Kenmore Elite Stainless Steel 24" BuiltIn Dishwasher with TurboZone Rotating Spray Jets 13103 Logo
A
Anonymous Posted on Sep 22, 2011
The water seems to not be hitting the top row of dishes and the dishwasher has gotten louder, end result not cleaning the dishes
Sam
Level 3:
  • Kenmore Master 3,247 Answers
  • Posted on Sep 22, 2011
Sam
Kenmore Master
Level 3:
Answers
3247
Questions
0
Helped
1305034
Points
10378
Best to chck the water pump which could be partially blocked and not sending water to the top spray feed.
It would be helpful to have the full model number in order to identify the part numbers etc.
I have a Frigidaire dishwasher approximately one-year-old. Has always worked great but lately white residue left in bottom of stainless steel and residue on dishes. Have switched dishwashing detergent Ran...
Try doing a wash with vinegar. It will clean all of those hard water and soap/lime deposits away. We do this frequently (once a month) here in Dallas, TX because the water is really bad.
Oct 27, 2014 • Dishwashers
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
My kitchenaid dishwasher leaves a white residue on clean dishes. 4 year old appliance, worked great until 6 months ago. under warranty, service repairman said i was using too much soap( am not). he cleaned...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
1helpful
The dishwasher is not cleaning properly, glasses look like they have a film on them, plates also do not look clean & the dishwasher has a foul smell.. like rotting food in it.. we use the top quality...
Check the main drain system connected to the dish washer hose pipe. Clean the junction if clogged. This smell might orginate from the pipe.
Check incoming water quality. If hard water is noticed, use softener attachments to the inlet.
Fill dish washer salt in the dispenser. Refer user guide. The salt will help softening the water to certain extent. Finally check whether rinse aid dispenser filled with the rinse aid liquid.
Top rack of Kitchen Aid not clean
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Dishes are not getting clean
Jul 16, 2009 • Dishwashers
1helpful
2answers
Top row of dishes are not getting clean.
It sounds as if there is no water pressure to the upper arm. You may want to try putting something over one of the holes to see if it is disturbed during th wash cycle. There should be enough pressure there to blow off a piece of masking tape if it is not attached too securely. Do some experimenting to see if you have presure there. There could be a problem with the tube that feeds to the water to the upper arm.
May 16, 2009 • Dishwashers
After running a full cycle dishes are covered in detergent residu
www.dishwasherfilter.com has a great product specifically for this problem. it filters the water going into your dishwasher removing the hard minerals that cause this problem. after the first load my dishes looked amazing. it is very affordable and fits right under your sink.
1helpful
Dishes are not clean.. on top level the dishes seem to be steamy
Check the following to address this issue.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
3. Clogged spay arms
4. Water temperature is too low
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
2helpful
2answers
Dishes are not clean; lots of soap residue
Try the combo liguidgel powder packets and wash on the potscrubber plus setting. We saw a drastic improvement with this setting. I have just about gotten out of the habit of thorough pre-washing, but I do rinse heavily soiled items.
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
