Question about Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator
Top fridge not working at all.
The Top Section of the fridge is not working at all, but the Freezer below is still working just fine.. ??
Not sure if its best to get repaired (it'a about 6yrs old) or just buy a new fridge..??
  • jayno Sep 18, 2008
    thanks for the advise. will get a quote 4 repairs ta..
  • 943 Answers
Hi thanks for the question the problem is the fan motor in the freezer yes have it repaired thanks the appliance doc
Posted on Sep 17, 2008
Freezer not working when its cold in the garage.
Where do you keep the fridge? If you keep it outside then most likely the condensor coils in the freezer may be freezing over and the only way to fix that is to keep it above 40 degrees outside the fridge.
Jan 18, 2017 | Refrigerators
Whirlpool top freezer 18c.ft w/ icemaker: freezer works fine. fridge does not cool below 56 degrees. vacuumed dust from bottom, turned entire unit off and restarted but still not working, in back of
i think you have to check to make sure that
the fan inside the freezer is cycling on.
it will be concealed of course but you should
be able to hear it. i replaced one once with
the same symptoms and that fixed fridge
portion of a 2002 or 3 whirlpool. make sure
to listen closely and not mistake it for the
stronger fan motor which operates in
conjunction with and nearby the compressor.
Feb 05, 2013 | Whirlpool Refrigerators
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Freezer works but fridge not cooling
On this type ice box the cold air for the freshfood section comes from the freezer via a fan motor. For all of it to work propah the freezer must not be crammed full. The air has to circulate or the fresh food section will suffer. So if you have it overloaded where the air cannot get below then Houston we indeed have a problem. If that is fine we want to next check to see if the fan is blowing up in the freezer section. No fan no cold air below. If that is fine we want to make sure the evap coils ain't froze ova by a faulty defrost heater or termination thermostat. If the defrost is all propah AND the fan is fine AND the coils behind the ice box are clean for optimum performance, then look for a clogged defrost drain. Sometimes the drain cloggs and the water pools between freezer and fresh food section. A slab of ice forms effectively blocking any cold air from gettin to the bottom. To cure that yall unplug it and let it all thaw out then clean the defrost drain. If ice is blocking the defrost drain then run a wire down into it from the heater to keep the drain open and party on!
Sep 05, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Older ge refrig, freezer at top leaking water into refrigator compartment below. otherwise its working fine.
Its the defrost problem. The drain hole is clogged and water is leaking in fridge section instead of draining through drain hole.Defrost the unit and check, for defrosting procedure , click the link below and follow the procedure:--- http://technoanswers.blogspot.com/2011/07/ge-refrig-freezer-at-top-leaking-water.html --------- This should help.Thanks.Helpmech.
Jul 08, 2011 | Refrigerators
There is a puddle of water inside the refrigerator, beneath the vegetable bins.
How many items are in your freezer? I had this problem and there was too much in the freezer, not allowing the air to circulate properly in the freezer, thus resulting in freeze up in the top (freezer) and condensation below in refrigerator section. Additionally, I had the refrigerator setting too cold, which accelerated the problem. I had to thaw the drain hole in the freezer section, below the fan, to allow water to leave freezer during defrosting stage. Hope this helps?
Jan 03, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
No Cooling in the Fridge section, freezer is icing
Generally on these models they rely on cold air being pumped fr\om the freezer to the fridge and have a adjusting device to control the flow, you need to locate and check this is free and working properly. Another reason for freezer ice up is a shortage of gas in the unit, this is usually unfixable as the leak can rarely be found as it usually occurs within the cabinet case. Sorry to say it would then be a throw away.
Peter
Jun 03, 2009 | Refrigerators
Top half fridge not cold freezer department fine
I had the same problem; the top fridge compartment was warming up to 14C while the freezer compartment was starting to defrost (frozen stuff was starting to become soft. I took the rear wall off the freezer compartment and found it all iced up. I defrosted it with a blower heater then powered it back up. It all worked fine for a month when the same thing happened. I figured that the defrost cycle wasn't working. I located the defrost timer on the rear right-side of the fridge. I rotated it several times and found that the fridge was turning on and off. I rotated it until the fridge turned off. I waited 5 minutes then stuck my head into the freezer compartment and felt the rear wall at the bottom where he drain is; it felt warm so I guessed the defrost heater element was ok. I ordered a defrost timer and installed it. I haven't had a problem since.
Nov 09, 2008 | Westinghouse Refrigerators
Top Freezer section working Bottom Refrigerator not getting cold
I have a side by side jenn-air refrigerator, the freezer compartment working fine and making ice like it should, however the refrigerator compartmant is not cooling, no cold air is felt, I need advise.
Sep 28, 2008 | LG LRTC19314ST Top Freezer Refrigerator
Freezer is staying cold (below 0), but Fridge won't cool
could need re-gasing but all f/freezer have 2 thermostats 1 for the fridge and 1 for the freezer
Aug 15, 2007 | Kenmore 63074 Top Freezer Refrigerator
Fisher and Paykel E522BRXFD Stainless Steel Bottom Freezer Refrigerator Logo
248 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
