Question about Eureka Vacuums
How do I change the belt on a 2991AVZ bagless vacuum
  • 120 Answers
Release the handle on the vacuum until it rests flat, then look at the part of the machine that has the hieght adjustment knob on it, that is the hood of the vacuum. there are usually three screws that hold it on. There should be a screw on the left and the right of the knob (towards the sides) and then the third is near where the small hose sticks out of the hood. once those are out the hood lifts up you will need to pull up on the brush roller ( you might need to use a small flat head screwdriver to pry it out, place it between the end of the brush and the housing and pull ) then take the new belt and place it over the small metal shaft that sticks out from the motor then put the belt on the roller and pull it into place dropping the roller back to where it was. also try turning the roller by hand to make sure you didnt pinch the belt under the roller.
Posted on Sep 17, 2008
"Eureka - Pet Expert HEPA Bagless Upright Vacuum - Mystic Purple" is BRAND new and burning! I literally had soot on my hand and up my nose and mouth after using it just now. I've only had it for 24 hours....
Sounds like the beater brush is frozen and the drive belt is burning up.
Check your directions on changing the drive belt for the beater brush. When you remove the beater brush, clean as best you can. At each end of the beater brush you will find a plastic clip. These clips hold the beater brush in the vacuum. Add some WD40 between the brush and the clips. Turn the clips by hand and be sure they turn freely. Reassemble and at the same time, put on a new drive belt.
If this solution is of help to you, please take the time to add a Thumbs Up to my profile for the assistance. Thank you. Paul
Oct 10, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
How do you replace the belt? Can't find anyplace to open the bottom to replace belt.
You don't actually have to turn the vacuum over for this. The two screws you need are on top, above the brush roller. It is the top cover that comes off instead of the bottom on this vac. You'll see everything once you lift it off.
Sep 24, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
While vacuuming a rug on high (carpet setting) the power suddenly decreased. Now it will only run with low power, not picking up items on carpet
It sounds like you burned the belt. Turn the unit over, remove the cover plate where you see the brushes. On the side of the brush roller is where the belt is located. The belt should be very tight on the roller. Also, you may see little black rubber pieces stuck to the area where the end of the roller is or in the part where the belt runs. Get your owners manual out and read how to change the belt. I'll bet when you ran over the carpet it hung on some of the nap and hung the brush roller up for a second or so. That's all it takes sometimes to fry the belt on some vacumes. Sometimes new vacumes come with a new belt. Look in the bag or box and install it.
Mar 08, 2010 | Eureka 2991AVZ Bagless Upright Cyclonic...
I have a Eureka Altima vacuum. The model number is 2996. I don't think my vacumm is sucking any dust. Plus, it smells like a burning leather. What should I do? I have tried to get help from others and they...
Sounds like the belt for sure. Here is a link with the owners manual. It shows how to get to and change the belt.
http://www.eureka.com/index.php?option=com_productdisplay&view=productdisplay&task=getproducts&productid=2&product_model=2991AVZ
Sep 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Bought at walmart - don't carry the Eureka Boss Whirlwind now and I need replacement belts
find a vacuum repair store in the yellow pages, these are common items so they will have them in stock.
Jul 14, 2009 | Eureka 2991AVZ Bagless Upright Cyclonic...
Bearings in the vaccum's main brush
Alot of times things get wound up on the brush roll ends and causes friction, the ends will overheat and melt, you just have to replace the brush roll(62365-2) and a new belt (61120A)while you are at it. Also check the slots where the brush sit in to make sure they didn't melt too, if so you would have to replace the base(62577).
Feb 21, 2008 | Eureka 2991AVZ Bagless Upright Cyclonic...
Changeing belt
On the top nozzle, there will usually is 2 screws holding the top done. There are slots or holes on each side near the front and the screws or in these holes. Remove them, remove the top cover and then you can get to the brush roll and belt.
Dec 22, 2007 | Eureka 2991AVZ Bagless Upright Cyclonic...
Changing my Belt
There should be 2 or 3 screw on the top housing, if not there, then they are on the bottom. Remove those screws, then the top housing comes off and the belt and brushroll are in the open.Part # 61120A long life belt. Brush roll #62365-2 if needed.
Dec 16, 2007 | Vacuums
Vacuums Logo
334 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
