Question about Olympus EVOLT E-500 Digital Camera
Shadow's A small shadow appears on my images as I view the finished pic on my screen flashing on the dark areas of my pics. How can I fix this problem? CJ
    Sergeant:
    Champion:
  • Olympus Expert
  • 479 Answers
Try to reset camera or you may need to brighten the exposure
Posted on Sep 19, 2008
  • Randy Morton Sep 19, 2008
    you may also press the info button to get different views... it will give you 5 different views
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
Tip
How to Put on Eye Shadow
Achieving Smoky Eyes.If you're looking for a way to play up your eye color, go smoky. A smoky effect makes eye color pop and creates a dramatic evening look. Read on to learn how to create a flawless smoky eye. <br /><br />Create a smooth canvas for eye makeup. First, you'll want to apply a primer to your entire face, including the eye area. Then apply a concealer to get rid of redness and dark circles. Finish off by applying a moisturizing foundation to create a flawless canvas. <br /><br />Apply eyeliner. Use a black liner and draw a line across the upper lash line. When you get to the middle of the eye, make the line a little bit thicker. Choose a lighter-colored eyeliner and line the bottom of your eye. Smudge the liner with your finger to create a smoky appearance. <br /><br />Apply two colors of eye shadow. In order to select the right products, check out eye shadow reviews. You'll want a color palette that has both a light and a dark color, such as L'Oreal Paris HiP Concentrated Shadow Duo. Use the lighter color as a base and blend the color all over your upper lid. Then, apply the dark eye shadow, starting at the lash line and blending upward.
on Nov 22, 2010 | Health & Beauty
I droped it =( 1- when i start the camara , i hear a shake or rarel in the zoom 2- in the digital view finder i see the image shaking 3- than it finally stops the image shaking right to left very...
Sounds like your image stabilizer got damaged by the fall. You'll have to get your camera serviced by an authorized Nikon service center.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10003
212-673-8400
Jul 05, 2011 | Nikon COOLPIX P90 Digital Camera
Dark semi circle shadow and pics too bright
Are you using a lens hood? Is your ISO set too high?
Apr 22, 2010 | Nikon D90 Digital Camera with 18-105mm...
Samsung lcd tv 18months old
i had the same problem and it turned out being the panel
Feb 28, 2009 | Samsung LN-T4665F 46 in. LCD Television
4805 shadow
I had the same problem just 99 hours after changing the lamp for the first time. The problem you describe is most likely the light tunnel that is cracked. I wasn't able to buy a new one on my own, I had to turn it in for repair. The light tunnel is only a couple of mirrors that the light travels between.
Jul 16, 2008 | InFocus ScreenPlay 4805 Multimedia...
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Dark screen
Two reason for the screen to be dark
1. If you can see 'shadow' images on the screen, this implys the backlight tube or the inverter circuit has blown.
2 If No images show up at all then this is a mainboard failure
This is assuming the batteries are ingood condition and the camera powers up..
Check Vivitar support for repair/replacement options.
If under ewarranty it will be replaced
If out of warranty - New Camera Time
Dec 30, 2007 | Cameras
Olympus EVOLT E-500 Digital Camera Logo
81 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
