Question about Haier HTX18GAAWW Air-Cooling And Automatic Defrosting Refrigerator
Drain hole plugs with ice
I have a Kenmore side by side. In the bottom of the freezer section is a drain hole. Whick keeps freezing up with ice. When the fridge goes into the defrost cycle the water can not drain out the drain hole into the pan underneath because the hole is frozed with ice. The water then runs into the bottom of the freezer. Any suggestions?
    President:
  • 1,462 Answers
This is a perpetual problem due to no drain heater being fitted. what may help is to run some pieces of copper wire from the defrost heater and have them into the drain hole. enough heat may be conducted to cure it
Posted on Sep 18, 2008
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
Jun 07, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore refrigerator, model #60267990, serial # EJ5036206, water leaking from the freezer into the fridge on shelves into veggie bins, drain hole freezes up, defrosted it about 2 months ago, and has...
a plugged or frozen drain is a common problem that occurs from time to time in just about all refrigs. Folllow theses directions and it will probably not occur again for 2-3 years.
  • Unplug refrigerator
  • unload food from freezer
  • remove icemaker if present (there are 3 screws remove the one on the bottom and loosen the 2 on top of icemaker then lift it off the 2 screws unplug from wiring harness)
  • remove 2 screws holding rear cover in place
  • move cover to the side or remove from unit altogether
  • defrost any and all ice from bottom of freezer and aluminum drain pan that is now exposed
  • flush drain hole that you will see once ice is cleared with warm water. (sometimes I use a large syringe or turkey baster to forcefully flush hot water thru the drain tube)
  • reassemble in reverse order
Feb 28, 2011 | Kenmore Refrigerators
Leaks water inside from the ports or vents under freezer but in fridge
Your problem more than likely is a plugged defrost line in the freezer...The freezer goes through periodic defrost cyles to keep the coils from freezing up. The water catches in a trough pan in the freezer and flows through a drain hole to the bottom of the fridge where it evaporates. This drain hole perodically freezes up and the water accomulates under the freezer bottom until the water level reaches your vent ports to the fridge section. Open your freezer and on the bottom floor of your freezer you should see two screws near the front on either side. Remove them and then take out the bottom tray....this will expose the drain hole near the rear of the freezer compartment. You will more than likely have to remove ice under the tray in order to see the drain hole. Remove the lower back panel on the back of the refrigerator and you should be able to see the drain line coming from the freezer. Unplug the refrigerator before you begin work. It will take a little while for the drain line to thaw to allow liquid to flow to the bottom. I find a hair dryer pretty handy in speeding up the process. To verify you have unplugged the drain line you should be able to pour hot water in the drain hole in the freezer and see it come out at the rear of the fridge in tube line just above a little catch pan
Feb 08, 2011 | Kenmore 64802 Top Freezer Refrigerator
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water accumulates in freezer bottom and of course frezzes. if we don't break up and remove the ice, water will leak out the door. best guess on the model below. The back panel states "R134a"
134a is the type of freon used. There is a defrost drain hole at the very bottom of the freezer usally below the back panel. It has a tube that runs underneath behind the back bottom of freezer section. It can get stopped up with slugg that keeps the water from getting to the defrost water pan. The water in the tube freezes and the water then runs out the front of freezer being it has no exit. . hot water or a hair dryer gun. If you have means to blow hole out after ice is melted will do a better job. Blowing warm water down hole through tube with mouth will knock ice out quickly but be very careful. also this ewill remove any trash build up in drain hole.
Mar 01, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side water leaking from freezer
You can buy a kit from whirlpool. In the kit is a metal tab that mounts onto the defrost heater. It is long enough to go into the hole. When the heater comes on for defrost the heat transfers down to the hole and keeps it from getting plugged up with ice. Part number 819043
Feb 05, 2010 | Freezers
Ice at bottom of freezer
Make sure defrost drain is completely cleared of ice and anything else obstructing it. Pouring hot water in it is correct, but make sure it is going all the way through to defrost pan under unit.
Oct 11, 2017 | Kenmore 52632 / 52634 / 52639 Side by Side...
Maytag side by side refrigerator ice forms at the bottom of freez
Your drain is probably plugged. Remove the back panel in the freezer and keep squirting hot water down the drain hole with a turkey baster or something similar until it clears. The drain hole is located at the bottom of the coils in the freezer section. Your refrigerator goes into defrost every 8 to 10 hrs. When this happens, it melts the ice on the coils, which in turn, runs out the hole where the drain is. If something like algae is blocking or plugging the hole, it will plug up causing water to freeze over the hole. The water has nowhere to go but out the door.
Jun 02, 2009 | Maytag MSD2454G Side by Side Refrigerator
Pooling Water
Hi!!!Your drain line is frozen and plugged.Try to remove the cover of the evaporator and you should see a small hole on the base of the evaporator thats yout drain line hole. Blow it away and your problem is gone..Good luckk..Plugged drain line..
Dec 23, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Water collecting in Refrigerator freezer section
the drain hole could have ben clogged with dirt and now with ice as the water did not drain as it went back to freezing mode. un plug the unit, let the ice thaw for a day, open the rear cover of the freezer and clean the bottom part of the evaporator. you can find the hole at the bottom part of the drain pan. i hope i was able to help.
Jul 05, 2008 | Kenmore Refrigerators
Haier HTX18GAAWW Air-Cooling And Automatic Defrosting Refrigerator Logo
385 people viewed this question
Top Haier Refrigerators Experts
John Tripp
John Tripp
doggzzz
Level 1 Expert
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
