Question about Lexmark X83 All-In-One InkJet Printer
Problem after installing cartridges
I activated the maint. menu and the printer heads centered as always to remove the old cartridge. I may have moved the carriage a little, now the carriage is on the far right and the machine clicks for several seconds and the three leds stay lit and the screen is blank.
I gently moved the cardtridge assy. to the left, then I gently strummed the belts that probably centered the sensors. you have to be careful and not do it too hard strum gently like guitar strings .hope this helps
Posted on Sep 24, 2008
What do I need to do when I install new ink cartridges to get the printer to stop showing that the ink is low or out ?
You will need to reset the software in most cases as the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken .
Jul 21, 2011 | Canon PIXMA MP470 All-in-One Printer
How do I install the ink cartridge
You will find two buttons on your printer.
One for power and the another is a function button.
Push them together at the same time while the printer is on.
In most cases this will move the ink head to the center on the machine in order for you to remove the old ink cartridges and install the new ones. However a different button may need to be used consult the manual in this regard.
The ink cartridges are clipped in, you will need to undo the clip!
Then pull the ink cartridge out, usually upward force applies.
Now once the old cartridges are removed you can install the new cartridges.
Be sure to remove any stickers that are meant to be removed, read the sticker and if it says "remove before use" then remove it.
Insert the cartridge and push them down, then the clip is to be clipped in.
Now to get the ink head to move back to it's lair first try pushing the function button.
If nothing happens then push both buttons together again.
Please read this session a number of times to get the jist of what needs to be done.
Also I would like to ask you to please rate this session with the use of the Thumbs on the right.
Thanking you very much.
Till next time!
damnor01
Mar 20, 2011 | Canon Pixma iP2600 Photo InkJet Printer
How do you change the ink cartridge for Epson TX210 printer?
manual available here with details .
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply and remember, even if you don't vote for me a please and thank you goes a long way
Mar 07, 2011 | Epson Office Equipment & Supplies
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
I have changed a black ink cartridge, bur my yellow and blue ink cartridges are too low to charge/clean so the black ink is not coming through. A little message comes up telling me that the blue and yellow...
Hi Good day!!! try this trick ^_^ open the cover of your printer to see the print head, now turn off your printer you will see your print head is moving when it moves to the center pull out the power cord of your printer ( this trick is about good timing) if success the print head is now in the center now remove the ink cartridge (note don't installed the new cartridge yet) now turn back on you printer without the cartridges, your printer will recognize that the cartridges are missing, ^_^ and finally your printer will find the your inks after that insert it according to its location.
Dec 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Problem installing an ink catridge
Most HP printers will move the print heads to the center of the printer when you open the front.
Each cartridge has a flip that you can flip up. The cartridge can then be removed by tilting it toward you. You can install a new cartridge by removing it from the box and foil liner. You then remove a strip that protects the head. Like you took out the old cartridge, tilt the cartridge and straighten it up. Flip the flip down. Close the top. You should be ready to go after the heads clean themselves and do an alignment.
If the printing is not satisfactory, you can go to your programs and hp will have a tool to perform alignment.
You can use HP cartridges, refilled cartridges or fill cartridges yourself (depends).
I've filled cartridges with success. However, it can be a bit messy.
Jun 07, 2010 | HP Printer Cartridges (Complete List): ,...
Mp140 display shows E 5 , book says push maint button but doing this does not move the display from E5 What can I do
E, 5
The FINE Cartridge cannot be recognized.
Possible causes are as follows:
bullet_s.gif The FINE Cartridge may not be installed properly.
bullet_s.gif The FINE Cartridge may not be compatible with this machine.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Nov 03, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How can i remove the ribbon cartridge of EPSON LX-300+ii?
open the top cover and pull up the cartridge if ribbon stock near head pull properly...........
Oct 09, 2009 | Epson Dot Matrix LX-300+ II Printer
Hi, please tell me how to install a new black ink cartridge into my epsonstylus D78 printer
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Epson stylus cx4400 printer
This for the CX5400 which is similar with its menu system:
Using the Control Panel Follow the steps below to replace an ink cartridge.
r_1.gif Make sure this product is on and the On light is not flashing.
When the ink is low:
Press one of the Menu buttons until Change Cartridge appears on the LCD panel, and then press the fontx1.gif Color Copy button. The ink cartridges move to the replacement position. r_3.gif Make sure that the document cover is closed, and then raise the scanner unit.
a8101037.gif r_space.gif r_caut.gif Caution: r_space.gif r_space.gif
  • Do not raise the scanner unit with the document cover opened.
  • Do not move the print head by hand. Doing so may damage this product.
  • Do not start replacing the ink cartridge before the print head stops.
r_4.gif For best results, shake a new ink cartridge four or five times, then remove it from its the package.
a8102006.gif r_5.gif Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of this product and dispose of it properly. Do not take the used cartridge apart or try to refill it.
a8101049.gif r_space.gif r_warn.gif Warning: r_space.gif r_space.gif Be careful when you are handling used ink cartridges, as there may be some ink around the ink supply port. If ink gets on your skin, wash the area thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. If discomfort or vision problems remain after thorough flushing, see a doctor immediately.
r_space.gif r_caut.gif Caution: r_space.gif r_space.gif Be sure to always install an ink cartridge into this product immediately following the removal of an old ink cartridge. If the ink cartridge is not installed promptly, the print head may dry out rendering it unable to print.
r_6.gif Place the ink cartridge vertically into the cartridge holder. Push the ink cartridge down until it clicks into place.
a8101051.gif If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7. r_7.gif Lower the scanner unit.
a8101039.gif The print head moves and ink charging begins. The On light flashes while ink charging is in progress. When the On light stops flashing, ink charging is completed.
Jun 14, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Lexmark X83 All-In-One InkJet Printer Logo
29 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
