My RCA M61WH74S does not show a picture and light on the tv blinks off and on
  • 4 more comments
  • alexkocs Oct 18, 2008
    I have the same problem, only I replaced the lamp and it still has no picture. The power light blinks occasionally as it did before the lamp replacement.This, according to the manual was an indication that the lamp was faulty. Apparantly that's not all that is faulty. Does anyone have any ideas?
  • bart2VP Nov 26, 2008
    I have the same problem...can someone help me out!!!
  • dustinc469 Nov 28, 2008
    I have the same exact problem with my tv also. I myself had also replaced the whole lamp assembly as the owners manual and RCA customer support told mr to do and still has the same problem. Its getting ridiculous let me know if you found out anything.
  • ljones012 Dec 28, 2008
    RCA M61WH74S , my tv made a pop sound and went blank the sound still plays and the blue light flashes.
  • Anonymous Apr 07, 2009
    same fuvking problem
  • ryanmoroz Apr 22, 2009
    I have kind of the issue. My TV turns on and then about 45 minutes later it turns off and wont turn on again. I took the back off and held the voltage regulator to 98v and it stayed on for another 1 hour. I can keep my TV going for as long as I want as long as I have the back off and a house fan blowing on the back of it. Not sure 100% what is wrong with it but I will have to try re-seating the lamp..... by the way try re-seating the lamp.... sometimes that is all it takes. Also if you take off the screen in the front and clean the front of the bulb that can help as well.
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
  • 18 Answers
SOURCE: TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
SOURCE: I have a rca model
the projection lamp is likely burned out
Posted on Dec 10, 2010
SOURCE: Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Posted on Feb 14, 2011
Slinteriors
  • 8617 Answers
SOURCE: have arca tv dlp
5 blinks is indicating the lamp or ballast has an issue.
Posted on Feb 18, 2011
Audio but no picture. New bulb is not blown
Video board problem. Find honest TV Tech.
Oct 28, 2013 | RCA M61WH74S
RCA D52W26 TV Powers on and has sound. It has no picture.
If this is an LCD TV, show a torch light on the screen from a safe distance. If you can see the picture, the back light is not getting on. You may have to call in a qualified service technician.
Aug 02, 2012 | RCA Televison & Video
I have rca m61wh74s...power light blink and it won't turn on
Replace the deflection board the ITC222A deflection board is available from www.tvrepairworld.com
Aug 10, 2011 | RCA Televison & Video
Hello, I have a RCA 61" M61WH74S rear projection
I am not sure which fan you are putting back as there are a couple. I am attaching 2 pics that show the fan locations. You may want to get the service manual for your model which shows the dissassembly proceedures. You can get it on page 2 of the service manual catagory from www.tvrepairworld.com by download within minutes of ordering service manuals are indispensable when serviceing a Television.
Jun 14, 2011 | RCA Televison & Video
My RCA 52 blinking power light, no picutre
Flyback transfromer is defective and needs to be replaced.
Oct 12, 2009 | RCA HD52W56 52" Rear Projection HDTV
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
TV WON'T COME ON
All the reports are showing the same problem the TV is in shutdown mode.
Something is wrong and it is refusing to start it makes a chirping or clicking sound. Solution is that it needs to be repaired nothing you can do unless you want to try replacing the motherboard yourself.
Dec 05, 2007 | RCA 24V511T 24" TV
Televison & Video Logo
618 people viewed this question
Top Televison & Video Experts
