Question about RCA HD56W58 56" TV
Screen adjustments?? My TV seems to need to be adjusted. At first I noticed the "ticker" at the bottom of the screen was too low. I did nothing to the TV to make adjustments, but now the picture is too high?? Cut off heads but I can see the ticker for sur!! Any suggestions on how to make the screen adjustments??
On the remote, if you use the right and left keys on the pad with the OK sign in the middle, it will adjust the screen to several sizes including Cinema, 16:9, 4:3, Zoom, etc. I, personally, use 16:9 because I, like you, need to see the ticker symbols at the bottom. I hope this helps.
Posted on Oct 06, 2008
How do I adjust the screen to the TV - I've looked in the MENU options and can not adjust the height of the screen. In other words - I can not read the score ticker on the bottom of the screen
Your sanyo tv may have service mode adjustments. It can be taken according to the sevice code options, which can be get from service journals available in the market. no menu adustment is there to adjust the picure linearity, height , subbrightness control so on. All adjustments are coded and have critical measurements which can be adjusted through service mode with the help of remote control. The remote control should be orginal to access service mode. Duplicate may not work properly.
Oct 14, 2010 | Sanyo DS24425 24" TV
Screen Resolution Problems with Samsung 50" DLP
You may have already done this, but check to see if you can change the screen size in the set-top-box settings and set this to widescreen 16:9 to match the tv. You may also have 14:9 as an option too. Also, check your video output settings, this can be changed between RGB, Composite, PAL or NTSC.
Let me know if that does or doesn't solve the problem
Dec 22, 2008 | Samsung DLP HL-P5663W 56" TV
Picture is cut off on the bottom of my Hitachi 57F500
Verical position is hard to adjust and is in service menu. A service manual will get you there, but you might get lucky with the vertical size adjustment. If you open the front of the TV, the vertical size is adjusted with a knob on the deflection board. Remove the speaker grille and take off the access panel. You will see two knobs, one horizontal and one vertical. Be careful, those red wires have 30,000 volts on then, don't touch anything but those knobs. If its just an adjustment, the v-size knob will fix. Set it so ESPN ticker is just above the bottom of the screen. *Service mode - the manual tells little but entering is done by "press and hold the input button, press the power button, release both after you hear HV come up" .. the v-pos parameter is in there, but this manual doesn't say where or how to adjust, procede at your own risk. If you get into trouble, pull the power so you don't save any settings. I believe you just navigate through the menus to find the parameter and use arrows to adjust. Enter may save. Sorry the service manual I have tells nothing much.
Dec 07, 2008 | Hitachi 57F500 57" Rear Projection...
Philips 46-inch Rear Projection with bowed image?? slight distortion
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jul 02, 2008 | Philips 46PP9302 46" Rear Projection...
Top And Bottom Of Screen
If you are useing a cable box or satelight rec. Check the format that you have it adjusted to. If not adjuste the format of the tv. If that does not fix it, it will need to be adjusted by a tech.
Mar 21, 2008 | Panasonic TH-50PX60U 50 in. Plasma HDTV
Arch on top and bottom of screen
I read that these sets have a problem with the yokes on tubes sliding down some- there for causing this problem make sure yokes are all the way up on neck of picture tubes,this may fix your problem!
Dec 27, 2007 | Philips 55PW9363 55" Rear Projection...
RCA F27442 27" TV
1) Ask what the part location on the board is = IC301 for example..
2) Provide service #
3) Could be LA7612N
4) If they were not blowing smoke,why didn't they give you a
six digit RCA part # ??
Nov 09, 2007 | RCA 32V420T 32" TV
Wacthing sports -Tickers and scores are off screen in HD
skilled,senior tech needed to access servicer mode and check/adjust geometry/convergence. if unresponsive,then replace convergence and re-check geometry and alignment.
Sep 30, 2007 | Sony KP-51WS510 51" Rear Projection...
News ticker off bottom of screen, how to adjust?
sounds like its stretched out just a bit. Do you feel comfortable with messing around inside where theres 100s of volts??? if you do then in the vert curcuit theres a small control called the vert height control right on the printed curcuit board. adjust it slightly so you can see that full pic but not the black partm of the pic. I WOULD HIGHLY RECOMEND thaT if you have no experience with this then leave it to a pro as afterv all they will charge you a minumum beanch charge to adjust the set for you Im sure as it is a minor thing to do. good Luck
May 02, 2006 | JVC AV-30W475 30" TV
RCA HD56W58 56" TV Logo
230 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
