Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Generator will not generate electricity.
I purchased this gernerator following Hurricane Katrina. We lost electrical power while Hurricane Gustav was visiting us and the Generator worked for a day and a half before it stopped generating electricity. It seemed to be losing generating power over that time period. Where and how do I begin to trouble shoot the problem?
    Problem Solver:
  • 18 Answers
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clean the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Posted on Sep 19, 2008
Hi i purchase the generator before Maria hurricane, after few days used, i note the oil leak, came out at the bottom. Why happens this if the generator is band new.
you dont say who made this genset but at a few days old it is under a warranty so take it back or to a repair shop.
Oct 06, 2017 | Electrical Supplies
Hurricane names
Mitch (1998), Katrina (2005), Wilma (2005), Ike (2008), Gustav (2008), Irene (2011), Jova (2011), Matthew (2016), Hermine (2016), Otto (2016), Irma (2017)
Sep 13, 2017 | Miscellaneous
How long will it run on a full tank of gas????
Hello. W/D here.
You've posed a fine question, as it has several answers. We used one of these during Hurricane Katrina.
1. At idle, you can expect about 6 hours.
2. Fully loaded, you can expect to refuel it at about 4 hours without the tank being empty.
Your actual time will vary with the demand placed on the generator, but these times are best as I recall.
Hope that this was of some small help, --W/D--
Jan 27, 2011 | Coleman Powermate Premium Plus 6250W...
I own a 5700 watt McCulloch generator. Bought for Hurricane Katrina. Ran perfect , changed oil & used fresh gas regularly. Crank every couple months to keep gaskets from dry rot. When I cranked it...
Most likely the protective circuit breaker has tripped. It doesn't look like the circuit breakers in your house wiring panel -- it is often just a small button that you must press to reset. It can trip easily from a surge when you first plug in an appliance (especially one with a motor), but if it keeps tripping with nothing plugged in, then you have a short in the generator wiring. Good luck!
Aug 17, 2010 | Garden
Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Sep 18, 2008 | Electrical Supplies
Not a 6250W but a 6500W Coleman Powermate Black Max.
Call Pramac Co. at 770-218-5430. I get parts from them every week. A service center left holding the bag when Coleman/Powermate went out. Ken's Repair
Sep 15, 2008 | Coleman Powermate Premium Plus 6250W...
Need operating manual for 6250
Their should be a twist value on the bottom of the gas tank.( were the fuel hose attaches.
Sep 13, 2008 | Coleman Powermate Premium Plus 6250W...
Supressor, transient
Hello hward,
You said, Hello from Baton Rouge, La. just recently nailed by Hurricane Gustav.......
during the hype of the storm, I think my wife's double oven took a electric surge and started smoking. I visually inspected the damage and saw a badly burnt and scarred flat saucer looking component (suppressor, transient)...I have ordered a replacement part and would like to know if you think that replacing this item will be all I will need to do..
If the range was under water I do not think this will be the only problem.
I believe it will cause you endless problems if it got submerged!
you may end up replacing this water logged unit!
Thank You ,Please remember to leave a rating
Sep 07, 2008 | Whirlpool RBD305PD Electric Double Oven
The power is out because of Hurricane Gustav. I have a 6500 watt portable generator and would like to use our clothes dryer which has a 220 volt requirement. Is that possible, and is there a special...
Dryers require a 40A circuit breaker to handle the current. According to Ohms Law: Watts = Volts * Amps. Therefore, you require a power capacity of 220V * 40A in order to safely run the dryer, which is 8800 Watts. This means your generator does not have enough capacity to run the dryer. If we consider the full power of your generator at 6500 Watts, this only allows for 29.5A, which is not enough to run your dryer.
If it WAS possible, you would need to ensure that you ran a 30A heavy extension cord with the correct 220V plugs and receptacles on the end. This would require at least 10gauge 3-conductor wire, which is quite expensive.
However, that point is moot, since your generator does not have the capacity to run your dryer. You could try it, but I rather suspect that the dryer will trip the 30A breaker on the genset circuit. If you do try it, make sure you run a 10-gauge, 30A extension cord or you could have a fire.
Sep 06, 2008 | Dryers
McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
1,540 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
