Question about Lexmark X3470 All-In-One InkJet Printer
LEXMARK 3470 COVER OPEN
Cartridge changed the message says cover open when it is closed
  • 446 Answers
There is a switch actuator on these cover try to see if you can find any piece of tab that actuate these switches, unless the cover is really closed ensure that it is fully flat
cheers
Posted on Sep 17, 2008
Changed my cartridge and the printer says cover open. Will not do anything else
Posted on Nov 23, 2008
Message says COVER OPEN CLOSE COVER but the cover is closed
The problem could be due to the printer cover sensor getting stuck or the cartridges in the carrier. Please follow steps below to identify and fix the problem:
1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
2. Open the printer cover and remove both the cartridges.
3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
4. Close the printer cover.
5. Unplug and re-plug the printer into the power source to reset it.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for errors.
8. If no error appearsl, open the printer cover and reinsert the other cartridge. Check for errors.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
10. Load some paper. Try to print again.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 11, 2011 | Lexmark X125 All-In-One InkJet Printer
My lexmark printer x 3470 will not operate....it says the cover is open but it does not appear to be and none of the controls will function.... help please??????
It could be due to the cartridges in the carrier or the sensor for the cover has become stuck. Open the printer cover and remove the cartridges from the printer. Close the printer cover. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, re-insert the cartridges and close the cover. Check for any errors.
Jun 15, 2011 | Lexmark C533DN InkJet Printer
After changing cartridge the message "cover open"
raise the cover and see if u can see a switch of some kind puss it down and see if it will print or restart ur computer and see what happens
Jan 23, 2011 | Lexmark X3480 All-In-One Printer
Please help me find the spot to re place the ink cartige to an x 3470 printer
Perhaps the Lexmark X3400 Series User's Guide will give you a better picture. You can download it using this link: http://bit.ly/cSUqq8. Scroll to page 52 for the instructions on how to change the print cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thank you for choosing Lexmark.
Oct 15, 2010 | Lexmark X3470 All-In-One InkJet Printer
Show error2200
1.Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2.
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved. Source(s): http://support.lexmark.com/index?page=co…
Apr 23, 2010 | Lexmark P4350 All-In-One InkJet Printer
X3470 printer says cover open and no buttons will work after I changed the ink cartridge and closed the cover it says cover open. the only way it will shut off is to unplug it.then it says 3470 then goes...
It is a common fail in this model there is a plastic arm which works as an extender for the switch that senses that the cover is open this part is easily detached from its place(in my case not broken but it could happen I suppose) resulting in printer showing that message. the switch is situated under the the scanner in the middle . when you lift the scanner part to see the ink cartridge, you see a plastic part underneath that looks like a 2/3 of a circle that is the part that pushes the switch.
You should open the printers gut and place the loose part back in place. Be ware that flat cables contact ends could easily brake use caution. (if you shake your printer you may hear the sound of the lose part).
You may ask if you need further assist.
and PLZ rate!
Happy solving problems!
Bruce
Jan 19, 2010 | Lexmark C533DN InkJet Printer
Error 2200 lexmark 6250.
hey ,
Follow the steps :-
Step Action
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved...
Nov 15, 2008 | Lexmark X7170 All-In-One InkJet Printer
Error 2200
Step Action
1 Power off the printer and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the printer on.
2 Power off the printer and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the printer on.
3 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the printer.
4 Power off the printer and remove the power supply from the back of the unit. Open the top cover of the printer. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the printer on.
Sep 16, 2008 | Lexmark P4350 All-In-One InkJet Printer
The scanner cover is closed, however I get an error message saying it's open. The unit will not print, copy or scan
I just changed the cartridges, however I get an error message saying " Cover open / close cover / change cartridge " error . The unit will not print, copy or scan. Any suggestions? Thanks
Jul 07, 2008 | Lexmark Pro X125 All-In-One InkJet Printer
Carrier Jam
i have a problem with my printer it gives a message saying 'clear carrier jam' with a big noise.its not working it is going too fast
Sep 26, 2006 | Lexmark P6250 All-In-One InkJet Photo...
Lexmark X3470 All-In-One InkJet Printer Logo
291 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
