Nokia C6 Smartphone Logo
Posted on Sep 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the factory restore setting code for nokia c6-00
Anonymous
Level 2:
Sergeant:
  • Expert 150 Answers
  • Posted on Sep 22, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
150
Questions
0
Helped
26143
Points
505
You can format your device by typing *#7370# when your mobile is in standby mode. Before the device is reset you need to provide the lock code. The default lock code is 12345.make sure you didnt change it!
dont forget to vote!
Micromax master resetting code all
1.NormalReset - Dial *#7780#
If you dial this code in Nokia handset, it will restore system setting without missing phone memory data (videos, photos, songs).
2. .Deep Reset - Dial *#7370#
When this code isdialed in Nokia handset, it will wholly clean internal phone memory. Entire phone settings and profiles will be deleted, but there is no effect on memory card data.
Remarks -
For Nokia Symbian 60 V1 supported mobile handset (7650, 3650, 3600, 3620, 3660, N-Gage)
you can dial *#7780#*#7370#
Latest S60 mobile handsets, you can dial Deep Reset through another way.
*.Switch off mobile handset first.
*.Press calling key (green), 3 and * keys or (Green calling button + 3 + *)at same time and grip them down.
*.You find a message about format mobile and then release these keys.
*. Password of Reset factory setting code will be either 1234 or 12345.
Nokia X3-02 mobile Restorefactory -
*.Go to Nokia menu lists, browse these options one by one-
*.Menu --settings-- Menu--- Restore Factory Setting
*.Insert phone code 12345and wait few moments to complete restore process.
Nokia 5230, 5800, 5233 and similar mobile handset Restore factory settings, how ?
*.Browse phone menu lists,
*.Then, go to
Menu - Settings - Phone -- Phone mgmt Factory settings
*.Insert security code -12345
*.Without data lost of internal memory, Nokia handset returns in original modes.
Hard reset of Latest Nokiahandset through another code -
*.Switch off mobile handset.
*.press and holdGreen (calling) +Red (End call button) + Camerakeys at the same time along with switch on power of mobile handset.
*.Then mobile asks to insert phone security lock code , so insert12345.
Samsung Restore factory code
*.*2767*3855#
*.*7465625*638*00000000*00000000#
*.#7465625*638*00000000#
or
*.Remove SIM card from mobile handset
*.Once off and on handset
*.Type *2767*2878# to perform internal memory reset
*.Insert SIM card again in mobile.
Samsung Androidsupport handset restore factory code -
Type*#*#7780#*#* - To Factory Restore.
Micromax Restore factory code for all version with Android -
You can use any following below code one by one to perform restore factory of Micromax mobile:
*.1122
*.0000
*.1234
=*symphony> 1122
=*nokia >5071 or 0000
=*micromax> 1234
=*tecno > 1234 or 0000
=*samsung> 1234
=*apale i phone >5869
BACK2HOME
Information from:
http://peperonity.com/sites/a--a.secret.mobile.codes/47096442
Terry
13helpful
2answers
How to restore my factory setting of nokia 7210c
To restore Go to Menu>Settings>Restore Factory Settings>Enter security cod(Default will be 12345)
Thank You
Don't Forget To Rate
Jan 25, 2011 • Nokia 7210
8helpful
Default restrofactory setting code
To restore to factory settings you no need any codes.
Please follow the below steps to restore your mobile to factory settings
Menu > Settings > Restore factory settings
When you select this,It will ask for security code.The default security code for nokia mobile is 12345.If you have changed the security code then type that code.
It takes several seconds to bring it to factory settings.
Thank You
11helpful
3answers
I need code of nokia 3600 classic reset factory setting
Thank You
Aug 07, 2010 • Cell Phones
5helpful
3answers
Restore settings
You have not mentioned which settings you want to restore. I take it that you want to restore factory settings.Go to settings in the menu and choose restore factory settings. Your phone will be set to factory settings and you can start afresh
5helpful
4answers
Nokia N95(black) restore factory settings
the default code is 12345. if you have entered a security code in your phone, use it to restore to factory settings
14helpful
2answers
Restore factory settings on Nokia N95 8g?
Please do this.Type *#7370# in your mobile phone,it will ask whether you want to restore factory settings give yes and it will ask for the code the default code is 12345.Give the code and wait for some time your phone will restart and you will see that your factory settings are restored.kindly rate me if i had helped.
42helpful
6answers
I can't put my nokia 6300 into restore factory settings mode..
The defaulkt security code for Nokia is 12345. You can reset the security code using : *#7328748263373738#. It works on most nokia phones. Worth giving a try.
And if the phone says simcard rejected, then the most common problem is that the phone probably might have been locked. You can get it unlocked for 5 quids in your local market.
Nokia 1200 v5.06
Restore factory setting for a Nokia 1200:
Menu > Settings > Restore Factory Settings > enter the security code
The default security code is 12345. If it doesnt work remove your battery for 15min and try the code again. Still the same?the code has most probably been changed. Dont remember the code?Best to refer to a Nokia Service centre for a code reset :)
20helpful
4answers
How to restore ALL factory settings to the Nokia 2630
my Nokia 2630 Serial Number 354861022927732
I do not restore due I have not known his code
please tell me the code
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
