MY sharp TV is broken. Where the cable is screwed into in the back of the TV was pulled out without being unscrewed. So I need to have that fixed so that it can be hooked up to my tv so the cable cord is able to screw back in.
    Genius:
  • 2,920 Answers
Youll have to either have it soldered back in or replace the tuner
Posted on Sep 17, 2008
Starter cable is stuck
unscrew top and check recoil drum if doesnt turn back possible broken spring following links should help
An easy way to fix pull start recoil spring How to Replace the Recoil Spring in an MTD Motor Lawn Mower About com Search Find it now
Jul 27, 2016 | Garden
My cable connector pulled out from the tv and now the tv won't stay on the power button will blank three times and go off what can be the problem?
when the cable got pulled it broke a connection on the board , and thatswhy it won't come on
it will need to be resoldered where the cable was pulled
need more help just ask me!
electech
Oct 26, 2008 | RCA Televison & Video
My mirror is cracked on my toshiba 46hm84. How Do I replace it myself
Here is a picture of the front bezel removal to get access to the mirror.d11d1b4.jpg
Sep 19, 2008 | Televison & Video
I HAVE A LG REAR PROJECTION TV MODEL AN-44RB10 HOW DO I CHANGE THE LAMP
If you see the tv set from the back you should see to the left part of it something like a plastic box sealed with twoscrews unscrew them and put the plastic off inside you will see a metal box holding the lamp (make sure the tv has na power and) unscrew the metal box and pull it out unscrew any screws holding the lamp and without touching the lamp at all replace it with a same one (don't use your bare hands because the grease from your hands will be burned when the lamp goes on and might destroy it . screw everything back screw the plastic and give it a try
Jun 09, 2014 | LG Televison & Video
WANT TO REPLACE THE BACKLIGHT ON MY SHARP 55R wp4H
Turn off the TV by pressing the power button. Go to the rear of the TV and pull the power plug from the electrical outlet. Wait 10 minutes for the power to drain from the LCD TV's capacitors before going to the next step because TV store a lot of current which can cause electric shock.
Go to the back of the TV and locate the lamp tube replacement panel in the lower right corner. Pull the maintenance cover off by hand first. Then unscrew the Phillips-head screw that secures the smaller tube door panel down. Pull the door panel off and unscrew the two retaining screws that hold the lamp tube in place. Pull the lamp out by hand and then insert the new tube. Screw the retaining screws onto either side to hold the lamp steady.
Re-screw the tube door panel back into place and then slide the maintenance cover over that. Turn the TV around. Plug the power cord into the electrical outlet and turn on the TV and that would be all.
Regards.
Apr 26, 2011 | Televison & Video
I can not remove the stand from my tv
1. Verify that there are 4 screws fastened (2 screws on each side which can be unscrewed using a hexkey)
2. place the TV on a flat surface with the screen facing down... unscrew the 4 screws using the right hexkey size.
3. Pull the stand downwards to take it off.
Sep 12, 2010 | Sharp LC-52D64U 52 in. LCD HDTV
Need to remove dashboard parts to fix speedometer cable 1982 Olds Firenza
pull the screws on the outer plastic panel when its off take the screws out of the speedo cluster on the out side of it .carefully pull it out and unplug the wires and the cable pull the cable threw the dash and unscrew it from the trans .then work your way back to the start
Jul 12, 2009 | Oldsmobile Firenza Cars & Trucks
How can I still use this TV?
find another TV, VCR (many around now), or other cable using device and exchange - 7 or so screws on  back of tv come right off and expose lower interface where cable jack is.  remove wires, solder salvaged unit in and it works....  Be careful when removing back of tv -  you can pull other wires when doing so.
Mar 11, 2009 | Sharp 27L-S100 27" TV
VCR/DVD prongs broken off in TV
unplug the tv then try to drill a real small hole in the broken off part of the cable that is inthe tv, then take a sharp pointed screw and try to thread it into the hole that you drilled if able to get it started then pull out on the screw to see if it will come out. If not able to do it this way you will have to take the back off and some of and see if you can push the broken part out from the inside. Be sure to unplug your tv from (AC) so you dont get hurt. If that dont work then u probley willhave to take to a shop to get fixed.
Feb 20, 2009 | Zenith C27A24T 27" TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
