Question about HP PSC 1410 All-In-One InkJet Printer
Slow printing for some reason my printer has gone on a 'slow go' and it takes ages to print a document even longer when colour is required...can you suggesta solution as it hasn't always been like this. thanks.
My printer cd is lost I have installed driver please suggest me
Posted on Oct 25, 2008
Extremely slow printing
The printer is an inkjet printer. Inkjet printers are slow printers compared to laser printers.
Also the print speed depends on the size of the document printed.
If it is a large photo or file, it will take longer than small notepad file.
Speed also depends on coverage. A page with a lot of it covered in ink, will take longer than a page which is only coverd in ink on a small part.
Also the print speed depends on computer memory and USB cable. Fast cable and a lot of memory mean fast transmission of data to the printer.
Slow cable and small amount of memory (512Mb, or 256Mb or less) mean slow transmission of data to printer
Sep 17, 2010 | HP Deskjet D4260 Printer
Print slow
Ink jets print slower than other printers. I have used many printers and found that if your documents are black and white only the print is faster. The font also makes a difference. if the font is fancy it takes longer for the printer to translate.
Apr 25, 2010 | Brother MFC 420CN All-In-One InkJet...
Epson sx200 printer, wont print black ink only
Many printers especially Photo ones also use colour even when printing Black. so you do need to replace the spent colour cartridge.
If you only need to print in black get a B&W printer not a colour one.
Jan 01, 2010 | Epson Office Equipment & Supplies
My samsung monochrome laser mfp printer has colour ink in it and it will not print anything in colour. My comp is windows 7. It will only print black and white and I want to print a coloured document....
The printer you have got is a monochrome printer i.e. it can only print in black. If you require colored outputs you would require to go in for colored printer.
Thank you,
Have a good day.
Nov 25, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Rx 620 slow to print
Epson's RX620 scans and prints photos at high quality. Text, however, was slow to print and not that good.
it_portal_pic_41791_t.jpg Epson's multifunction devices fall into two categories: general-purpose models that are designed for home or small office use, and photo-oriented devices such as this, aimed more at the enthusiastic amateur snapper.
Because it's a photography-centred device, the RX620 uses dye inks. On photo paper, these produce more vibrant colours than pigment-based inks, and a true gloss finish, but on plain paper produce inferior, less vivid results.
The Stylus Photo RX620 is quite large, and looks dated - but it's not short of modern photo-printing features. Its built-in memory card reader is compatible with seven commonly used digital memory formats, including xD and SmartMedia. Photographers using film will appreciate the scanner, with its high optical resolution and transparency backlight.
On plain paper the RX620's text printing showed bandingand rough outlines on default settings. Our five-page black-and-white text document took two and a half minutes to print. Increasing quality settings made it even slower.
We tried realigning the print heads to improve print quality. The RX620's manual process involves choosing the best-aligned examples from four rows of 15 patterns. This takes good eyesight, and it can be hard to choose between similar-looking options. We needn't have bothered - text remained unchanged.
Photo printing was far better. The RX620 produced some of the best prints we've seen from a multifunction device, but only at its highest quality - and slow - setting. Our A4 test picture took 15 minutes 12 seconds to appear.
The RX620's scanner is excellent, previewing an A4 sheet in six seconds and scanning a 6x4in photo at 600 dots per inch (dpi) in just 14.5 seconds. Negative scan times were reasonable, with a single frame scanned at 2,400dpi in 1 minute 40 seconds.
The RX620 can perform many advanced functions without being attached to a computer, and its colour screen has a clear menu system. Prints can be made directly from memory cards, photo prints or even film. There are four document copying settings, but results using the default Text quality are adequate for most office purposes.
The RX620 isn't a brilliant multifunction device. It does many things well, but its printer is too slow, and simply not good enough on plain paper.
Please rate my solution after reading it. Thank you
Feb 27, 2009 | Epson RX620 All-In-One InkJet Photo...
Very, very slow printing
I don't know the make/model of the printer, but I can mention a few possibilities.
1) If your printer is set for PostScript (PS) language, versus PCL , it normally takes longer to print.
2) If this printer is fairly new, check for old Printers installed that are no longer connected to the computer/network. See if there are still print jobs in the queues. A missing printer with jobs still in queue will keep polling the system and eating up processing time.
3) If this printer is a laser printer, it may have to wake-up and warm-up before printing.
Nov 23, 2008 | Acer Aspire 5100-3357 Notebook
No colour printing
The problem with Canon printers sometimes is that, if you do not use original cartridges and put compatible ones, the printer will not recognise them. Even if you refill the originl ones the printer will still think that they are empty due to the microchip that every cartridge has. Try using original inks. If you already used original inks, then another reason might that the ink tubes have benn blocked because of dried ink if you haven't used your printer for a long time. Try performing a deep clean through the printer application.
Hope that helps
Apr 20, 2008 | Canon i80 InkJet Printer
The HP laserJet Colour printer
I have reduced the size of the mega pixals on the digital camera before taking photo graphs this appears to have fixed most of the problem.
Apr 05, 2008 | Office Equipment & Supplies
Not print and not scann without colour cartridge
most printer require all cartridge to be present and recognised before they will operate- even though you only wish to print -say- text in black. When printing in most machines all colours print even if it is only text you want. Except some machine can have a black only mode This will be found in the properties menu, if your machine has the facility
Jun 06, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP PSC 1410 All-In-One InkJet Printer Logo
109 people viewed this question
Seeker5211
Seeker5211
