Question about Kenwood KAC-9102D Car Audio Amplifier
Kenwood amp i touched the B+ wire to the GRN on accident when i was installing it and now it wont power on.. Is there a way to fix this problem.
  • 35 Answers
Yes there is!!! I have that same amp and what probably happened to you happened to me, if you seen some black smoke or smelled like something was burning then heres what you do, Remove the cover under the bottom of the amp, there are alot of little screws so dont lose them!!!, you will see a wire that look like it ws fried and it will be broke apart, so get you a GOOD sautering iron and sauter the wire back together is you cant get it to sauder back then just take a piece of wire and tie the two broken pieces together and then your amp should work again!!
Posted on Sep 17, 2008
My son accidentally the pos and neg speaker wires together and the fuses blew on the amp and now the power light wont come on at all do you think the amp is damaged?
If I had to guess by touching the positive and the negative terminals together it probably fried up the transistors. While back I did the same to my amp and poof amp no longer worked. Took the amp apart to find the transistors fried up. Ordered them from the manufacturer but never installed them, ended up buying a new amp. Mainly, replacing the amp doesn't mean it would fix the problem....
Feb 22, 2011 | Kenwood KAC-9102D Car Audio Amplifier
I am installing a new cd player in my 2006 dodge ram single cab truck, i have made the mistake of the cutting the stock wiring harness plug. Now i need to know what color codes are on these wires so i can...
Hello my name is Israel. I have added the following informaiton to help you out. Good Luck.
Radio 12v gray/red + radio harness
Radio Ground black and black/lt. green - radio harness
Radio Ignition pink/yellow + radio harness
Radio Illumination orange/tan (dimmer) + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- dk. grn/yel - dk. grn/lt. blue +,- radio harness or amplifier
Notes: The amplifier is behind the glove box.
RF Speaker +/- gray/yellow - gray/lt. blue +,- radio harness or amplifier
LR Speaker +/- gray/lt. grn - gray/dk. grn +,- radio harness or amplifier
RR Speaker +/- dk. grn/lt. grn - dk. grn/gray +,- radio harness or amplifier
Feb 21, 2011 | 2006 Dodge Ram 1500
1993 ford thunderbird stereo installation guide/ wiring guide
bat.-lt.gr/ppl; grnd-blk; ign-yel/blk; lights-lt.blu/red & org/blk; grnd-blk/org; L.F.-org/lt.grn & lt.blu/wht; L.R.-pnk/lt.grn & tan/ylw; R.F.-wht/lt.grn & dk.grn/org; R.R.-pnk/lt.blu & brn/pnk
Nov 07, 2009 | 1993 Ford Thunderbird
Amp will not come on ,no light
Yes!!!!!!!!!! Your remote wire is what tells your amplifier to turn on and off it won't work without it. Assuming your stereo headunit is an after market unit it has the correct wire for this. what you have to do is pull out you headunit, and in the back of the headunit where all the wires plug into your unit there is blue wire with a white stripe. this is the remote turn on wire. connect a wire to that blue n white wire and run it back to your amp, insert it into to the spot marked remote. turn your head unit on and your amp will power up... if you have all the rca cables hooked up your amp should be ready to go.... btw good choice on the amp, kenwood is the way to go!
Aug 31, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Kenwood KAC-9152D I THINK IT SHORTED OUT BUT HOW CAN I FIX IT?
Either can either do it yourself like the guy above or take it to your local car audio dealer :)
Upfront Audio
Apr 10, 2009 | Kenwood KAC-9152D Car Audio Amplifier
No power to the amp i touched the power wire to the side of the amp
It probably burned a trace on the circuit board.
With the amp hooked up normally and the head unit on (so the amp will have remote voltage), do you read 12v DC anywhere on the case of the amp (black meter probe on the ground terminal of the amp)?
If there is no voltage on the case, confirm that you have 12v on the B+ and remote terminals of the amp (black probe on ground terminal of the amp).
Aug 25, 2008 | Kenwood KAC-9102D Car Audio Amplifier
Mp2035 cd player will not turn on.
My hunch is that the fuses blew. When you cut all three at once you shorted the battery to ground and most likely blew out the fuses. Check the fuses and let me know. That is my best guess. Good luck
-Andrew Hawkins
Jun 10, 2008 | Kenwood KDC-MP2035 CD Player
FIX AN AMP
It probably blew the fuse near the battery or in the distribution block.
Jun 09, 2008 | Kenwood KAC-9102D Car Audio Amplifier
My kenwood kac7201 amp wont turn on but it has power to it
Recheck the voltage precisely like this:
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Jan 22, 2008 | Kenwood KAC-7201 Car Audio Amplifier
Kenwood KAC-9102D Car Audio Amplifier Logo
88 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
