Question about Heartland 3525SS Dual Fuel (Electric and Gas) Kitchen Range
Heartland Metro 36" Range latch won't retract after self-clean
We have a newer model Heartland Range - the latch won't completely retract after self-clean mode. I think there is a very simple solution to this, but I haven't hit upon it yet. We've unhooked it from the power source and turned it back on and set the clock, but it still remains partially extended.
We've turned it on self-clean and waited 10 or so minutes and pressed the "X" button to turn it off, but it still only partially retracts. The door will close, but still has us uneasy. Thanks for any light you can shed on this.
  • boettgerkenn Jan 09, 2009
    I have a similar problem but never turned on the self clean. The hook is just extended.
2 Suggested Answers
KevinWhite
  • 1902 Answers
SOURCE: We own a Heartland Legacy 3620 Dual Fuel range.
Hello & Welcome to FixYa
You are right it is the door latch that is bad and needs replacement, there is no other switch or solenoid. The only other thing that I'll recommend you to check before replacing is the electronic control board though that seems to be fine. Please get back to me if you have any other questions.
Kevin
Posted on Dec 19, 2010
My old Westinghouse range self-clean oven door latch is in the locked position with the door open. The door cannot close with the latch in the way. The clock is making a buzzing sound.
The first question I have for you is, how did the latch even come out in the first place? Normally the latch comes out ONLY when the oven has been set to cleaning mode.
The buzzing noise is probably there because the oven 'thinks' it has completed the cleaning or that the latch is out.
you may have to take the door off the oven and remove the inner cover to see if there is a way to get the latch to retract. Otherwise, call a professional to come take a look at it.
Nov 11, 2017 | Hardware & Accessories
How to self clean hotpoint gas range model number rgb740beh3ct
To self clean that oven REMOVE THE RACKS, slide the door latch from the right to the left,push the self clean button,push the up/down arrows to set the clean time (usual clean time is 4 hours 30 minutes) push start
After the clean is over it may take a additional hour before the door will open if the latch doesn't move back easily to the the right once self clean clean is done do not force it just wait more time
GENE
Oct 10, 2011 | Hotpoint RGB745 Gas Kitchen Range
When trying to use either upper or lower oven, panel flashing "Control Locked." Won't work.
Try this:
ToChangeFactorySetDefaultOptions:
1, Controloptionsmay be changedby se-
LectingtheSetupOptions(0)padandthe
desiredoptionpad.(SeeOptionsbelow.)
2. Currentoptionwillappearin thedisplay.
3. PresstheAUTOSETpadtochangethe
option.
4. PressCANCELpadtosetthe displayed
optionandexittheprogram
The LOCK is option 4 change the OPTION from 4 to 9.
9 is the factory default settings.
This should work. However.... there is the possibility that the unit had performed a self clean function. If you just completed a self clean cycle it can but up to 1 hour AFTER the cycle before you can open the door or use the oven as the range must cool down and cycle a thermostat before it wil work again.
There is also the possibility that the door lock has not completely retracted. If you can get it to start a self clean cycle.... after 1 minute press cancel and the lock should retract. (I know you said won't do anything) I am hoping that after you reset the options from 4 to 9 that you might be able to do this.
Thanks for choosing FixYa,
Kelly
Sep 06, 2011 | Maytag MER6772 Gemini Electric Kitchen...
I HAVE A WHIRLPOOL MODEL NUMBER RF368LXKQ RANGE AND WHEN I TRY THE SELF CLEAN BUTTON I GET F5E1 WHAT IS THE PROBLEM
The F5E1 error codes means that the door light switch OR a switch on the self clean latch has failed. If the oven light comes on and goes off when the door is opened and closed it most likely going to be a switch on the latch thats the problem.
The part numbers are;
DOOR LATCH W10107830
LIGHT SWITCH 3195993
GENE
Aug 28, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
The oven door of my heartland stove does not close tightly any more. Is there an easy fix?
i have a 36 in legacy when you replace the door oven strip do not put it on the bottom
Jan 31, 2011 | Heartland 3525SS Dual Fuel (Electric and...
I have a 36" heartland range and the oven does not work. A few times I have reset the breaker and then it works, although now even that does not work. The gas top works fine ande the digital display unit...
If you had to keep resetting the breaker that means the electric element was shorting, arcing and therefor drawing too much amperage. The reseting of the breaker kept allowing it to spark start. The high voltage would occasionally create its own bridge from the heat expansion to make a connection and work. But the use of the unit under these conditions kept destroying the heating element even more. A few things need to be checked now. The heating coil, and the high voltage wires inside and out. There is no telling where the damage may have traveled now. Hopefully it only killed the heating coil.
Mar 18, 2010 | Heartland Metro 3635RWNG4PR Dual Fuel ...
The cooling fan stays engaged after a cleaning cycle. How can it be turned off as it has been running for 2 days now.
The problem is the oven door latch. Open the oven door and you'll see the latch on the left front. When it's to the right, the readout will read "SC" for self cleaning. When pushed back left, the fan stops. Apparently the latch does not return to the off position after SC. Snap it back a few times and it may stay off. If not, you'll have to fix it.
Dec 06, 2009 | Heartland 3525SS Dual Fuel (Electric and...
The door lock for self cleaning is in the lock position with the door open. i tryed to cancel it but would not. an F3 message came up when i pushed clean. is there a way to reset the system.
Unplug the unit or flip the breaker switch (easier). After about 30 seconds, the latch will retract, allowing the door to close. Re-start the self-cleaning process.
Aug 23, 2008 | Frigidaire Gallery GLEFM397DS Electric...
Heartland 3525SS Dual Fuel (Electric and Gas) Kitchen Range Logo
225 people viewed this question
Top Heartland Kitchen Ranges Experts
Dan Webster
Dan Webster
Jim Goldsmith
Jim Goldsmith
Are you a Heartland Kitchen Range Expert? Answer questions, earn points and help others
