Question about Acer AL1711 17" LCD Monitor
Acer AL1714 I believe the inverter is dead on my Acer monitor. When I hold a flashlight up to the screen I can see the desktop. If I unplug and plug the monitor the lights flash on for a split second. When I opened the monitor up one of the capacitors I believe had a black spot on the copper wiring., I called Acer to see if I could buy the part and surprise.....they no longer make it (the monitor is just over 3-years old). I have seen somewhere online where people say you can use inverters from cold cathode pc lights to fix this issue. Does anyone know if this is true? If so, could the inverter be connected to the pc with power wires running to the monitor? I hate to throw this out.
  • SXViper03 Sep 17, 2008
    When I refer to the lights flashing on I mean the monitors backlights.
  • Acer Master
  • 5,568 Answers
The inverters often fail from capacitors that have lost so much of their original capacitance and developed losses great enough to disable the circuit.
If you can identify the inverter section, you might want to replace any capacitors you see - a 'shotgun' approach, since locating the defective cap requires a fairly wide range capacitance meter with loss (DF) measurement feature unless you are lucky enough to locate one with a bulging top or crystalline deposits around the base. These instruments cost upwards of $200 so for a single use it doesn't make sense.  About the only part in that circuit that might be unique is the transformer so everything else can be bought or substituted. The lamp itself could have failed and these are available under similar part numbers from multiple sources. If the lamp has strong discoloration toward the ends, I would replace this first.
Posted on Sep 17, 2008
My Acer AL1714 monitor was given to me, the person that gave it to me said last time the last time it was connected it work but the monitor had been stored for about 2 years. So I bought a 19V-2.3A power...
mccampbell71 Probably a failure of inverter circuit(dc to ac 600-1100vac) to light-up (sustain) "cold-cathode-fluorescent lamps" causing the "switch-mode-power-supply" to go into full or partial SHUTDOWN mode. Black Screen of Death strikes again!!! The Question I have is why did you BUY a "black-brick" supply? Did the other one fall out of the car or get run over by a train? Only you will be able to make the decision of to REPAIR or Trade-in for new. You are no different than 5000 others worldwide (all brands) who have monitor's with BSOD! Yes, some (75-90%) can be saved to work 1-3 more years! Read some of my other responses in my profiles (12fixlouie aka louie12fix) to learn of the options you have open to you. Bye for now 12fixlouie If this info was of some use please rate on fixya.
Nov 13, 2009 | Acer AL1714 17" LCD Monitor
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Power cord
This one should do the trick.
http://insidecomputer.stores.yahoo.net/ac-adapter-for-acer-al1714-al1714b19volt-l1714171419.html
Feb 09, 2009 | Computers & Internet
Acer Aspire 5003WLMi
the reason for not seeing any picture on the external is becouse it is disabled in windows. I have 3 lcd screens here, only one gives picture untill I go and extend my desktop into the other monitors.
from desktop -> right click anywhere -> properties -> settings ->
Id say the backlight is bad is your acer still covered by warranty?
Aug 10, 2008 | Acer Aspire 5003WLMi Notebook
From what I have read, my inverter board has gone haywire in my acer flatscreen monitor. the screen lights for a second or two then goes very dark with a ghost of the computer's desktop image barely able...
you can change the inverver PCB or check the cable running from board to ya screen for any possible loose lighteen and check for any effect b4 changing the inverter board
May 24, 2008 | Acer Computers & Internet
Acer AL1714
HI again,
I think you will have to go for a repair but anyways i suggest you to ask the other experts.Like Irish druid or bestdarngood.
May 12, 2008 | Acer AL1714 17" LCD Monitor
LCD monitor display is not appearing
It would seem that you are on the right track. If the desktop could be seen (albeit very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance of part of the desktop could be seen.
Often, the larger the screen, the more the number of CCF lamps. Being a 17incher, I wouldn't be surprised if your Acer AL1714 would have two. Having said that and I am assuming that both lamps are not working, then the common denominator would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the monitor than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Acer.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope this be of additional help/idea to Coolguy's assistance. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 06, 2008 | Acer AL1714 17" LCD Monitor
LCD monitor display not working
The problem you have is with the backlight lamp, which is not turning on. When this happens only because lamp is faulty, Acer LCDs have a security switch that will not turn the screen on at all and will return a blinking light on power on led , as diagnostic feedback.
If you have a dim light it sometimes means that the bulb is still ok, but is not working. This often happens because of a faulty capacitor on inverter, which is powering the lamp.
Although the above symptoms are typical of a faulty inverter, a faulty power supply, lamp, or A/D board can produce the same symptoms.
It's also possible that an inverter could have been damaged by a faulty lamp. If faulty lamp is not replaced before refitting the repaired inverter, in time, the inverter will fail again.
Best thing to do is taking your lcd to a local TV repair or computer repair that works with lcd (ensure they work proficiently on lcds , some of them doesn't), to test if it is the lamp or a faulty component on board. If possible find a shop giving you some warranty time, as, if there is more than one problem the LCD can fail again in few days.
Regards
Acer al1714
The problem may not be the monitor. Acer AL1714 is known for its weak power supply unit. Unplug power supply from monitor. If the green light on monitor comes on but goes out quickly, the power supply is the culprit!
Dec 28, 2007 | Acer AL1714 17" LCD Monitor
Acer AL1711 17" LCD Monitor Logo
125 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
