Question about GE Washing Machines
Ge elite 110 23012 100 top load washer
Everything works fine as it should,only the agitator does'nt seem to completly agitate. I apply light hand pressure on top as its agitating and this makes it work better,(pulling cloths down into tub). Agitator just seems weak or loose.Any suggestions on what and how to fix this. I'm sure I can do it my self with some info. This is a GE Elite top load washer Model #110 23012 100 maybe 8-9 yrs.old.
    Passionate:
    Visited the website for 10 consecutive days.
    Champion:
  • 207 Answers
Look on the inside your agitator makesure it not strip out cauing your agitator be lose might need to replace agitator
Posted on Aug 08, 2017
  • 641 Answers
SOURCE: washer will not agitate
A wears out clutch might prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. Good luck!
Posted on Aug 06, 2007
aborcass
  • 2651 Answers
SOURCE: GE Profile Washer Agitator will not come off
there is a product called agitamer, a rubber bladder inserted under agitator and hooked to your cold water line, pressure popos it off quite nicely
Posted on Feb 22, 2008
SOURCE: Kenmore Elite Washing Machine
On some you won’t see a bolt but if you look at it the white plastic that looks to have a stud in the middle is square and that is the nut you can use a 1/2" extension and ratchet to unscrew it then remove then agitator
Posted on Mar 04, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
SOURCE: Whirlpool Washer making loud noise during agitation. Agitator appears to be very loose
Does anyone have the name or part number of the piece that needed to be replaced that help stop makes all that noise?
Posted on Sep 09, 2008
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
My GE top loading washer is making a clunking noise during agitation. Everything else okay
The problem may be in your agitator. The spline may be worn out. It is located under the spindle. Are your clothes becoming clean. That noise might be the agitator not fully engaged.
Feb 06, 2013 | GE Washing Machines
How to take out the agitator on ge top load washer
Normally you can remove the top from the agitator, where you would normally put conditioner, and look down the centre of the agitator and should see a retainer of some description that should be able to be undone by hand.
Feb 23, 2012 | GE WBSR3140DW Top Load Washer
My WHDSR109J8WW Top Load Washer will not agitate or spin. When to the spin cycle something clicks as if trying to spin but does not. Checked belt...fine. Did the reset motor troubleshoot...did not help....
hi Jlove.
Washer Fills but Does Not Agitate. If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts..
Washer Doesnt Agitate or Spin
Top Load Washer will not agitate or spin Google Search
Dec 13, 2017 | GE Washing Machines
22942 Top Load Washer: Our Kenmore Elite w/ Quiet Pak II Super Capacity t...
my kenmore washer elite11 leaks water in the rinse cycle on the floor.
May 17, 2010 | Kenmore 22942 Top Load Washer
My agitator is not working in my washer- it is a kenmore elite. the agitator seems locked up. Everything else works fine.
The agitator is driven by a couple of different methods. The first is the agitator is splined and slips onto the matching splines of the agitator shaft from the transmission. The second is the use of a bell coupling which is splined to the agitator shaft as well and the agitator snaps onto the coupling. If the agitator does not agitate, first remove the agitator and watch the agitator shaft to see if it is working properly. This will require a small load setting of water and the machine set to run. If the agitator shaft is working properly, it is either the splines on the agitator or the bell coupling that is defective. If the agitator shaft does not work properly, the problem is in the transmission.
Hope this helps.
Aug 07, 2009 | GE WBSR3140DW Top Load Washer
GE top loader not agitating
Your agitator splines are probably stripped out.
Remove the agitator and check the spline grooves.And the agitator coupling on the shaft.
Mar 04, 2009 | GE WBSR3140DW Top Load Washer
Feb 11, 2007 | Kenmore 15864/15862 Top Load Washer
Washing Machines Logo
88 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
