gas valve. It is a fairly common thing that happens with gas dryers so i have written a tip that explains in detail what happens when gas valve coils are weak.
http://www1.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
I hope i have helped you to fix your dryer,
GENE
Oct 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer won't run, control panel lit, start/pause light flashing green, none of the buttons work. Checked door switch & both thermal fuses, all okay. Was thinking it was control panel, purchased and...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 13, 2011 | Maytag Neptune MDG5500AW Gas Dryer
My dryer ran fine with my last load of only 3 towels. I haven't had any problems with my dryer before. I went to "wrinkle release" my towels and nothing happened. No lights, no 18min. showed...
heatman101
Aug 03, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Gas burner won't stay lit
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 10, 2010 | Dryers
Amana ALG443RAW Gas Control
On a gas dryer gas is flowing "TO" the gas valve all the time.
It does not flow "PAST" the gas valve unless the gas valve opens and the burner is lit. This is based on other components working correctly.
If other components fail the gas does not flow past it.
Nov 30, 2009 | Amana ALG443RAW Gas Dryer
Dryer runs fine but does not heat
Check that the pilot light is lit and flame kicks on when dryer is activated. If no flame, then check gas valve. If only pilot remains lit but does not increase when dryer is activated, then you could have a bad coupler or sensor or circuit problem which would have to be tested with a voltmeter and/or test light.
Nov 15, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My gas dryer comes on and is blowing air just not hot air. It is a very old kenmore stack set with gas dryer model 417. I think, do you know what this could be?
sounds like the thermacouple has gone bad. when it goes out pilot light will not stay lit. if there is a handyman around, it shouldn't be a problem to replace
bama46 please rate have a great weekend
Aug 22, 2009 | Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Apr 01, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Oct 08, 2007 | Dryers
Dryers Logo
49 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
