Question about Candy Washing Machines
CANDY GO1482 WONT GO!
Hi
My Candy washing machine has stopped working, I select the wash does not matter which, press the start button. The washing machine begins to fill then stops and wont go into the spin cycle a couple of times the 90minute wash light & the stain vanish light flashes when it decides to stop working. Help
Cheers
Adam
  • DeanZak Feb 16, 2009
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: My Candy washing machine has
It appears your timer has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
Candy washing machine gc4 2d washes for about 15" then stops for 30" (the screen goes black) then on again for about 10" and then stops again.
sounds like overload protection is disabling the machine. it could be caused by a lot of reasons, the only advice I have is to check for a jammed drum, empty machine and see if drum turns freely. best luck to you.
Dec 06, 2014 | Hoover Genuine Candy Zerowatt Washing...
Candy go1482
please follow this steps for problem spinning.God bless you
  • Is the belt broken? Loose?
  • Does the lid switch click when closing?
  • Does the spin solenoid engage?
  • drive coupling worn out? (on some newer Whirlpool & Kenmore top loaders)
  • clutch worn out?
  • Current to motor? (Use voltmeter to check)
May 28, 2013 | Washing Machines
No power on washing machine (candy go1482) it blew the house trip then since then wont turn on ive tried an extension lead and still does not work
Sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Aug 10, 2011 | Washing Machines
How do the drum caseing come apart to change bearing on my candy go1482 washing machine
Candy GO1482 model is made by Hoover and the drum is welded shut. You can't replace the bearings (cost usually 10 GBP) and a replacement is 220 GBP plus vat. I've just been bitten and hurt badly over it. Next time buy Indesit, Hotpoint or Bosch.
Candy GrandO 8kg Erratic Cycle Selection and Flashing Lights
I can't solve this problem but have exactly same problem with erratic lights. I 'm starting to worry about possible explosion.
Mar 12, 2010 | Candy Washing Machines
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
My Candy washing machine has stopped working, I select the wash does not matter which, press the start button. The washing machine begins to fill then stops and wont go into the spin cycle a couple of...
Feb 16, 2009 | Washing Machines
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines Logo
106 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
