Question about Intertherm Heating & Cooling
We only shut off the furnace in May.....we turned it on for the first time today and want to know if that is safe.
  • 182 Answers
I believe an inspection of the heat exchanger and a good cleaning should be done yearly.That being said,it does not harm your furnace to be shut down.
Posted on Sep 18, 2008
If I shut off the blower on my gas furnace do I have to shut down the whole furnace
Turn of the system at the thermostat. If you turn off the blower, assuming you mean at the tstat, there's no need to turn off the pilot. If blower is running and won't stop, even if turned off at tstat, turn off power by any means necessary, and pilot does not need to be turned off. A "standing pilot" is made to stay lit at all times, running or not.
Mar 07, 2017 | Heating & Cooling
Why doesn't my furnace shut off
HOW OLD IS YOUR FURNACE AND WHAT MAKE IS IT
Dec 06, 2014 | Heating & Cooling
I have the model 40135 thermostat & a gas furnace. When the temp in my home cools, it tries to engage the furnace, but just as quickly shuts the furnace off. It does this over & over, & I have to turn the...
The rule of thumb for placing thermostats on the wall is to be far removed from any vents (warm or return air), it shouldn't be in a hallway where the air moves like a wind tunnel. It must be one the the most still areas in your home. Is this the case?
Oct 21, 2013 | Heating & Cooling
I installed an RTH2300 this winter to replace an old mercury thermostat. It worked fine for the heating season. I turned it to Cool for the first time today and my AC and furnace blower will not turn...
Maybe turn selector switch to off.see if every thing shuts off.if yes. turn FAN selector switch from (auto) to (on) mode.does the outside unit come on or does just the furnace blower only run ? the inside fan should be the ONLY thing on.if not, reverse the (G) & (Y) wires inside the new thermo.
Jun 07, 2011 | Heating & Cooling
Flame sensor dirty
Sandpaper lightly scrubbed over the sensor tip to remove any contamination.
Sometimes cleaning is not enough and the sensor must be replaced.
Jan 30, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Pilots stays lite but furnace burners will not turn on. when i turn the knob to on nothing happens
You more than likely need to change or adjust your thermocouple in the furnace. It is the part the pilot light heats up to let the furnace know it is safe to turn on the gas flow. These go bad over time and are fairly inexpensive and easy to change.
Nov 06, 2009 | Heating & Cooling
Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Mar 02, 2009 | Ruud UBHC Air Conditioner
Goodman Furnace m/n GKS90453BKAC
A constant red light (not blinking) indicates that the thermostat is not calling for heat. Of course you know it is but just to be safe, jump out R and W on the board. If it continues to do the same as you indicated, replace the board.
Dec 05, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Intertherm Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Dan Webster
Dan Webster
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
