Question about Samsung RS2630SH Side by Side Refrigerator
RS21DGRS SAMSUNG SIDE BY SIDE REFRIDGERATOR
It started with the water dispenser not working. Now the fridge temp has gone from our set level of 3 degrees C to 12 degrees and will not return to its set level. Freezer seems to be OK.
  • Anonymous Sep 19, 2008
    I HAVE THE SAME PROBLEM WITH MY SAMSUNG , I HAVE NO WATER AT THE DISPENCER -BUT I HAVE ICE, AND I CANNOT REDUCE THE FRIDGE TEMP UNDER DOUBLE FIGURES
    MANY THANKS
    DARREN RICE
    CLACTON-ON-SEA
    U.K.
  • lioncerf Sep 27, 2008
    I have the exact same problem:
    no water from the dispenser, although ice part is working fine
    desired temp is set to 4 (celsius), double digit actual temp
    Dummy interim work around: use picnic freeze pack from the freezer to lower fridge temp :-(
    I do not quite understand the proposed answer: where is the fridge freezer wall to be found? What plastic part needs to be removed to access it?
    Cheers,
    F
    Cote d'Azur
    France
  • 943 Answers
Hi thanks for the question it might be a problem with a little frost on the freezer wall fridge not defrosting check the freezer wall with your hand,will feel some frost if this is the problem thanks the appliance doc you
Posted on Sep 17, 2008
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The fridge of my American style fridge/freezer is
You can use a hairdryer on the frozen parts.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Samsung RS21DGRS side by side fridge freezer. Fridge not working became noisey then stopped working. It is 2 years old and two week out of warranty.
common issue on these uk Samsung fridge freezers , symptoms
fridge noisy stops when door opened
water doesn't work
colder at the bottom of the fridge
ice build up around the left vent on the lower fridge panel
check out the you tube video and the Chanel the video belongs to - very helpful stuff regarding uk Samsung fridge freezer problems
this videos show how to dismantle Samsung rs21
May 29, 2008 | Samsung Office Equipment & Supplies
Water Dispenser Not Working
the water spout on the dispensor unscrews this is a clog issue take it off and then run water becarful this does have a spray effect all over but it allows water to flow
also there is the problem of the water tube up the door has kinked when closed this is a big deal with front fridge water the ice dispensors tube goes up the back
May 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Amana Side by side refridgerator Model SBD20TPE P1190006WE
hi
one question : are the units under warranty ?
if not its pretty easy to swap the dispenser paddles and the membranes
infact i have been using this site for many years and have found it helpful: : www.howstuffworks.com
thanks
May 04, 2008 | Amana ACD2232HR Side by Side Refrigerator
No water from water dispenser on my ge hotpoint refridgerator
its possible the water tank or tube is frozen up. try turning off the refrigerator and leaving the door open for about 10-15 minutes and see if it will start working again. if that works adj your temp settings to warm the fresh food section up just a little to prevent it from freezing again..
Dec 12, 2007 | Hotpoint HSS25GFP Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
408 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
