My screen has cracked and ive just purchased a new screen to fit i need to take the old plastic screen off
    Sergeant:
  • 300 Answers
Very Carefully! ... jk lol
1. You'll want to begin by removing the top plate cover of YOUR laptop/notebook illustration below.
2. keep trac of every screw or **** or metal item you remove
3. You'll next want to detach the display ribbon cable , this is just an example
4. finaly you'll want to remove any OTHER ribbon cables , exampe below.
5. now for the tricky parts , you'll need to make sure you DO NOT PRY anything open
keep searching for hidden screws that may be located underneith plastic covers
that parts very tricky because sometimes they disguise them very well
6. once you find the screws to remove the face plate , illustrated below you'll be able to install your
new display screen without any farther assistance.
you do not need to remove the metal rods that hold the display in place , you just want to remove the face plate like this example my screen has cracked and - d298892.jpg>
Thank you for using FixYa!
Loch Hiam
Az.
Posted on Sep 18, 2008
Samsung tv cracked screen
Hello Sam, it would cost more to replace the screen than you can purchase a new set for. Beside that the new set will have many updates if your set is over 3 years old. p.s. If you have little ones, you may want to have a piece of lexan cut to fit the front of your new set and attach it with 4 pieces of velcro in the corners to protect the new screen. Then if you want you can remove it for "movie night's" or whatever. the $50 to $65 it would cost is a lot cheaper than a new tv.....tks Terry
Apr 18, 2014 | Samsung Televison & Video
Broken laptop screen
There is nothing more frustrating than a broken laptop screen. Whether you have dropped your laptop or stepped on it,once the screen is cracked it has to be replaced. Having the screen repaired may cost you almost as much as a new laptop. Purchasing a new screen from the manufacturer can also be expensive. Taking the time to look online at computer message boards or resellers can help you to find a reasonably priced screen. By following a few easy steps, you can replace your cracked screen and have a functioning laptop in an afternoon.
Determine what model laptop screen will fit your laptop. Ordering a screen directly from the manufacturer can be almost as expensive as buying a new laptop. Look at online computer message boards, auction sites and retailers to find less expensive options. Disconnect any power source, including the battery pack, from your laptop before you begin. Locate and remove the four to six screws that hold the bezel, or plastic frame cover, in place. The screws sometimes have small plastic or rubber covers over them. Pull the plastic bezel away from the screen cautiously, working around the edge. Some bezels snap in and out of place. A small flat-head screwdriver may be helpful in prying the edge of the bezel away from the screen. Pull the screen forward gently. You will find two main wires behind it. The ribbon-like wire, or video cable, is usually taped in place. Remove the tape and disconnect the video cable from your broken screen. Remove the broken screen from its metal frame. Connect the new screen to the video cable and pop it into the metal frame. Replace the tape, plastic frame and screws. Power up your computer and test your new screen. Hope this helps.
b>
Dec 10, 2012 | Computers & Internet
Controller case is broken.
Pretty much going to need a new system.
Oct 22, 2012 | Video Game Consoles & Games
Logitech harmony one
  • Dear Sir:
    Turn off the power to your computer and unplug all cables connected to it. Remove the battery, if one is installed.
  • 2
    Locate the covered screws around the cracked screen. Remove the rubber or plastic covers, then unscrew the screws.
  • 3
    Gently remove the plastic frame around the cracked screen and set it aside. Disconnect any power cords or cables going into the LCD screen.
  • 4
    Remove the cracked screen and slide the new screen into place. Replace any tape or plastic fasteners that hold it in place.
  • 5
    Reconnect all internal cords to the screen. Screw in the frame and replace all the screw covers.
  • 6
    Reconnect the power supply and all external cables to the LCD screen and switch it on.
    sincerely. God bless you
    ernesto cuadra
    managua, nicaragua. c.a.
  • Feb 15, 2012 | Logitech Harmony One LCD Touchscreen...
    Cracked screen, now lines running up and down screen
    Its all one piece on the vu. as long as the plastic lens covering the lcd is still intact. Its a fairly easy replacement Ive done a few!
    Mar 01, 2010 | LG Vu CU920 Cellular Phone
    Plastic box of wires to big for my new cd player after taking my old cassette player out
    You wll need a stereo installation adapter kit. This will change the dash opening to the size you need, oftentimes by replacing an entire dash panel for a factory look.
    http://www.bestbuy.com/site/olspage.jsp?skuId=8520442&type=product&id=1218019640369
    Here is a link to the dash kit for your car at Best Buy. These will come with detailed instructions. Let me know if this helps :)
    May 22, 2009 | 2000 Ford Focus
    Salton Yogurt Maker GM5 plastic lid replacement
    I have the same problem.  I used to place plastic wrap on top and still use the old cracked lids.  Now, I cannot find my instruction booklet.  Can you help me?
    Jan 01, 2009 | Crock Pots & Slow Cookers
    My screen on my rca 61130 has cracked i ve removed the screen protector and need a NEW SCREEN can it be replaced
    yes it can be replaced.calling a technician is much advisable as fitting the new screen is not very easy as it should be allighned as the old broken screen was before.if there is a slight difference in the fitting you will not be able to see the clear picture.
    thanks.
    Oct 13, 2008 | Televison & Video
    My rca d52w19 has a cracked screen,
    is the inner screen damaged? or just the outside. the outside is called the super sheild. this can be purchased at union electronics
    Oct 07, 2008 | RCA D52W19 52" Rear Projection Television
    Need new product
    I have a brand new, never used (parts still in plastic, but no box) ULTREX Kitchen Preparation Center model 14008- Blender-Food Processor-Fruit Juicer that you could buy.
    Nov 06, 2007 | Blenders
    Computers & Internet Logo
    David Payne
    David Payne
