Question about Sony KP-51HW40 51" Rear Projection Television
KP-51HW40 Convergence Problem
Multiple images of red, green and blue and bowed in the center from top to bottom. Do I need convergence ICs and resistors? If so, can I do it or do I need to pull the board and have you do it?
  • nothomeyet Sep 27, 2008
    I received the parts but need instructions. I thought they would come with the parts. Do you have any?
  • ravgman Oct 12, 2008
    I have the same symptoms: Multiple images of red, green and blue and bowed in the center from top to bottom. The bowing gets smaller as the unit warms up.
    I have purchased the recommended parts or the manual yet. Usually, I purchase the manual first, troubleshoot, then get the parts to fix. Is this issue so cut and dry that replacing the two convergence ICs and the pico fuses is the only solution to this problem?
  • Sony Master
  • 8,617 Answers
Actually your model should only need two STK392-560 Convergence ICs and six 3.5 amp pico fuses. You can get the replacement ICs and pico fuses at the following link with free installation instructions. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Sep 18, 2008
  • Sonny Berry
    Sonny Berry Sep 28, 2008
    send them a email and they will email them to you right away
Aproximately 50% of the Tv's image is distorted by a green and red doubled image. Can we fix this
Yes, this problem can be fixed if you are handy with electronics stuff repair and can solder parts in circuit board easily with proper tools.
Replace convergence out ICs to get converge picture.
Let me know exact model number and brand of your TV for further info as question shows its Sony KP-51HW40 tv.
Jan 08, 2010 | Sony KP-51HW40 51" Rear Projection...
I have Sony KP-46WT500 Projection TV. For some time it appears convergence went bad. I see multiple images, especially at edges and corners. As many as 3 images Red, Blue and Green. I am an Electronics...
It would be great to assist you in Sony convergence issue.
As you said, for some time TV shows bad convergence in picture that shows its matter of lose/ dry solder joints in D board, specially on convergence out ICs pins that need to be re-solder.
There are 2 big black ICs mounted on aluminum heat sink on D Board of TV, below image shows D Board location in TV.
Resolder pins of these 2 ICs and also check any other dry/ cold solder joints in circuit board. I do not think of IC replacement as problem occurs some time.
Let me know if you have additional question.
Thanks.
Dec 20, 2009 | Sony KP-46WT500 46" Rear Projection...
Double Image Red and Green
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Feb 08, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Text/images overlap each other in 3 colors, 3D distorted picture
  • Screen looks 3D
2c07611.pngSolution
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
How do i center the colors, red, blue and green?
Replace Both of your convergence ICs STKs, big black ICs.
STK392-560, also CK pico fuses around ics you may have 1or2 bad .
HAPPY NEW YEAR!
Jan 01, 2009 | Sony KP-61HS10 61" Rear Projection...
Sony KP-511HW40 - blue/green tint issue - convergence issue?
Replace your convergence ICs STKs big black ics Go by number on them STK392-560 ect..... Parts you can order on line www.electronix.com or Call 1-800-223-3205 you will also need silicon heat sink compound to put on New ICs replace Both STKs
Dec 25, 2008 | Sony KP-51HW40 51" Rear Projection...
Convergence issue with blue
You need to replace the convergence Ics located up front behind the speaker grille numbers STK392-110 you can get replacements at the following link and they provide free tech support and instalation instructions with pictures. heres the link.
May 06, 2008 | JVC AV-56WP74 56" Rear Projection...
Distorted image and color
sounds like the convergence ICs have failed. Will the red and blue move in all 4 directions when you try to adjust the convergence? If not the convergence ICs are bad replace both of them also check the resistors that power the ICs as they may be open as well.
Mar 12, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Mitsubishi Vs-6047 Convergence Problem...Please Help!
usally convergence green is split between 2 ics. so if your blue and red are still good. it might be the green output resistors. The
Jan 08, 2008 | Mitsubishi VS-6047 60" Rear Projection...
Sony KP-57WS510 Convergence issue?
Replace convergence IC's....STK392-560 X 2 + check pico
fuses under IC heatsinks.....................T.
Nov 12, 2007 | Sony KP-57WS510 57" Rear Projection HDTV
Sony KP-51HW40 51" Rear Projection Television Logo
132 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
