Question about Microsoft Excel for PC
Won't recalculate automatically
When entering a number into a given range of cells and hitting the enter button, it won't automatically recalculate the new number. the only way to see the new number is by hitting the save button, and the same thing happens when you delete a number in that range. the new total will not show until you hit the save button........very weird and frustrating!!! help, suggestions??? thanks
  • moneymender May 11, 2010
    What version of Excel are you using?
  • hr4u May 11, 2010
    how can possible of data storing power
Posted on Sep 21, 2008
Dell mini 10 with corrupt config\system
Boot from the CD.
When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R
Once you are at the Recovery Console you will be given at least one choice of Windows installations. Normally the choice you want is the number 1 choice. Click the number 1 key at the "top" of the keyboard and click enter.
NOTE: at this point your numbers to the right of your keyboard are turned off. If you insist on using these keys for your numbers remember to hit the Numbers Lock key before clicking a number over there or your computer will automatically reboot and you will have to wait through the previous steps to get back to the console.
You will be given a message asking for the administrator password. Unless someone or something has messed with your computer there is no password so you just click the Enter key.
This will bring you to a prompt that says:
cd \
Press Enter
Note: between "cd" and "\" there should be a "blank space" otherwise the command won't work
The prompt should now say:
cd system~1\_resto~1
Press Enter.
If you don't have Windows CD...
Download Windows Recovery Console:
Download, and install free Imgburn:
Using Imgburn, burn rc.iso to a CD.
Boot to the CD...let it finish loading.
When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
Nov 09, 2011 | Dell Inspiron Mini 10 Notebook
In Excel adding positive and negative numbers
  1. Select the column. (click on top of the column it will select)
  2. Right Click and select Format Cells.
  3. Select Currency in Category then press OK
b6298df.gif Now just type your Numbers i.e. 571 for $571 and -650 for -$650 and sum using the normal way.
That is Select the Cells which you want to SUM and Press Alt+=
This will bring the total just below the selected cells.
Apr 02, 2008 | Computers & Internet
Test Mode Information for tdMA models
Enter <b>*3001#12345#</b> and select <i>Field Test</i> (menu option 9 on a 6160), followed by one of three options: <i>Enabled</i>, <i>Enabled+lights</i>, or <i>Disabled</i>. Once selected you must power down the phone and power it up again. To get out of test mode re-enter <b>*3001#12345#</b>, <i>Field Test</i>, <i>Disabled</i> and then power down the phone. Once you power up the phone you may automatically enter field test mode, screen 01 AND/OR you are given a new menu choice of Field Test.<br /> To turn on field test mode select the menu option of Field Test and enter a number between 1 and 7. To turn off field test mode enter number '0'. There are a total of 7 different test mode screens on tdMA models and they may vary somewhat between the different Nokia models. Use the arrow buttons to move between field test screens.
on Jun 19, 2011 | Cell Phones
I have entered several calculations onto my ti-84 plus. I want to know how to scroll up through my previous entries. Thank you.
To get back to the previous entries, you can hit the 2nd button then hit enter. Continue to do this and you will get to the entries before that.
May 02, 2011 | Texas Instruments TI-84 Plus Calculator
I have sagem my101X mobile but when ever i on it it shows sim locked and asks to enter unlock code what should i do?
If you enter wrong password for more then 5 times,it ll ask you to enter the puk call your customer care and
get the puk number...enter the puk number in the space given for password....thats it...problem is fixed
If you had locked your mobile then update the formware all saved passwords will be deleted.
nothing plays disc 2.finalised.3.right region code and matching dvd, infront of your manual says discs won`t play.
mobile passcodes
If you forgot you can generate master code using your IMEI, which can be viewed by pressing *#06# and keying that in the link mentioned below,,
Hope that helps
Nov 20, 2009 | Nokia 6233 Cellular Phone
How do i search for an unlisted code for my universal remote?
This is the web site where I found the codes for mine,
Hope this helps, if not, let me knoe the model # and I can assist further...
Sep 17, 2009 | Philips Universal PH301S Remote Control
Unlock code for LG cell model cu720
On the AT&T Network, to unlock the LG Shine or CU720, it’s pretty simple:
  • Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM
  • Enter *#865625# then the 16 digit unlock code*
  • Device should say: Network Lock Deactivated
  • Phone may automatically reboot
*The 16 digit code can be obtained by calling AT&T Technical Support and given the representative the IMEI number. In exchange they will give you the Subsidy Unlock Code.
To obtain the IMEI number, type *#06# on your device. This is a 17 digit number and it is not the same as the unlock code, this is the IMEI number to give to AT&T Technical Support in exchange for the 16 digit Subsidy Unlock Code.
to get the (16 digits code) call att and tell them you are traveling overseas, it may take two calls.
,but they should give it to you the (16 digits code)
Insert non ATT SIM
Power up
Showing 'Invalid Smart Chip'
Enter *#865625#
This will take you to a screen saying you are about to unlock your phone. Do you want to proceed.
Select yes (left button)
Enter your 16digits code.
Hit OK
Enter your code again
Hit OK.
Now the phone is unlocked
It requires 2 inputs of the unlock code.
If this helps solve your problem please give a fixya rating, all of them are really appreciated, sorry I cant personally tell you the code number, but ATT or your Service provider should, if all else fails, here's an online service.
May 27, 2009 | Cell Phones
Spreadsheet formulaes
1. enter = symbol
2. enter ( symbol
2. enter cell location where your cost value is
3. enter * symbol
4. enter 0.7
5. enter ) symbol
6. enter 0.175
eg. =(A3*0.7)*0.175 where A3 is the cell location where your cost amount is
Oct 08, 2008 | Microsoft Windows XP Home Edition
Select the cell or group of cells --> Format --> Cells
Apr 17, 2008 | Computers & Internet
Motorola Raz KM1 fire
Usually the voicemail number is set automatically by the service provider so that the general user wont have to. Sorry but I do not think you'll be able to, but I will keep my eyes open for a unlock code for it. Hope this helps!
Sep 11, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Open Questions:
See all Microsoft Excel for PC Questions
Microsoft Excel for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
