Question about Refrigerators
Beco larder fridge - excess of water in drip tray at rear - fridge cold but items in fridge are heavily condensed
    President:
  • 1,462 Answers
You have air leaking into the fridge. check door seal by trapping a slip of paper between seal and cabinet all way round
Posted on Sep 18, 2008
Kelvinator Cyclic 330, Model No: CS334A-R
Tonight, get a battery flash light, turn it on, put it in the fridge and close the fridge door. Then turn off all the lights in the room. If you can see any light escaping around the fridge door, the door seals aren't working properly, and need replacing.
This is the main reason why too much water is being condensed and causing your fridge drip tray to overflow.
May 25, 2014 | Refrigerators
Having thermostat problems in my Maytag fridge/bottom freezer. Pulled the fridge out and vacuumed everything. This am the copper coil on the back outside is leaking water drop by drop. The coil is not hot/...
The copper coil on the back comes from the compressor and is what makes the fridge cold but it is filled with gas. They can condensate and drip water but this isn't usually enough to notice, or cause damage. I would actually suggest looking again to check the exact source of the water. Be aware that some water from the defrost cycle is supposed to drip into the evaporator tray at the back.
Jul 10, 2013 | Refrigerators
Water is dripping from the bottom of the fridge (slow drip). How do I fix it. I have a Maytag French Door stainless steel fridge (4-year-old) with freezer on the bottom.
There should be a drip tray catching the defrost water... it may be overfull... Try to remove it and empty it. The tray is actually supposed to have a heat evaporator to dry up the water before it overflows. Your may be fuller due to excessive frost also... from hot temperatures outside or opening the fridge too often or for too long... good luck!
Jul 24, 2011 | Freezers
Have a GE Model #GSL22JFPHBS side-by-side refrigerator that the freezer is staying cold but the refrigerator part is not get cold.
its either the defrost heater or defrost thermostat or the defrost timer has gone bad and the evaporator is iced over,HINT: (you will see the inside rear panel in the freezer has frost on it) and the evaporator fan cannot blow cold air over the iced up coils in which case soon the freezer will start to seem warm too,if this isnt the case then its the damper vent door located between the freezer and fridge compartment that opens and closes to throttle cold air into the fridge from the freezer,sometimes they freeze shut from condensation or the door hinge breaks and it can jam shut,also if theres excessive water dripping into the fridge from the top it can be a plugged drain hole and water blocks cold air flow,also make sure the evaporator fan beneath the evaporator coil in the freezer is operating when the units running or cold air wont be pushed into the fridge either
Jun 27, 2011 | Refrigerators
Hi, I have a refurbished RFG297AARS from Samsung that we purcased as a refurb about 7 days ago. On day 1-3, a puddle of water formed under the back right underside of the fridge, without the water line...
Chances are its either the drip line or drip tray.. there is a drain to route the condensation pulled out of the fridge and freezer that leads to a drip pan underneat the unit.
Either the drip tray was not installed.. reinstalled incorrectly or the drain tube is leaking or no longer directed to it, or it's overflowing due to excess condensate.
Best of luck!
Apr 26, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Water dripping from underneath
The water is most likely coming from the condensation that's drained out of the refrigerator during the automatic defrost cycle.
Be sure the bottom fan is running and clean out the condensation tray. Warm air pulled across the condenser coils is supposed to evaporate the condensate water. If the fan is not running when the refrigerator cycles on, replace it. This would also result in the refrigerator running excessively without cycling off.
While you're working under the unit, be sure to clean off the coils too.
Good luck. Hope this was helpful.
Nov 20, 2009 | Computers & Internet
Black tray above compressor is filling up with water on a RLA50
hi there.the tube your speaking about comes from the rear of the fridge down to the plactic tray on top of the compressor...and is used for conveying condensed water from the fridge to the dri tray where it is evaporated by the running heat of the comressor....excessive water can be caused by a faulty fridge door seal....door not closing correctly...and the possibility that your fridge setting is to low....or sited close to a working radiator
regards Sir Galahad
Aug 12, 2009 | Hotpoint RLA50 Refrigerator
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
Dec 16, 2008 | Refrigerators
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
I have a larder fridge that seems to collect too much water in the tray at the back, it seems to be temperamental with cooling. It only works part time. How affected are they by not being completely level?...
this water should be evaporated by the motor heat.however, i have found with larger larder fridges of several makes that too much water is formed for it all to go.
worth while checking the door seals as well as if seal is leaking, more ice forms on the evaporator and hence more water
Aug 31, 2008 | Frigidaire Refrigerators
Refrigerators Logo
245 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
