SOURCE: My HP Compaq nx9030 wont turn on
try to remove your memory/ies. then plug it to ac power without battery, if it turns on try to unplug and put back the memory module (one by one if more than 1). plug and switch on if it works then put everything back if not, you ned to replacethe memory.
Hope this helps.
Please vote if it does.Thanks!
SOURCE: my laptop will power on but will only show a blank
It seems that your system/Laptop is affetected by some spyware or antivirus. To remove this follow these steps:
1. Power On you laptop.
2. Press F8 function key before the window logo appears.
3. Select to choose Safe Mode.
4. Now use System Restore to restore your system to the previous date.
5. After completing the Sytem Restore, you will be able to login to windows.
Thanks
SOURCE: Hi, my laptop is hp
hi,
Power drain would be a better solution in this case.1.first shut down the comp2.unplug the charger3. remove the batteryand after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
And if the issue still persists.update the bios of your computer to the latest version which is available on the HP website.
