Question about Whirlpool Washing Machines
Cannot get the back off on my whirlpool LSL9244EQO washer to see where the leake is
    Sniper:
  • 88 Answers
The back panel does not come off, the cabinet comes off the base. Open and flip the control panel up, pop out the two gold clips, unhook the lid switch harness, and tip the cabinet toward yourself and pull off the base. Boo ya. The leak is goin' down.
Posted on Sep 17, 2008
My whirlpool washer model LSL9244EQO will not turn on
first lets check power at wall is it good?
then i would check the lid switch they are a common problem and if bad will not allow unit to start... if you are not hearing anything at all and you have power then it is going to be most likely either the lid switch or the timer itself.the lidswitch can be jumped out and tested or if you have a meter it should be a closed circuit when shut and open when lid up/...good luck to you
Dec 03, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirlpool washer leaks water
If your TOP LOADING Whirlpool manufactured washer is leaking, the following link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
If the leak is more like a constant drip, a common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
Jul 31, 2010 | Whirlpool LSR7333 Top Load Washer
During the wash cycle of the 24" combo washer dryer, it leaked
A hose inside the washer is your most likely culprit. On older whirlpool washers they used a plastic hose to run from the pump to the back case of the machine that was pretty susceptible to cracking.
Jun 28, 2010 | Whirlpool LTE6234D Top Load Stacked...
Brand new Whirlpool Oasis leaking all over floor
Take the back off & make sure the out let hose is still on your pump.
Dec 06, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Washer Model LSL9244EQO
shut off water remove rear hoses pull screen from inside opening and clean ..BE SURE TO REINSTALL SCREENS..if still slow or stopped altogether replace fill valve..remove rear screws in console lift and roll console back unplug lid switch pop the clips on each corner up and off cabinet will lift off valve is top right side
Aug 06, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaking from my whirlpool frontload washer
open the door and check between the drum and door frame. There is a large rubber bladder completely surrounding the drum. Pushing the drum further back into the machine will let you see the entire thing and unfold it. These often get small laundry like socks stuck there as well as sharp objects like nails. You may have a tear in it which will leak like that. Replacement parts run about $70.00.
May 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer leaking from bottom back..
sounds like you need to check your back drain could be the drain is clogged.Fill with water and see if it comes from the drain
Nov 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
65 people viewed this question
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
