Question about Ovens
Electrolux eog 7330
As described before with this model, my oven has tripped out and your right it's because it has overheated. but is there a reset button or do you have to do something else?
    President:
  • 1,462 Answers
There is an overheat stat somewhere inside the casing - sometimes on the top[ and sometimes close to the fan. this may be a resettable stat - ie has a little button in the middle to reset.
another way is a thermal fuse - a little cylindrical thing inside a heatproof plastic tube
Posted on Sep 18, 2008
Why is my electrolux oven is ringing non stop after using pyrolitic cleaning
Hello Avishag, thanks for your post!
From what you have described your Electrolux oven is ringing after you have used the pyrolytic cleaning. Your control panel may need to be reset and you can do that by disconnecting power from it for at least ten minutes. If this does not help resolve your issue I would need your model number to further assist you. You can locate that information on the frame of the door on a white or silver tag. Once I have that information I would be happy to assist you further. -Matt
Apr 11, 2016 | Electrolux Ovens
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Oven overheating
Your thermostat is STUCK. Replace. Your 'tripping mains' is your clue that your power is over loaded. Have an electrician check your boxes to make sure all is ok AFTER fixing stove.
Mar 03, 2014 | Electrolux EOC6690X Pyrolytic Electric...
I cleaned my electrolux oven for 3 hours and now my oven will not heat up any help please?
From what you have described sounds like you need to have the oven reset. Unfortunately, if resetting it at the household circuit breaker does not prove to be successful, then you will need a professional technician to pull the unit out of the cabinet/wall and reset it from the back panel.
Jul 31, 2012 | Electrolux 30" Built-In Single Electric...
Hi, I have a Electrolux EOG 900 builtin gas oven & gas grill, fan very noisy. Its 10 years old, willl the grill & oven pack in if the fan gives up altogether. Would it cost alot to fix. Hope to...
They won't pack up.. The fan is there to circulate the warm air. It might not heat up or cook as quickly as it used too. It will not cost much to fix though, labor will usually cost more than the part itself.
Good Luck
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Electrolux Ovens
OVEN OVERHEATING
thermostats are not the sane. make sure cooling fan is working as this is more likely to cause the oven to cut out
Jul 23, 2010 | Electrolux EOD6390X Electric Double Oven
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Jul 12, 2010 | Electrolux Ovens
Main oven light and fan comes on but no heat. Reset clock. Happened after power trip. Small oven and grill works OK.
Check that the oven timeclock is not set to 'Auto' as if so this will prevent the oven from working. It should be set to 'manual'.
Try this and then reset oven.
Dec 23, 2009 | Electrolux Ovens
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Tripped out
take off the oven knob, behind is a piece of plastic - the reset switch is behind that.
you have to poke a smal screwdriver in and should hear a small click
Sep 02, 2007 | Electrolux EOG7330WN Gas Double Oven
Ovens Logo
137 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
