Question about DataGo USB 2.0 to IDE/SATA Adapter Kit (00837281003006) Storage Controller
Usb to ide/sata adapter manual
How do you use these. I can find no manual
    Scholar:
  • 113 Answers
Http://techgage.com/article/vantec_sataide_to_usb_adapter/
Just read this it explains it all in detail .....Good Luck
Posted on May 07, 2009
3 Suggested Answers
SOURCE: sata to ide cable
yes see my Blogg here:
http://zylab-silverdragon.blogspot.com/
lok at 2010 time to backup. It explains it all there.
Posted on Jan 19, 2010
SOURCE: Installing a IDE to SATA converter adapter
I have successfully connected a older. 20 GB drive to a computer with a 2. sata connection on the mother board.
Buy trial and error I found that connecting a power cable to the converter and the hard drive was the only way to get the Bios To recognize the drive.
Done sucessfuly with a 40GB drive as well, Set drive to master.
Posted on Feb 11, 2010
Is there an adaptor available that will connect the drive to a USB port?
This set up provides the power for the drive and the connection via USB
They also have USB 3.0 for significantly faster data rates
26126808-0f3qdadr2gbg1i1ke3bo3d2n-4-0.jpg Instructions on USB To SATA IDE Adapters Cables
Hope this helps?.
Mar 12, 2016 | Computers & Internet
Is a ide a hard drive
You should check what kind of hard drive is using your computer. If it has less then 5 years probably hard drives are sata.
watch this tutorial
How to connect SATA devices in PATA IDE only PC system
Modding Guide Inline SATA Connectors
How to connect an IDE drive to SATA motherboard
Jul 22, 2015 | Hard Computers & Internet
Can I take a working SATA ACER notebook HD and put it in an ACER with 44 pin IDE?
Just check whether your hard disk is in good condition., what is the health percentage., It has any bad sector or weak sector,. before changing.,..(because if u use convertor it should work)
use harddiskscential for performance of your hard disk
SATA to IDE adapters any good
http://www.hdsentinel.com/ SATA to IDE Adapter Drive Not Detected in BIOS
Jun 05, 2015 | Acer Computers & Internet
What kind of HDD should I plug into a standard PC, SATA or IDE?
Current generation PC motherboards generally support only SATA drives, both HDD and CD-ROM. Some older motherboards may support both. Consult the manual for your computer under Specifications and it should say. There are adapters available to convert IDE drives to SATA and USB enclosures and converters that can run IDE drives on otherwise SATA-only desktops. You have to be more specific with manufacturer and model numbers of your PC to get more specific answers.
Jan 13, 2015 | Computers & Internet
Turn into usb drive
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4
USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit
AU $8.09 free postage worldwide
You would have to remove the hard drive and use a usb sata ide kit
you will then have to connect it to your computer using a usb port
Aug 13, 2013 | Western Digital Caviar SE16 WD5000AAKB -...
Wd50000aakb make into a external usb
AU $8.10 free postage worldwide
Please help me with this
USB 3 has the fastest data transfer speed through a computer with USB 3 port. If your computer does not support USB 3 then it cannot transfer data at USB 3 speeds.
If you install a hard drive into an USB 3 hard drive adapter case and the data transfer speed would depend how fast a hard drive you install in this USB 3 adapter case.
A SATA hard drive is faster than an IDE/PATA hard drive. Make sure you get the correct USB hard drive adapter case with the SATA or IDE/PATA connector that matches the hard drive.
Nov 03, 2012 | Computers & Internet
Hi there. When talking about USB 3.0. Can say say that there is a USB 3.0 hard drive? Or can I say that if I have an external USB 3.0 hard drive case and place a hard drive in it it would have the USB
Good day sir how do i connect a 500gig sata drive to a mother board ms 7142
Dear User, Good day, This is the specification of your motherboard. MSI K8MM-V Via Socket 754 MicroATX Motherboard / Audio / 8x AGP / 10/100 Ethernet LAN / USB 2.0 / Serial ATA. All you need is sata cables and an adapter if the power supply cable support only serial IDE. check this link for the photo of the adapter. http://www.buy.com/prod/ide-to-serial-ata-sata-for-3-5-hdd-pc-adapter-converter/q/sellerid/23962916/loc/101/214950013.html
Apr 16, 2011 | MSI K8MM-V Motherboard
Ide to usb connector sata cable attachment
The connection should be simple where you match the connections. The long connection is for the power and the short is for data. You can't really mess up the connection but be carefull when trying to connect and not to force the connections.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | Adapters.com Serial ATA IDE Converter and...
DataGo USB 2.0 to IDE/SATA Adapter Kit (00837281003006) Storage Controller Logo
1,360 people viewed this question
Top DataGo Computers & Internet Experts
David Payne
David Payne
Are you a DataGo Computer and Internet Expert? Answer questions, earn points and help others
