Question about E-Machines eMachines Desktop PC
Emachine hard drive door will not open (how to repair?)
The hard drive door will not open. When the external eject button is depressed, the door sounds as if it is going to open but it does not. The same happens when the internal eject button is used. Will I need a new hard drive or can the door be repaired?
  • 247 Answers
Assuming this means the CD drive rather than the Hard Drive (which doesn't normally have a link to the outside world).......
Unless something from outside is very obviously fouling the door, the problem is probably internal to the drive. With the price of replacement drives these days (shockingly low), I wouldn't even bother opening the drive to investigate what's wrong - I'd just put a new (probably higher spec) one in.
They're all a standard size and fitting and fitting a replacement is a "no surprises" job.
Posted on Sep 17, 2008
How do I open the dvd door on my dell computer?
By pressing the eject button in front of DVD drive, if that's not working or is mechanically damaged, then go to start, then my computer, then you will see your drives. Right click on DVD/CDR the select eject. If you got it stucked with something and it won't eject then you need to find yourself a paper clip and straighten one end, you will then insert and push hard thru a small ejection hole in the front of DVD drive itselft.
Apr 26, 2014 | E-Machines eMachines Desktop PC
Unmount usb
External hard drives are portable storage devices you can use to back up files or transfer content from one computer to another quickly and safely.
While external hard drives vary in design and storage capacity, turning them off properly is ideal because it decreases the chances of damaging or corrupting files.
Whether you are using Windows or Mac OS X, you can safely eject and turn off your external hard drive in minutes.
Safely eject your external hard drive before turning it off if you have connected it to your computer.
To do so, click the "Safely remove hardware" icon on the system tray on the taskbar. T
he hardware window launches.
Click your external hard drive's icon in the hardware window and click the "Stop" button. You should see the "This device can now be safely removed from your computer" dialog message.
Press the "Power" button to turn off your external hard drive.
Some external hard drives turn off automatically when you safely eject them.
Right-click your external hard drive's icon on the desktop if you are using a Mac, and then click "Eject."
Alternatively, drag your external hard drive's icon from the desktop to the "Trash" bin.
You should no longer see your hard drive on the desktop.
Feb 05, 2014 | Transcend Computers & Internet
The CD drive has a pinhole on the door/drawer. It should be located close to the button you press to open the drive. Straighten a paper clip and insert it in the pinhole, pressing gently. The drive should open, releasing the CD.
Jun 22, 2013 | E-Machines emachines (emachinees) CD-ROM...
Cant eject my toshiba external drive
Is it listed in Computer? if so, right click, scroll down to Eject. If that fails shut down computer, unplug external drive USB and pry the door open or disassemble the case.
Dec 25, 2012 | Toshiba E05A050CAU3XW Canvio Hard Drive...
I emachine dvd rom/burner won't open how can i open it? but before it really do not play any dvd and then now it wont open.
If the door on your CD/DVD drive will not open when you push the eject button (on the front of the drive), Click on Start, My Computer, and Right Click on your CD/DVD drive. Then Click on Eject. If the door still refuses to open, you can insert a paper clip into the small hole on the faceplate of the drive and push it in until the door opens. If the door continues to refuse to open in the normal manner, you will have to replace the drive,
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Apr 05, 2011 | E-Machines emachines (emachinees) CD-ROM...
My cddvdrw drive door won't open to install a disc
Hi !
If your CDROM drive is not opening, try to push paper clip in the pin hole above the CDROM. This pinhole is use to eject the CDROM drive.
Good Luck
Jan 08, 2011 | E-Machines eMachines Desktop PC
Emachine-new-disc door used 3 times, now it will not open. Help.
Open "My Computer".
Point at the icon for the CD-drive.
Click with the SECOND (usually the RIGHT) mouse-button on that icon.
Choose "eject", to open the door.
If that does not work, then exercise the WARRANTY on your NEW computer to get the problem fixed, at no cost to you.
Sep 21, 2010 | E-Machines emachines (emachinees) CD-ROM...
The CD rom tray will not open.
just watch carefully on cd drive front there is a tine hole somewhere below the door area . now u need a very thin rod or something to insert in to it. there is a button inside that hole so while pressing that button press the eject button. hopefully ur cd drive door will open
Apr 20, 2010 | IBM -3509707 External 4x CD-ROM Drive
Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Feb 02, 2010 | Computers & Internet
The cd drive won't open on the tower
If you look closeley there should be a small hole near the eject button. You can manually open the door with a straightened paper clip.
Mar 19, 2009 | E-Machines emachines (emachinees) CD-ROM...
E-Machines eMachines Desktop PC Logo
123 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
