Where is the filter
The hotpoint is leaking
where is the filter so I can empty it
Is it underneth the washing machine
How do i get it off?
    President:
  • 1,462 Answers
Filter should be checked regularly and is a pain to do on hotpoint. however, blocked filter would not cause leak.
remove small panel at bottom back.
you will see a large diameter hose running from tub to pump.
undo this hose at the tub end and you will find filter inside hose.
carefull, water will come out
Posted on Sep 18, 2008
Machine will not empty or final spin hotpoint wma57 . have replaced pump and cleaned pipes out still no joy
Have you checked and cleaned the filter?
To check the filter, remove the lower rear panel of washer, locate and remove the large black hose connected to the bottom of the drum.
Remove and clean the plastic filter inside the hose.
Reassemble and test for leaks.
Jan 31, 2011 | Hotpoint WMA74 Front Load Washer
How do we empty the filter on hotpoint first edition wma 10?
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose, reassmble and test for leaks.
Have some cloths ready to mop up any water that may appear..
Jan 13, 2011 | Hotpoint First Edition WMA12 Front Load...
Hi my hotpoint wma63 fills with water for a wash, then empties
motor tacho not being sensored...motor or pcb fault...chopper board faulty bottom front right in machine.
Jul 31, 2010 | Hotpoint Washing Machines
Hi my hotpoint washing machine wont stop spinning for some reason any ideas what is wrong
Very likely that the filter is blocked. Because the machine senses there is still water present it carries on spinning but the blocked filter is preventing the machine emptying. Turn off the power at the plug. The filter is usually mounted at the front near to the floor. Unscrew counter clockwise and be prepared for some water to leak out. Clean the filter under a tap, it will probably looked blocked and then re fit. Select a short programme cycle and see if the fault is cured.
Jul 04, 2010 | Washing Machines
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint washing machine WF430- Where would my filter be located as it needs to be emptied?
Its located at the rear of the machine, adjacent the drain pump, held with jubilee clips. You only have undo the main one. Filter is like a small, holed basket with a plastic ball. Empty anything in there and make sure you place the plastic ball back, tighten jubilee clip.
Jan 04, 2010 | Hotpoint Washing Machines
Where is the filter on Hotpoint first edition washing machine ?
Hi.
Some of these models, I believe, had a filter behind the front plynth. If nothing there then you will have to get to the back of the appliance.
Disconnect the power supply and remove the bottom back plate.
You will see a black hose that connects to the bottom of the drum and the other end connected to a drain pump.
With a few towels handy (make sure washing machine is empty!) unscrew the large clip holding the hose to the outer drum. Indide this hose you will find a filter. Remove, clean and refit.
Make sure hose is pushed firmly back on the outer drum and the clip fully tightened.
test with a small amount of water in the drum to make sure there are no leaks.
Hope this helps
Aardvark Repairs
Nov 18, 2009 | Hotpoint First Edition FEW12 Front Load...
Leak from lower door section and from powder door thing.
This could be a partially or completely seized/failed pump.
Before a machine goes in to a spin cycle, it runs the pump to empty all the water out. It used to be quite common that the machine does not check all the water has gone before spinning, it just runs the pump for a set time which if the pump is okay, is long enough to empty it.
If a spin is then started with quite a lot of water left in the drum, it gets thrown everywhere including back out of the powder/conditioner draw. Also the sheer strain of spinning a large amount of water can force water through an otherwise okay door seal.
Unless you are comfortable working on the machine yourself, call an engineer.
Sep 07, 2009 | Hotpoint WF430 Front Load Washer
Cant find my filter o a hotpoint first edition
i cant find the filter on my aquarius either, but i just read somewhere that this egg smell is probably caused by u mostly running the machine on cool washes i.e 40' ? so its suggests u run the machine on a 95' empty wash using ure normal detergent 2-3 times a year as the smell is a build up of bacteria because your washes arent hot enuff to kill it. If ure egg smell is bad, i'd do the empty hot wash thing a couple of times to make sure ! hope this makes sense?! :)
Apr 30, 2008 | Washing Machines
Water leaks from the soap dispensing tray on Hotpoint WMA 56 model
In the sump hose there is a filter, remove the hose and clean out filter insert, water is being forced up dispenser hose because it cannot empty fast enough.
Dec 24, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
116 people viewed this question
Top Washing Machines Experts
