Wpc54g model number need to locate my encryption code 192.168.1.1 user name charlie password phillips
    Scholar:
  • 147 Answers
You can set the code to whatever you like, by logging into the adapter's built in web page, and changing it yourself.
Enter the IP above into your browser.
Posted on Sep 17, 2008
Hotmail pop and smp codes
  • POP server: pop3.live.com
  • POP server port: 995
  • POP SSL required? Yes
  • User name: Your Windows Live ID, for example yourname@hotmail.com
  • Password: The password you usually use to sign in to Hotmail or Windows Live
  • SMTP server: smtp.live.com
  • SMTP server port: 587
  • SMTP Authentication required? Yes (same as POP3 username and password)
  • SMTP TLS required? Yes
Aug 10, 2015 | Google Computers & Internet
Forgot user name and password need to add new
Sorry but this is the only to reset the password
Press the Reset Button for approximately 10 seconds
Resetting the Router will erase all of your settings (WEP Encryption, Wireless and LAN settings, etc.) and replace them with the factory defaults.
Jun 06, 2011 | Linksys Wireless-G WRT54G Router
I tried to change from WEP to WPA but the password will not go through. It makes it an unsecure line for wireless. What am I doing wrong?
The Short Answer:
Your password might not meet criteria. It also depends on whether you use a custom encryption key. If so, then you either need to create a 10-digit or 26-digit hexadecimal number (numbers 0-9 & letters a-f) depending on whether you use 64 or 128-bit encryption.
The Long Answer:
A WPA password must be between 8-63 characters long, and must only contain ASCII printable characters.
The 2Wire User Guide for the 2700 states the following:
"You can customize the following wireless settings in the Wireless Security panel.
1. From the Authentication pull-down menu, select an authentication setting: WEP-Open, WEP-Shared, or WPA-PSK.
Note: WPA-PSK authentication is supported only on HG model gateways.
Open authentication allows users to configure their wireless adapter as either Open or Shared; in either case an encryption key is required. Shared authentication allows users to configure their wireless adapter for Shared authentication, which requires an encryption key. WPA-PSK requires that users configure their wireless adapter using TKIP.
2. To use the encryption key that came with your gateway, click the Use default encryption key radio button.
To create a custom encryption key, click the Use custom encryption key radio button. If you select Use custom encryption key, you can define a 64-bit or 128-bit encryption key. For 64-bit encryption, enter a 10-digit hexadecimal number. For 128-bit encryption, enter a 26-digit hexadecimal number. A hexadecimal number uses the characters 0-9, a-f, or A-F.
3. Click SAVE"
May 04, 2011 | 2wire 2700HG-B Router (2700HGB)
My grandpa set up our wireless network a few years ago, but bless his heart, he passed away just this year and we forgot our WEP key and we need to reset it or just get ahold of it so the family can access...
Sorry for your loss.
  • Note: Resetting your router to the factory defaults not only changes your gateway user name and password to the factory default values, but it also deletes all your home network settings. This includes the SSID and network encryption key. After you reset your gateway to the factory defaults, your home network won't be accessible until you reconfigure your router and all your network devices to use the same SSID and network encryption key.
To reset your VersaLink 327W gateway to the factory settings:
Hold the reset button on the back panel of the VersaLink gateway for 30 seconds.
  • All your settings will be lost including network encryption information, MAC Address filtering information, and any SSID information you have entered.
  • The gateway user name and password will revert to the default of Admin as the user name and Password as the password.
  • You will need your user name or password to reconfigure the unit..
Your VersaLink 327W gateway is now using the default settings for the network configuration. This includes the default SSID and network encryption key. You must re-configure your VersaLink gateway to match your previous settings that were assigned to all other devices on your wireless network. Otherwise, no other network devices will be recognized.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 18, 2011 | Westell Wirespeed VersaLink...
How to set a password?
  • Access the router's default configuration address through your Web browser by entering this address: http://192.168.1.1 (see Resources). Do not enter a user name. Enter "admin" for the password. That process works for all new Linksys routers. If you have changed the user name or password in the past, use the user name and password that you created.
  • 2
    When the configuration screen opens, click on the "Wireless" tab and select "Wireless Security" to view the router's current security password. The "Security Mode" field will say "Disabled" if you do not have a password to secure your network.
  • 3
    Select the appropriate encryption type from the "Security Mode" drop-down menu. Linksys routers offer WEP and WPA encryption. WPA encryption allows you to use a single password to access the network. WEP encryption creates 10- or 26-character keys that act as your password. Some of your wireless devices may only utilize a certain type of encryption. Determine which protocol is best for your network.
  • 4
    Enter a password that will be required to access the network. For WPA encryption, you can write your own password. For WEP encryption, click the "Generate" button to create passwords that can be used to access the network. Write down your passwords and keep them in a secure location.
  • 5
    Click "Save Settings" to confirm your changes. Your network will now be secured and will require a password for access.
  • 6
    Click the "Administration" tab to create a password to access the router configuration page itself. Be sure to change the password from the default "admin." Reenter the password for confirmation in the next field. Click "Save Settings" to confirm your new password.
  • Feb 16, 2011 | Linksys Wireless-G WRT54G Router
    I cn not find my wep code
    Hi bobraywhite,
    Try to locate the wep code underneath the router. If you cant find it I suggest trying the following steps:
    1. Use the Internet Explorer browser.
    2. Type the following IP address in your address bar: 192.168.1.1 , you will get a login window. Your user name can be blank and the password is admin. If you have trouble logging in use the user name: admin, and the password is: password.
    3. Click on "wireless" then "wireless settings" or "wireless security." Toward the bottom of the screen look for "Security Encryption (WEP) key," if you see more than one WEP key use the first one listed.
    Hope it helps.
    Thanks for using FixYa
    Bestregards,
    Reyjoshua07
    Jan 25, 2011 | Computers & Internet
    I need to secure my network and lock my router
    Plug a cord from your router to your computer. Open up Internet Explorer. In the address field, type 192.168.1.1 a box will pop up asking for a user name and password. For user name enter admin for password, leave blank. If this doesnt work enter password You are now into your router. Navigate to "Wireless" fro here you can turn on the WEP encryption or any other encryption offered. Once in the router, you may change any settings including the user name and password. Hope this helps.
    Jan 12, 2011 | Linksys Wireless-G WRT54G Router
    How do i set up a password for the router?
    access following link
    http://192.168.1.1
    or
    http://192.168.0.1
    then type user name as "admin" and password as "admin" or blank or "password"
    then set your internet as WEP then enter wep 128 bit encryption key like number thensave setings wep encryption key is your password.
    Jul 17, 2009 | Linksys Wireless-G WRT54G Router
    I need my wep number where do i find it:
    Access your router with following link.
    http://192.168.1.1 or
    http://192.168.0.1
    thsese are defaults ip to access it.
    then go to wi fi security encryption and get encryptipn code it is your WEP code.
    Jul 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
    Asking for a password
    I had the password problem with the Phillips DVP-5140. I looked up the user manual on the Phillips website and searched for "password". There is a manufacturer default password of 136900. I entered that number and was then able to play the DVD. The password may be different for other models, but you can find the default in the user manual for your specific model.
    R/
    MO-Help
    Aug 10, 2008 | Philips DVP5140 DVD Player
    Computers & Internet Logo
    24 people viewed this question
    David Payne
    David Payne
