Question about Whirlpool AWM5145/2 Front Load Washer
Too much water
Hi, i really, really, really hope someone can help! Our washing machine has stopped draining the water out! When cycle finishes the clothes are soaking wet and theres loads of water left in the machine. I really dont have a clue, my mum has gone on holiday so this is a big drama to us! Please help!
  • 1,543 Answers
Most likely your water pump is blocked. I don't know where to find a parts brake down for this, as this model is not listed over here across the pond, but from the photo I found it appears that there may be an access door to a filter on the lower right side of the machine.
Posted on Sep 17, 2008
Machine will not finish any wash cycle, It stops, illuminates END light and beeps? Is there a reset or is this at the end of it's life?
Hi, quite often cycles are not finished because the drain pump has an intermittent fault. It may pump ok at the start of the cycle but towards the end it's had enough and stops. Leaving water in the bottom of the drum. If this is similar to your machine's symptom then I would be checking the pump. They are cheap to buy and easy to fit.
Hope this helps you.
Oct 04, 2015 | Washing Machines
Washing machine won't drain or finish cycle
It sounds like you have a drain pump stopped up or failed. Do you hear any noise when it is supposed to be draining? A humm or buzz?
Oct 31, 2007 | Fisher and Paykel GWL11 Top Load Washer
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
Start matsui washing machine
Check the washer drain hose for clogs.
Jun 19, 2017 | Washing Machines
Hi. I have a kenmore Washing Machine model 27062601 It doesn't finish the cycle. stops wen is washing, then I have to open it and start the cycle again. some times this works, some times don't. ...
Hi xochipiliti,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 05, 2011 | Kenmore Washing Machines
Not working 100%
One the water in the bottom of the machine is more than likely becuase it is not draining properly reason?
Thenpump or drain pipe could be blocked or the filter or outlet at the bottom of the unit is clogged with food,Two are you useing dishwasher powder or blocks and not dishwashing liquide,three chech the wash arem holes are not clogged with food all holes must be open if two or so clogged it will spin the arm but will not wash properly and naturally will not rinse properly they must aslo be clean.Last make sure the machine is heating the water and not trying wash cold do this by stopping the machine mid cycle and open the door is there steam if so cool leave it to finnish the wash so clean filter ,wash arms,drain pipe blow into it and see if ant food particals appear in the machine,
Hope this helps
Jan 23, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Beko WMA 765s washer, power works no display
If there is power and lights are showing, but the door will still not open, then it could be one of several things.
First and foremost the door lock could be faulty, or the door handle or latch mechanism could be faulty or broken, if the door lock is not getting power then it is probably the main cotrol unit at fault.
I feel you should get someone to look at it for you.
Dec 07, 2008 | Washing Machines
Washer problem
Inspect the drain hose, see if there is any obstruction.
Try to understand if the machine does not drain at all or if the cycle is not completing , and timer stops before completinc cycle.
If the machine is not draining, then, once you check the drain hose and see no obstruction in there, it can be a faulty drain pump, or a faulty water level switch. If machine instead does not complete the cycle, it is a faulty timer/programmer.
See here for more detailed explanation: It won't drain
Sep 08, 2008 | Kenmore 22422 Top Load Washer
Will not finish draining
i have amagtag neptunetl washingmachine and it won't drain the water all the way out nor will itspin out anything.it is computerized.sure could use your help
May 18, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Whirlpool AWM5145/2 Front Load Washer Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
