Question about Dell Computers & Internet
Lines on the Screen, shut down and will not turn back on
My Laptop was working fine, went to lunch and came back and it had three sets of lines on the screen and would not stop, the cursor was gone, I shut it down by CTL,SFT EsC. then I tried to turn it on and it will act like it is on and will shut down within seconds and the screen never light up at all.
  • nofearsamm May 11, 2009
    Hi there about three months ago i started getting lines about 3mm apart running all over the screen from the bottom left to the top right corner. I have wiped the computer clean and have reinstalled everything back on and still have the same problem. They only seem to appear on lighter coloured backgrounds and are identical to each other. Any ideas.
    Thanks
  • 40 Answers
Hi, the issue may with the LCD panel. I work in DELL and have been getting lot of issues like this. It's called vertical line defects.. You can connect and external monitor and press Fn and F8 to toggle the display over to the Monitor. If the display is fine, replace the LCD screen. If the system is under wrranty, call Dell tech support and get a replacement or else call 800-288-4410 (out of warranty repair) department to send your laptop for repair. If the display is the same on the monitor, then the video card/Motherboard has to be replaced.
If this information is succesfull, then please rate!!
Posted on Sep 17, 2008
Hello my acer aspire 3680 laptop wont turn on and no lights are comeing on when pluged in so i took iit to a computer shop and he pluged a diffrent ac carger in and it worked then i came home and pluged my 1 in and it worked for about 30 secs then went off again and it wont ome back on and ideas
Posted on Nov 27, 2009
  • 446 Answers
Im afraid you have a prob with the inverter nor the LCD itself you need to send this to a tech
Vertical lines on laptop screen
problem with either display or the display cable...call cust service to diagnose and fix the issue
Mar 15, 2014 | Dell Studio 1555 laptop
I was playing Bewelled 3 on my Acer Netbook and the screen went into horizontal lines and I was unable to see anything. Turned it off and on again and cant see the startup screen, still horizontal lines.
I'll give you some simple solutions...
(i) Juz connect to external monitor, if it working fine surely it is the problem with the LCD.
(ii) Plz make sure that the configuration support this game.
(iii) The last option is repair / re-install the operating system, coz while you tried force shut down, the system files may corrupted...
Thanks & Regards
Anas K A
May 28, 2011 | Acer Aspire 4720 Notebook
I plugged my tv in and went through the set up. after that the screen went to lines and pixels. Then the cable popped up for a second and went back to the lines and pixels. It keeps doing this and shutting...
U have a bad cap that is makeing your set shut down will be located in the high voltage section of your set. Please have tech check and replace.
Aug 13, 2010 | Sanyo 42 in. LCD TV
There is just three lines that show red, green and blue.
It has been my experience with Sonys that those three colored lines indicate that the set is having trouble with the data communication lines. The hitch is that a model as complex as that one has as many as five seperate clock/data lines and if any one of them goes down the set will exhibit your symptom. It will take a professional to track down which line is causing the problem. I've seen audio output IC's as well as tuners cause the problem.
Jun 03, 2009 | Sony KP-61XBR48 61" Rear Projection...
Red lines on Sony KP51HW40 Rear projection TV
Yeah, seen that more times than I shoulda in the last 4 years. The red picture tube has a cathode to heater short. That means it's no good. That red picture tube is no longer availible. But all is not lost. There is a company that rebuilds those tubes reasonably. Most reputable tv shops will know this. The ones I've done cost around $450 out the door. One minor hitch is that with all the shipping involved the job usually takes about three weeks. That can be expidited but then the price goes up.
May 28, 2009 | Sony KP-51HW40 51" Rear Projection...
Vertical lines, screen freezes, laptop shuts down
it most likely doesnt run on windows me so that theory is out.Take it to dell or call someone to fix it
-CG
Jan 24, 2009 | Dell XPS M1330 Laptop Computer PC...
When I boot up the screen is all colors and lines
It sounds to me like your cable is loose to the lcd or the video card is not properly 100 percent seeded into the mother board. Prolly the cable in one way or the other, perhaps bad cable.
Nov 21, 2008 | Toshiba Satellite A215-S7422 Notebook
Acer Aspire5100 laptop modem disappears from hardware profile!?!
Could it be the screen saver when you said about Vertical lines.
I mean ,your computer was set to a certain period of time that if it stay idle, then the screen saver program will start to run.
takecare.
Apr 19, 2008 | Acer Aspire 5100 Notebook
Computers & Internet Logo
233 people viewed this question
Alun Cox
