Question about Philips 23PF5320 23 in. HD-Ready LCD Television
No color I have tried a PS2 and a DVD player on this tv and all I get are black and white images.
4 Suggested Answers
maatmartin7
  • 1213 Answers
SOURCE: my plasma, lcd tv only shows in black and white
Would you say say the color is intermittent, sometimes black and white an occasionally flashes streaks of color? The small signal board may be at fault. You can ask to have the board replaced or fix it at the component level. Parts for the board at component level could be PN#823827736071 location 1H00, this is i beleive a color crystal, and two capacitors , PN#223886975478, location #s are 2H08 and 2H09. This repair is very prettymuch the repair you will need. Theses are surface mount parts and will require a tech to do. Hope this will give you a good start for repair!!!!!
Posted on Oct 19, 2009
  • 1335 Answers
SOURCE: inherited a flat screen tv without remote. cannot
You need to invest in a univeral controller. You can either order one onlne or go to a local store and purchase one. The controller instructions will give you the correct codes to access your TV controls. I don't understand your comment about black and white on the DVD player. Are you having problems hooking up the DVD to the TV? Most problems will be cleared up after you get a remote. If you need a user manual for the TV let me know the model number and we can find the correct source. Thanks.
Posted on Jan 02, 2010
  • 27 Answers
SOURCE: Color image is coming out black and white
does it happen on the any input or just on tv setting?
if it's judt tv then sounds like the tuner, if it's on any input, then the video chip or a decoder on that board.
Posted on Apr 09, 2010
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
Toshiba 50L2200u no color
I'm having the same exact problem. I bought a Toshiba L2200U 50 inch and it works great with cable, but the DVD player only works in black and white. I've tried different DVD players and cables, but still no luck. Did you find a solution?
Dec 27, 2012 | Televison & Video
When playing DVD on panasonic plasma TV, the color is black and white
Consult the owner manual for the player (and or try it on another set) as many players have settings that can cause B&W or a single color display for the image.
Dec 02, 2012 | Panasonic Viera 50" Class 1080p Full HD 3D...
Components are in black and white instead of color
Wrong connection. Hook up the component output from DVD player or Wii to TV component input using component cable(red, green and blue plug)
Dec 29, 2009 | LG Televison & Video
Why is my playstation 2 in black and white? I have changed av cables, different video inputs, also swapped dvd player with ps2 video inputs. The dvd player is still in color? is there something with the...
For me it sounds like the TV treats the incomming signal as a SVHS signal. I have had the same problem with a SEGA dreamcast back in the days. In my case it was a quite simple setting in one of the TV menus.
Try different video inputs. (and SCART adapters) This is also is a important step. Some older TV's doesn't have SVHS support at some of the SCART inputs, and in your case that will be a good thing.
But as you said, you maybe already have tried this.
Don't know if this was any help for you but i wish you good luck!
(Because PS2 is still really fun playing)
Oct 10, 2009 | Sony PlayStation 2 (PS2) Console
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Recently bought a Sony Bravia 20KDLS4000. Sony DVD player DVD-NS575P was compatible with 3 year old Sony TV but with Bravia, the DVD image is in Black and White. TV gets color fine. Thanks for your...
Try to set your video output settings on your dvd player . I assume you used to connect to your old tv by using svideo and now you are using another connection like component, scart or hdmi.If the video output setttings on your dvd are still on svideo you will have to set it to rgb or component or else you will get black and white images..
Sep 29, 2008 | Televison & Video
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
DVD and PS2 in Black and White
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Jan 20, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Screen B&W only: Same as other poster
Screen works you get a black and white image. The colour stage works you get colour output to TV So my guess is the ribbon connector from motherboard to screen is loose or adrift. Is this something you fell you can fix or 'know a man that can?'
Aug 19, 2007 | Durabrand PDV-705 Portable DVD Player
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
