Question about LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive
Laptop Hi I done format for my laptop, everything seems okay except when I start it, it takes over 5 minutes, I do not what is wrong with it. I am using Windows XP Pro my laptop Dell D600 I highly appreciate your advice Khaled
  • kld_hn Sep 18, 2008
    Hello
    I did that and now much better, but still taking up to 3 minutes until final boot successfully into Windows.
    Any more advices may it will be help to reduce the booting time
    Thanks
  • 43 Answers
Hi, It appears that the your computer taking some time to login to windows. I suggest that when the computer finally booted successfully into Windows, you need to disable all the startup items under the system configuration.
Just type in "msconfig" under the "Run" screen and hit the enter key or click OK. Please click on the Startup tab then click on "Disable All" then hit "Apply" and "OK". You need to restart the computer to so that the settings will be updated.
Hope this helps!!!
Thanks
Posted on Sep 18, 2008
Formatting Fujitsu HDD
certainly not.it is abnormal to take 20 hours which can be done in simply 5 minutes if you format it using Linux or just zero-fill your hard drive.do you know what is zero-filling?
Apr 03, 2012 | Fujitsu Computers & Internet
I need to reboot my lenovo pc to original setting as i have put wrong programmes an the c drive is nearly full
okay, get a porable device such as a portable hard drive and copy everything to it, then put your laptop back to factory settings, it will wipe your hard drive and then install the original soft ware but make sure to copy all items, including your install setup programs so that you can install what you need, if you have the operating system (windows disk) then you can also format your hard drive, this will delete your whole hard drive and when its done it will reset, enter your BIOS and reinstall windows, this may take between 2 to 48 hours depending on your hard ware installed.
Jan 29, 2012 | Lenovo Computers & Internet
HP Pavilion DV5000 battery charging problem
Sounds like you need to calibrate the battery, it is supposed to be done every 3 months. If it is not done, your battery will display the same symptoms are you describe. Yes, this holds true for adding a new battery also.
Here is HP's instructions on how to do it. You want to scroll down to the section called "Calibrate the notebook PC battery".
http://h20239.www2.hp.com/techcenter/battery/Battery_max.htm
Feb 27, 2010 | HP Pavilion dv5000z Notebook
When powering from full shut-down, takes about 30
whenever you want to turn it off, put it on hibernate.
Jan 02, 2010 | Toshiba Satellite M35X-S161 Notebook
Dell pc to slow
Yes, you can get (any) help. You must run a Registry Cleaner. It will clean your Windows registry which seems to be having irrelevant entries. You can down load one free from www.download.com or you can search google for free registry cleaners. I had the same problem and my laptop used to take over 20 mins to boot. I cleaned it with one RC and now it gallops like a new laptop. I do not think that you have any hardware problem.
Nov 15, 2009 | Dell Dimension 2400 PC Desktop
Blue screen on my laptop when I start reinstalling a deleted win Vista OS
I would get a different hard drive. Hard drives can be very tricky sometimes. I had that problem with My D600. replaced the hard drive and everything was okay. Hope that helps.
May 25, 2009 | Acer Aspire 6930-6771 Laptop
T42 Booting Takes too Long
since you did a fresh install run norton or mcafee or avast
by the way avast is free. defrag your drive. i always do that even after an install.
to get avast go to http://www.avast.com
and download it (it's not memory hungry) run it.
if you still have problems let me know
Mark
Apr 16, 2009 | IBM ThinkPad T42p Notebook
Laptop battery is not charging
you need to repalce the battery, it will only work on AC power only now as the power surge damaged the battery, thank your lucky stars that the surge didn't blow the whole laptop because 98% of the time it does!
Nov 16, 2008 | Computers & Internet
LG CRN 8245B (CRN-8245B) Internal 24x CD-ROM Drive Logo
59 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
