Question about Makita 3612C Router
Powerless Router unused for 1 year in storage. In an attempt to use this machine again, nothing appear to happen, just dead. Checked fuse and connection, seemed ok. What are the possible causes, if I may inquire. Thank you. yeoh
  • Anonymous Mar 03, 2009
    I have the same problem with Hitachi M12V. The repair depot tells me that the electronic control has to be used regularly or it simply quits. This means, not only does the router have to used, but has to be used at different speeds. Hard to do for a hobby type woodwork.
  • 2,176 Answers
I would first use compressed air and thoroughly blow thru the vents. Second I would take out the brushes they have a black cap over them and after removing wipe them off with a clean rag and reinstall. Look at the cord for cracks in outer jacket. Plug in and try again. If this doesn't work UNPLUG tool and turn collet nut by hand and connect again and retry. That is about the only things you can do safely. When storing sometimes dust and debris gets inside tool and can make the brushes loose contact with the armature
Posted on Dec 25, 2008
Pe-770 sat unused over a year. Does nothing whe plugged in.
Sometimes after a long period of storage, machines are slow to come back to life. Leave it plugged in and see if it revives.
Nov 08, 2017 | Sewing Machines
Dell latitude 610 AC adapter issue or battery pack issue or both?
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Dec 21, 2007 | Twinhead SlimNote N12PI Notebook PC
Power won't come on
hi, i take it you've checked the fuse in the plug, there's usually a glass fuse inside the washer power supply not sure where the circuit board is located in your machine but they usually sit at the bottom of the machine if it has blown make sure you put the same rated fuse back in. if blows again the there's a dead short somewhere hope it helps
regards
shaun
Nov 19, 2011 | Washing Machines
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
I have a roper (whirlpool) top load washer (model # ras7133kq1) that only had less than 1 year of use and was in storage for 2 years. It had been working perfectly when it was put in storage. I installed...
When ever you are keeping the machine ideal for two years the machine may get rusted because once you start using the machine the dust will started to deposit at the bottom of the drum.
you may put some oil or grease over the mechanism and check even after doing that also if you find the same problem means you have change the inner bearings
Jan 19, 2010 | Whirlpool Washing Machines
Calypso washing maching appears dead. Power is
Its your control board most likely.Im sorry these machines were full of gremlins.service techs hate to work on them thats why its so much to fix them.sorry.
Nov 15, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Appears dead (after being transported)
Washing machines have a cut-off switch that is activated by lifting the lid on the clothes compartment. Possible that the wires are to the terminals of this switch.
Take the top of the machine loose again and check to make sure this switch is connected.
This is where the power goes before it goes into the rest of the mechanism so it can appear dead.
May 08, 2009 | Washing Machines
Router will not power up
I wrote a long response to your question, which apparantly has been lost in the web somewhere.
Try to make sure the detachable power cord is properly connected, and twisted 1/4 turn clockwise to lock in place.
Make sure the toggle switch is working freely.
Make sure the collet lock or spindle lock is not engaged.
If that doesn't help, please write back and I'll try to re write a troubleshooting guide for you.
I can't believe it didn't post properly.
Anyway, good luck!
Mar 21, 2009 | Dewalt DW616m 1 3/4 Maximum Motor HP...
No power running to SERVIS washing machine
Try disconnecting the heater element first and see what happens if still same unplug motor and try again, it is a process of elimination.
Plz rate solution.
Thanks.
Dec 14, 2008 | GE WPXH214A Front Load Washer
Makita 3612C Router Logo
215 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
