Question about Philips Magnavox DVD/VCR Dual Player
Magnavox ZV450MW8 After initial setup.... loses all programming except Time. Not power failure related. This is an intermittant but continual problem.
Magnavox is made by Funai. Similiar problems in another piece of equipment made by them was solved by 1) Turning off DST in the clock, or/and 2)Turning off the clocks auto update feature, ie, go to manual clock adustment. Hope this helps.
Posted on Nov 27, 2008
Lost manual for DVD Recorder/VCR ZV450MW8 Need instructions to copy DVD Disk to VDD Disk or e-mail manual
To dub a DVD, first press Setup on the remote. Then select Recording (use the Up/Down arrows and then press OK). Navigate to and select Dubbing Mode. Select the direction for the duplication. Then press Setup to leave the Setup menu. Then press DVD to ensure that the unit is ready to play the DVD. (Press VCR if you are dubbing a video tape.) Then Press Play to advance to the section that you wish to duplicate, if needed, and then press Pause. (Press Pause a bit early; the dubbing process will lose about 5 seconds.) Now, press the other Mode button (VCR if recording to tape, DVD if recording to DVD). Next press D.Dubbing on the recorder or the remote. (The button is to the right of the Channel Up/Down buttons on the recorder. It's near the bottom left on the remote.) Press Stop when the section to be duplicated has been played in its entirety.
The Magnavox ZV450MW8 was manufactured by Funai with the Magnavox name. Thus Funai Service has the manual available: http://www.funaiservice.com/manual2012_search2.php . The direct link is http://www.funaiservice.com/manuals/MAGNAVOX/ZV450MW8/ZV450MW8.pdf . The directions for dubbing a DVD to VCR or vice versa start on page 48. Note: copy protected items cannot be duplicated.
I hope this helps.
Dec 10, 2014 | Televison & Video
Tip
Hey tech guy. Have a Magnavox ZV450MW8 DVD \ VCR combo. Unit loses all...
One fix to return DVD player to origional setings, is to go in to the menu and find the factory reset option the will return the setings back to fresh from the factory.
Regards Tech Guy
on Sep 07, 2008 | Panasonic DMRES30V DVD Recorder/VCR Combo
I need an owner's manual for a magnavox DVD/VCR combo ZV450MW8
click this
http://www.manualowl.com/p/Magnavox/ZV450MW8/Manual/39630
or paste into search box
Dec 29, 2012 | Televison & Video
Magnavox ZV450MW8 will not turn on
if no power indicator check for broken power cord, if ok at this time you will need to remove the cover of the dvd player to access the power supply.then look for blown fuse or any burnt parts here.
Sep 22, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
Magnavox ZV450MW8 shuts off within 10 seconds of being turned on
The problem is in the power supply, one or two capacitors fail and sometimes have a slight puff at the top, need to be replaced.
Mar 18, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
How can I get a manual for ZV450MW8
Please send me an email to LBrown18062@hotmail.com and I will send it to you. Please put "Magnavox zv450mw8" as the subject or you can use the web address below:
www.magnavox.com/support/download_list.php
Jan 27, 2012 | Magnavox ZV450MW8 DVD Recorder VCR
Need manual for Magnavox ZV450MW8
Hello
Get into this site from you can download the user manual of your device. It is in pdf format comes over 11MB capacity. If you feel any difficulty in downloading the same, send your email address to me by FixYa comment box. I;ll send a copy of the manual to you by return mail. OK.
www.funaiservice.com/manual/MAGNAVOX/Manual/ZV450MW8.pdf
Jun 24, 2011 | Magnavox ZV450MW8 DVD Recorder VCR
Hello. I recently bought model TC-L32C22 for the waiting room of an office. Every morning when I turn on the tv, I have to go through the setup of the channels again. Why is this? Did I do the initial...
Could the unit be losing power overnight? If the TV is on a switched outlet, change outlets (or make sure the switch stays on). Did you actually finish the setup? The setup screen will continue to appear if you press Exit before it is completed. You should have seen the "Setup is complete" message.
If you are correcting the time as well as repeating the scan, the TV is probably losing power overnight.
If this is power related, consider a UPS that will power the TV overnight in Standby mode. It uses 100 W when on and 0.3 W in standby.
I hope this helps.
Jan 19, 2011 | Panasonic Televison & Video
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I need to get a manual for a magnavox vhs/dvd recorder item #zv450mw8
Hey jleedwards,
If you have lost your owner's manual for this Magnavox VHS/DVD recorder, you should be able to find a copy of it online through the Magnavox/Funai support website:
http://www.funai-corp.com/6pdf/om/ZV450MW8.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 16, 2008 | Televison & Video
Philips Magnavox DVD/VCR Dual Player Logo
145 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
