Question about Garmin GPS
Fuse blue in the car adapter and at the same time garmin 300 nuvi went dead and wont start up with either car power or battery power.
    Scholar:
  • 147 Answers
Blue fuses are usually 5 amps.
Red ones, 10.
Yellow, 20.
The fuse inside a cigarette adapter is usually a 1A, buss fuse - available from Radio Shack or "The Source By Circuit City".
If your blue fuse blew, then visit your nearest department store, and purchase a new fuse. Buy a box of 5 or so just in case.
Posted on Sep 17, 2008
How do I turn on my Garmin Nuvi?
Go to Garmin and download and install Garmin Express, Plug your GPS into your PC. The GPS should power on and Garmin Express should identify it and tell you of any updates. If the GPS does not power on (it should go into usb mode), then contact Garmin for warranty work. You can also check the power adapter in your vehicle. If the red light does not come on, the adapter either has a blown fuse or went bad, causing your GPS battery to be discharged. It is quite possible that your battery is discharged. You might leave it plugged into your PC overnight if the battery is dead.
Mar 28, 2017 | Garmin nuvi GPS
Will not stay on when not plugged into the car outlet?
first make sure that the device is indicating that the battery is being charged or that the battery is fully charged. this is indicated on the menu screen by the battery icon as being 4 bars of full green color.
if the unit will not charge in your vehicle, you might need to replace the fuse that is located at the tip of the vehicle adapter.
1. to change the fuse unscrew the black, round end piece on the vehicle power adapter and remove it. inspect the fuse to see if it is blown. If not end here.
2. if determined the fuse is blown remove the fuse (glass and silver cylinder), and replace it with a 1A fast blow fuse.
3.ensure that the silver tip is placed in the black end piece. screw on the black end piece
if the fuse isn't blown and the unit still wont charge you may have received a usb cable with your Garmin Nuvi. If you didnt recieve one any mini usb cable should do. On this model you can connect the Nuvi to a computer using a usb cable. And see if you can charge your unit through this method. *Note* that the computer must be on for the unit to be able to be charged.
If you can charge your Nuvi unit on the computer then you may have something wrong with your cars adapter. I doubt this is the problem however if the unit is able to be turned on.
If you cannot charge the unit via a car adapter (with working fuse) or a USB cable. The most likely problem is the battery is no longer accepting a charge. On the listed unit a Garmin Nuvi 265 the battery is not user replaceable. So you would have to contact Garmin to get the battery changed or see if there is a local battery store that is able to change a battery on this model unit.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please rate the comment. thanks and have a great day.
Aug 20, 2010 | Garmin nuvi 265 Car GPS Receiver
I battery went dead. I have pluged it into my computer . It lights up and shows a picture of it attached to the computer and the word Garmin but it does not show it chargeing.
Please leave it to charge and after about 2 hours - check it.
The Garmins need an initial charge to run - it is not bypassed if dead. It will not run on adapter power.
If it will not charge in vehicle or home - the jack may be loose from the board - but more likely the battery has failed.
Garmin DOES repair for a flat fee - units that are OUT OF 1 year WARRNATY CLICK HERE.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Garmin nuvi 265 Car GPS Receiver
My garmin 1300 went completly dead while on a route with the power cord attached. Unpluged tried again . Now its working. Is this normal?
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 15, 2010 | Garmin nuvi 1300 Car GPS Receiver
Gps nuvi 250 wont charge, shuts off in a
It will shut off right away if the batteries are not charged.
Why doesn't it charge?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Oct 17, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Has been working fine..now will not turn on.
It sounds like a dead battery?
When it is plugged into the car, you should see a charging symbol, or it will say charging if the screen is off.
Are you sure it is getting power from the car? Check the fuse for the lighter socket, also the power cord has a fuse in the end that goes into the cigarette lighter socket, if you twist the end of the adapter it should open and expose a fuse.
Check these fuses to be sure.
Hope this helps.
Apr 17, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi will not switch on
If you are using the cigarette light adapter plug-in, you probaly blown a fuse in the plug.
Unscrew the silver / or black tip of plug.... carefully its spring loaded.... check fuse
Mar 26, 2009 | Garmin NUVI 710 Car GPS Receiver
Nuvi 350 wont charge with car adaptor. But charges with ac charger in usb port of Nuvi. Any thoughts? I have another Nuvi 350 that does charge with this ones car adaptor.
Are you using the same port on the Nuvi to connect the car adapter and the ac charger, or two different ones? If not, then the jack could be broken (solder joint, pin?).
Aug 10, 2008 | Garmin Nuvi 350 Car GPS Receiver
Gqrmin 350 GPS Receiver wont turn on
Dead Battery? That makes no sense at all. He mentioned he was running it off the battery - " I was able to plug it in to a computer1.gif and unplug and was able to use it on the battery. Once I unplug and use it on battery, the only way I can power it off is by pressing the Reset button on the back."
The fact of the matter is that there is a well known issue with Nuvi 350 Power switch. I haven't taken mine apart yet (also bad power switch), but most likely the switch is defective or the solder joints are broken.
Sep 23, 2007 | Garmin nuvi 350 GPS Receiver
C340
I had the same problem recently... What I did was open the front casing and hit the reset button under the cover, then it turned on while plugged into the car adapter.
Dec 29, 2006 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
110 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
