Question about M-Audio BX5a Speaker
M-Audio BX5a Speaker Problem
When the speaker is on mode; the power LED does not work and it makes a hissing sound if anyone can help with this; i highly appreciated.
  • junkassbox Apr 24, 2009
    Same problem here. Any details as to how to replace the capacitor? I'm decent with a soldering iron. I'm assuming I just cut off the old one and solder on the new ones?
Not sure i can help with the led problem but i just fixed a hissing problem with one of my BX5a monitors. It developed a hiss when on (both tweeter and bass) and a very loud thump when switched off. I found a slightly swollen power filter capacitor on the internal board. They are the two biggest black capacitors, labelled as 25v 6800uf. Only one of these was bulging. The tops of these should be totally flat. The indented X on top of the caps make any bulge easy to spot. Worth opening it up and having a quick look. I could only find 35v 6800uf caps at my local electronics store but they did the job ($3 each). I swapped both out and it's now working great. An easy DIY fix, just be sure to always have the power cord unplugged before you put your hands anywhere near the guts of the thing. Hope it helps.
Posted on Dec 06, 2008
    New Friend:
  • 7 Answers
Replace the caps with 50v 6800 uf ones. 25v is way too low for monitors. bad choice on m-audios end.
you will most likely have to solder new leads on the board and mount the caps off the PCB because new ones are so much bigger. easy DIY fix though. happens all the time with this model.
just make sure you get the polarity correct on those caps and dont forget to discharge the ond ones BEFORE you go working on it! (just ground the cap)
Posted on Dec 10, 2012
How to replace capacitor on M Audio bx5a speaker
http://mr-ives.blogspot.nl/2011/09/mending-pair-of-m-audio-bx5a-monitors.html
Apr 20, 2013 | Klipsch Synergy Sub12 Subwoofer Speaker
The led light went out not even a year old
it says the quality of your led light is too bad if it wooldn't been fixed well ..you never buy the that led . you should change another .
home light
May 10, 2012 | M-Audio BX5a Speaker
APX400.4M. 12 volts on.... Power LED on....fuse OK...but no sound...not even a hiss from the speakers
Make sure that your speaker cables are connected properly and that the amp is not in protection mode. Also make sure that the amp ground wire is connected solidly to the vehicle chassis in a paint-free location. If you do all of that and it still doesn't work, make sure the head unit lead is connected correctly to the amp (these should be RCA cables).
Feb 27, 2011 | Clarion APX400.4M Car Audio Amplifier
Where do I find a replacement woofer for a bx5a monitor
http://reconingspeakers.com/product/m-audio-bx5a-woofer/
Jan 02, 2011 | M-Audio BX5a Speaker
One of my speakers has a constant hum and an intermittent crackle/hiss while music playing. Please help!
Swap speakers from the output of the receiver or amplifier. If you hear it from the same speaker, then the speaker is bad.
Nov 10, 2010 | M-Audio BX5a Speaker
No sound from M-audio BX5a monitor
I have a pair of BX5a monitors hooked up to a video editing suite. One of the monitors is off. They are powered to a working electrical supply. They are driven off a Mackie DFX-6 with a 1/4" unbalanced connection. No blue light on the monitor, no sound or hissing on that...
Jan 31, 2009 | M-Audio BX5a Speaker
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
No sound from left rear surround speaker
i think it would probably be somthing inside the channel???
Jan 01, 2008 | Aiwa NSX-DS55 CD Shelf System
M-Audio BX5a Speaker Logo
2,355 people viewed this question
Top M-Audio Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
jason
Are you a M-Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
