Question about Refrigerators
Refrigerator electrical short
I have a whirlpool side by side refrigerator, model 22RF. I bought it used and it was working properly according to the previous owner. I plugged it into a GFCI outlet and it trips the outlet. I have disconnected each component at the electrical connector and the outlet still trips. Any suggestions on where or how to isolate an electrical wire short?
Ernie
  • Anonymous Oct 22, 2008
    I also have a whirlpool side by side refrigerator, 2001 25cuft. I recevied it used and it was working properly according to the previous owner. I plugged it into a GFCI outlet in the garage and it trips the outlet. I have disconnected each component at the electrical connector and the outlet still trips. It will run for several hours without tripping the circuit, but after about eight hours, usually overnight, it trips and then cannot be plugged in to the same circuit for several more hours. After waiting about 4 hours, it will then work again. Any suggestions on where or how to isolate an electrical wire short?
msmichalko
  • 17 Answers
SOURCE: fridge problem
You may have a short some where in the fridge. If you have a multimeter, I would suggest metering the power leads to the compressor. The compressor may be bad, if you find no shorts in the metering of the power leads.
Posted on Jan 10, 2008
  • 21 Answers
SOURCE: refridgerator trips the gfci outlet but will run on a regular out
sometimes with age the GFCI may start to get weak from continous current heat/cool--expansion/contraction.A regular outlet is fed by a circuit breaker which may have a higher amperage rating.If you replace the GFCI it may take care of the problem.The only fuse I can think of will be a circuit breaker in the fuse panel.Hope this helps. Gregg
Posted on Jun 06, 2009
  • 401 Answers
SOURCE: Kenmore side by side plugged into a GFCI outlet
Plug it into a "regular" outlet and not a GFCI
Posted on Jan 03, 2010
  • 25 Answers
SOURCE: frig cools works great all day then trips the gfci
Hi Sturkle;
Does this happen say- every 6-8hrs? If so you may find the defrost element has a short, or defrost timer is faulty. Defrost element is located in the freezer compartment, Time located an back of fridge.. Use a qualified person when playing with electrics...Cheers
Posted on Mar 29, 2010
  • 351 Answers
SOURCE: whirlpool refrigerator trips gfci outlet
Yes ,, if the fridge outlet is behind the fridge and therefore not accessible for use by counter top appliances .. then yes change it to a regular outlet.
The cause is probably the compressor, getting a bit noisy..electrical noise I mean.
Posted on May 05, 2010
Ice build up in freezer causing the refrigerator to warm up
Your defrost circuit is most likely not working. Unplug your refrigerator and take off the back wall inside the freezer and ohm out the bimetal thermostat (it's a round, metal thingy clipped onto the top or side of your evaporator coil lines.
It should read a short. If it doesn't, replace it. If it does read a short, then it's probably good and you'll need to ohm out your defrost heating element.
It usually looks like a baking element you would have in your electric stove and wraps around the sides and bottom of the evap coil. You should get some sort of resistance reading. If it's open, replace it. If it's reading a decent amount of resistance, then you'll need to look at your defrost timer (or main control PCB if you have a newer refrigerator). I'd need specific model information to help you there.
Oct 16, 2014 | Whirlpool Refrigerators
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
My Whirlpool refrigerator trips the main breaker of 40 Amps
A refrig cannot pull 40 amps in defrost , unless there is a direct short in the defrost system ( timer , heater , bimetal ) . I would use an extention cord ( for test purposes only ) , and try a different plug . Sounds like the circuit breaker is weak . In defrost , the MOST you should get , is 6 amps . This will not throw a 40 amp breaker . If you have an amp meter , remove the back refrig panel behind the refrig , and connect to one of the power cord lines (just not the green ground ) , turn into defrost and check the amps . This will tell you if short is in refrig , or weak breaker .
Sep 06, 2009 | Whirlpool ES5FHAXS Side by Side...
The Ice Dispenser on my Whirlpool Side-by-Side Refrigerator broke
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Refrigerator.
Mar 10, 2017 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The light bulb burned out. I do not know what type and and wattage of the bulb to replace it.It is the refrigerator light bulb in GE TFX24R refrigerator. Thank you my email is endliamc@gmail.com
According to GE this uses a 40 Watt appliance bulb. You should be able to get one from any department or home improvement store.
I hope that I have provided the correct information that will assist you in the resolution of this issue. If you have any questions, please post back with a comment to this thread.
If I have helped you with your question and/or solved the problem, please take just a moment to rate this post. Thank you!
I try to give the best FixYa experience.
May 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water & ice dispenser problem
Ensure there is proper water pressure and volume to the unit....replace the water filter....all should be fine.
clarkco
Apr 29, 2009 | Refrigerators
Whirlpool fridge stopped working. Actually somehow
This is an indication of a direct electrical short. Unplug refrigerator and do not use until the problem has been repaired! Sea Breeze
Mar 27, 2009 | Whirlpool ED5FHEXMQ Side by Side...
GE Ice dispencer not working properly
for a very informative video on trouble shooting your refrigerator http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
I had the problem with no water or ice dispenced and the lights dim when dispencer is used and the refrigerator compresser stops after using the dispencer and had to unplug and reset unit. GE DID NOT WARANTY IT. I bought a new motherboard for about $88 and fixed my problem. As the video shows there can be other problems that will cause some of these symptoms but not all at once. My frige was only 2 years old when this happened.
Mar 02, 2007 | GE GSH25JFR Side by Side Refrigerator
Refrigerators Logo
311 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
