Question about Kenmore Elite HE4 Electric Dryer
Dryer not working
The dryer lights are on. Everything looks normal until I push start. The dryer beeps but dosn't start.
Thanks,
Becky
  • 1 more comment
  • SAMCPHERSON Sep 21, 2008
    I have teh exact same problem. It allows me to seltect the cycle, it displays the number of minutes and when I push the start butten, it beeps twice and the numbers start to flash. I tried unpluging it, but when I plugged it back in it showed a code of PF (power failure). I hit cancel and it went away. I hit the cycle and start and it beeped as before. The dryer is about 4-5 years old.
    Any help would be appreciated.
    Steve
  • johnikeo Sep 23, 2008
    I have the exact same problem. It allows me to select the cycle, it displays the number of minutes and when I push the start button, it beeps twice and the numbers start to flash. I tried unplugging it, but when I plugged it back in it showed no code? I hit the cycle and start and it beeped as before. I used the dryer a few minuets before and noticed the dryer light went out inside. i changed the bulb the filament was blown to Pices. I replaced the bulb and it still didn't come on. The un plug computer reset dosent work The dryer is about one year old.
    John
  • Hilblee Nov 21, 2008
    Same exactly.
I had the same problem with my HE3, my husband took out the switch that tells the dryer when the door is closed and messed with it. He put it back in and it works for now - he says we need a new one.
Posted on Sep 24, 2008
  • 750 Answers
Becky843,
Huuum,at your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems.
if they are not serious, or they are a temp glitch!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Thank You
Posted on Sep 18, 2008
Hi, we have a Siemens IQ300 Condenser Tumble Dryer which we have recently inherited. Unfortunately it worked for a wek before just stopping. The lights are on and everything looks normal but when you
Check to see if it is properly grounded and that the incoming voltage is correct (120V or 240V) for the wiring config you have.on the dryer as it sits. Also try unplugging and wait a minute or so before plugging back in. This will sometimes reset dryer electrical components to factory settings.
Dec 07, 2012 | Dryers
Dryer won't start
If you look closely, there are 3 separate pins that must latch. One is a simple push-button style which latches no problem.
The others are little prongs at the top and bottom of door. The bottom prong latches cleanly, but the top one will not latch because the door is a bit too flexible.
Close the door normally, then firmly press on the top edge of the door. You will hear the final latch grab, then you press and hold the start button. The dryer starts normally.
Oct 21, 2012 | Whirlpool GEW9250 Electric Dryer
I have the Kenmore He4. All the lights are working but when I push normal and start, I get a loud click and beep but nothing happens. All the lights seem to work normally.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 27, 2011 | Kenmore Dryers
My fisher and paykel dryer ( mod# ED56 ) wont start, power is on
I had this same problem with my Dryer. It is making the few quick beeps because it thinks the door is still open. Near the bottom of the opening to the dryer there is a sensor switch that gets pushed in when you shut the door. Try holding the switch in with a knife or something and then start the dryer with the door open to check if that is the problem.
After i did this, i closed the door and my dryer started as normal.
Aug 11, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Dryer does not work
Dryer just beeps, lights work, panel lights change, dryer just wont start. before this dryer worked but kept beeping thru the whole cycle. now nothing but lights.
Mar 13, 2009 | Whirlpool GEX9868J Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer...
Hello jmylymok,
Welcome to Fizya,
You said, you replaced burned out dryer bulb on Whirlpool GEW9250PW and now drum light won't shut off even with door closed. Dryer will not work but all panel lights function normally - UNTIL you press start. Dryer just beeps and doesn't work. When I tried the troubleshooting solutions, the error 6E comes up. What does this mean?
This sounds like the reason your bulb went out was more than just a bulb normally dying!
There is a short, or in that socked or the switch or it affected the the control panel too!!
This sounds like a hands on diagnoses job!
Let me know how it goes.
Huuum
Oct 08, 2008 | Dryers
Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
Jul 25, 2008 | Whirlpool GEW9200L Electric Dryer
Kennore gas dryer # 110.87694110
you need to check the door switch and the start button first
Feb 11, 2008 | Kenmore 74602 Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
