I have a simpletech 500 g external drive. I just had my main computer crash and I have hooked the drive up to my laptop to see what I can recover. My old laptop circa 2003 - won't read Resource CD so ....I have gone to auto recovery and restored folders but when I open them they are empty? Am I doing osmething worng? Maybe I didn't back up my stuff but it shows on the simple hard drive that I have 18,000 files and I only have 150 G left on the drivfe - so where are my files? Help
Please contact SimpleTech's Technical Support department and they will be able to assist you with your backup and restore issues. They can be reached at 949-477-7700 or 800-945-3444.
Regards,
SimpleTech Technical Support
Posted on Sep 19, 2008
My new Laptop with Windows 10 operating system does not recognize my older simpletech 250gb pininfurnina external hard drive. I'm not sure what driver I need to get it to recognize the hard drive.
Try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this file recovery program called asoftech data recovery to recover your files. download it from
http://download.cnet.com/Asoftech-Data-Recovery/3000-2248_4-75328850.html
Sep 07, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
Six month old Simpletech 500 GB ext. drive not recognized
I had the exact same problem. Solved by removing Simpletech drive from the 'flashy-box'. Unplugged drive from internals and threw the 'Pinnaferrina' case away and installed it on my motherboards extra sata plugin site (if it has one). If you open your computer case it should be labled on the Motherboeard as such. Mine has four. On the first attempt when I started the computer i Had no OS system showing on first boot-up. Shut off computer and power and shifted SATA (RED Cable) to another Sata plug on Motherboard and it booted right up and I had the drive back. You will need a longer Sata cable than the attached to the Simpletech drive and a power cable that matches the one on the Simletech . Forget looking for the drivers on the net and the Simpletech web site was no use.
Oct 10, 2009 | SimpleTech 500GB SIMPLEDRIVE EXT HD-USB...
SimpleTech 500 GB external hard blinking red light
I got one with the same problem. I opened up the case and hooked up the hard drive to a generic usb to sata adapter that i picked up on ebay and it works fine now if a bit clunky looking.
Sep 10, 2009 | SimpleTech 500GB SimpleDrive Pro External...
Hard drive crashed
Yes any data recovery place will be able to astract whatever was written on that disk as long as it has not taking a serious fall you can get your data recovered under $15 a GIG so yes take it in if it is that important to you.
May 14, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 500 GB external hard drive - unresponsive
If you really can not get it to work anymore, you could try opening it up and connecting the hdd directly on a IDE/SATA port in your computer. This will only work if you have a desktop, for a laptop you would need all kinds of converters.
May 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 500 gb external hard drive
There is a power consumption work-around untill a Y usb wire can be purchased; the main power cable must still be used at all times but this workaround should only remain temporary!!!
Simpletech should have included this so laptop users could use the drive as their capacity is better than the packaged slimmer simpletech portable backup drives for laptops, which does include the Y cable....
1) unplug usb while powered and unknown hardware is present on laptop...
2) turn power switch off from the external HDD...
3) return power switch to on from the external HDD...
4) plug in usb connection to laptop...
Autoplay should read from external HDD!!!
**** Save some $$$ and buy a Y shaped cable to provide sufficient amount of power from laptop usb
ports, cause it's necessary to use 2 of your ports to provide power in addition to the main power from HDD to wall****
ADONIS
Sep 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
