Question about Nikon N75 35mm SLR Camera
Film stuck in camera
The other day I took my last shot and my camera proceeded to retract the film. Before it was finished it stopped and an 'E' appeared in the window. I am afraid to open up the film door and expose the film. If there any way to make sure the film is wound into the canister before I open it up? I own a Nikon n75. Thank you.
    Guru:
  • Nikon Expert
  • 362 Answers
First, replace the batteries, turn on the camera and try again. If that dose not work, you need to take the camera into a darkroom, a room that is 100% totally dark. The slightest light leak could fog your film. If you do not have a room in your house that you can make light tight during daylight, try doing this at night, Once you are in the darkroom, you will need to work by feel. Open the camera back and feel for the film magazine. If there is no film protruding, you are ok and can turn on the lights. If not, you need to pop the magazine out and use the protruding knob on the end to manually wind the film into the magazine while you alternately pull the film off the take-up spindle. Once all the film is in the magazine, you can turn on the lights.
Posted on Nov 30, 2008
No film in but it says there is
needs repairing at a qualified shop
sounds like the film advance motor died
Apr 21, 2013 | Nikon N6006 35mm SLR Camera
Advance lever is stuck. I bought new film and a new battery for my canon ae-1, loaded the new film, and took two shots until the frame counter read 1. the next day I advanced the film and when i pressed...
Like all AE-1's and related models, your camera is gumming up inside as the internal lubricant films are at least 25 years old and are largely dried-out.
The fix is to get the camera to a repair specialist for a CLA service (Clean, Lubricate, Adjust). As a one-off extra cost also get the foam light seals and foam mirror buffer replaced as they'll either be absent by now or will still be turning to a sticky goo. Modern foam is is different material and is will not decay like the old stuff.
A CLA and foam replacement definitely costs more than the residual value of the camera, but they're solidly built and have plenty of cheap high quality lenses so can still achieve results which compare well to even the best modern pro dSLR's. Get the work done and your camera will probably last until 35mm film ceases to be available. Your camera will also withstand conditions which you'd never dare risk a dSLR in.
Jun 27, 2011 | Canon EOS-AE-1 35mm SLR Camera
I just put in a new roll of film and I took 3 pictures and then the screen at the top said "ERR" and the film retracted itself....what happened?!
Hi, On Minolta's ERR means that the film hasn't been loaded in the camera properly so you'll want to reload the film.
Jun 15, 2011 | Minolta Maxxum HTsi Plus 35mm SLR Camera
My film advance lever is stuck. pushed button under camera didn't work
You may have hit the end of the film. Rewind the film back to the spool until the very end gets back in the shell.
If you think you still have unexposed film do the following. Rewind about 1-2 full rotations. Cover the lens using the cap. We're doing this so that step 2.3 will not spoil your last pictures. Take 2 shots (with the lens cover). This time the button at the button should have popped out.
Feb 28, 2011 | Canon EOS-AE-1 35mm SLR Camera
On loading a fresh film into the camera the motor winds through to the last frame ie does not stop at first frame
That's entirely correct. Your camera winds all of the film out upon loading and each shot then winds the film back into the canister. Your frame counter works in countdown mode telling you how many shots remain rather than how many you've taken.
Many other camera do the same thing. The beauty of it is twofold: if the camera back is accidentally opened, then the shots already taken are safely in the film canister (except for the last shot), also when the film has finished you wait less time for the short length remaining to be rewound rather than the entire roll.
Hope this helps, please take a moment to rate my free answer.
Sep 25, 2010 | Ricoh GR-1 35mm Point and Shoot Camera
I have an Canon AE-1 and the film advance lever will not advance the film, the lever goes half way. The shutter will not release. Thanks
The film is either at the end or stuck. The shutter will not release unless the film advance lever has gone all the way and back.
Make a note of the frame counter. Rewind the film and remove it from the camera (When you feel the film to come loose from the receiving spool, stop rewinding to prevent the end of the film to disappear inside the can. This way you can reload it if it was stuck in the middle.) If the film was completely exposed, take it to be developed.
With the empty camera, try to advance the lever and release the shutter. If this works, the problem was the film and not the camera. Everything is fine. If the problem persists, take it to be repaired.
If the film was stuck in the middle, load it again into the camera. With the lense cap on (preferably in a dark room or similar) 'shoot' as many 'empty' frames as you had on the counter plus two more. Finish the film and develop the pictures.
If the film stucks again at the same place, rewind it and develop normally. It was a bad film.
Hope this helped you to solve the problem.
Nov 16, 2009 | Canon EOS-AE-1 35mm SLR Camera
Evoca 115 stopped working after 22 shots
I think you have run out of film. 22 panoramic shots is the equivalent of at least 35 regular shots. Did you open the camera in a darkroom because if not you might of ruined the film. You need to try rewinding the film putting in a fresh roll and I think it should work. Hope this Helps.
Nov 22, 2008 | Samsung Evoca 115 35mm Point and Shoot...
Leica m6 film stuck, I think
Did you mean you wanted to unload the unfinished film?
What you did then? be more clear and specific about the procedures before I can give you suggestions.
pc-cook
Oct 22, 2007 | Leica M6 TTL .58 35mm Rangefinder Camera
Canon A1- Just stopped working
Get a dummy film and put it in the camera , make shure that the film is fully loaded on to the take up spool and test it all the way through, It sounds like the film is coming off the take up spool. I have repaired a lot of these A1's and they don't suffer from this problem. yours Tim 01689 818009..
Oct 03, 2007 | Canon EOS-AE-1 35mm SLR Camera
Nikon N75 35mm SLR Camera Logo
329 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
