Question about Zanussi ZWD1680W Front Load Washer / Dryer
Dryer problem the dryer starts to dry and it keeps knocking its self off.
I've just had a the same problem with this model, locking out with error code E20 ...but fixed it!, and i tell you what - it's not difficult. Give it a go and save yourself loads of money in the cost of professional service, repair or unnecessary replacement.
I've had the machine only about three years, but it's seen some heavy use with two small boys in the house ...so it's worn maybe more like double its real age (how i feel getting out of bed some mornings).
The lockout seems to be an overheat protection rather than anything broken.
The dryer works by sucking air out of the right hand side of the drum, through a clear(ish), flat plastic tube to a metal fan chamber at the top, the fan blowing air into the heater chamber (wrapped in tin foil across the top), from where the hot air passes back into the drum through the slot at the top of the front door.
Thing is, some of the fibres and fluff washed and tumbled off clothes collects and clogs in the clear tube on its way to the fan ...some of it dry and thin like old wallpaper, but most of it (after some time) thick and staying damp like paper mache. Of course, when the tube gets blocked and the fan can't **** up enough air to blow across the heaters, i guess the heaters get over hot (mine was scorchio when i took the lid off straight after the second time it failed) and an overheat thermostat is tripped. There might be other forms of protection like pressure switches and current sensors, but hey we don't need to know if there are.
All you have to do is remove the tube and poke and flush out the fibre mache.
Before you start though, for heavens sake UNPLUG THE MACHINE! If it's wired into the wall, then at least remove the fuse or flick off the circuit breaker at the fuse box.
Unscrew the two screws at the top and behind the lid. Slide the lid back and lift off. Looks daunting doesn't it? Honestly though, don't worry about it.
Find and remove all the screws holding on the back panel (there are four to the rear of the top cross bar and one hiding behind a white grommet down the bottom of each side). Unclip the tube /cable holder at the top and knock /slide the back panel rearwards.
Down the right hand side, you'll see the clear flat suction tube. Prise the small tube off the top and the fan up until the suction tube can be pulled out from the side. Unscrew the hoseclip around the black rubber drum tube on the inside face, then prise the suction tube out of the base frame with a screwdriver and some care.
You'll then be able to flush /poke out the fibre mache with a hose and a wire coat hanger.
Reassembly is reverse of the above. Bingo, you're done.
Oh and if it still doesn't work, what have you lost by trying?
Posted on Oct 07, 2008
  • hugo943 Dec 10, 2010
    My 'clearish' flat-pipe didnt look particularly blocked - but cleaned it out anyway (used garden hose down both holes) and it seems to have sorted the problem... Thanx!
Frigidaire dryer started loud knocking. A cpl weeks later knock stopped but it took 2-3 cycles to dry. Now it won't dry at all. What's a good place to start troubleshooting?
Hello Dondrake, thank you for your submission!
From the information you have provided your Frigidaire dryer was knocking and now it is no longer heating. This could be a potential problem within your heating element or control panel. I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord from the dryer for at least ten minutes. I hope this information is helpful to your repair. -Matt
May 04, 2016 | Frigidaire Dryers
Why does my dryer will complete a cycle then shut off. It then goes to the next setting an starts by its self. Any suggestions?
control board defective? bad moister sensor not sensing dry clothes and going into dry cycle agin?
Jun 21, 2014 | Samsung DV337 Electric Dryer
Maytag neptune mdg9700bww dont stop drying by it self
could be dirty electrodes, find the two shiny metal strips in the dryer drum maybe in the front, so you will stick your head in the drum and look back at the lint filter to see them. Clean these with window cleaner and try again.
Jan 22, 2014 | Maytag Neptune MDG9700A Gas Dryer
MY DRYER HAS STARTED TO HAVE A KNOCKING SOUND ON ALL SETTINGS PERIODICALLY DURING THE DRYING CYCLE. IT SOUNDS JUST LIKE SOMEONE KNOCKING ON FRONT DOOR OR LIKE A SHOE BANGING AROUND IN DRYER. MAYBE NOT...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 15, 2011 | Fisher and Paykel DEGX2 Dryer
There is a knocking noise as the dryer works. This just started. But it does dry the clothes in as usual. Please help.
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Jul 04, 2010 | Magic Chef CYE4000AWW Electric Dryer
My dryer is not drying the clothes. It is a self venting dryer and I clean the filter everytime but the clothes are not drying. The filter light keeps flashing and I think the dryer is turning off.
check the out side vent and make sure that it is not blocked with lint also make sure that the ducting is not kinked or has to many curves in it that will hamper the effects of proper drying
Jun 09, 2010 | Dryers
Top loose, new dryer not level? rattle when start
No dryers are not self leveled. You may not have put the legs on ? they come in the box or if you have then you need to prop them up with a 1x4 or something.
Apr 19, 2009 | Kenmore 500 6952 Dryer
Zanussi ZWD1680W Front Load Washer / Dryer Logo
337 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Chris Hall
Chris Hall
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
