Question about ASUS P4P800S Motherboard
Added ide hd and can't boot from ata hd now!
Hey folks,
need a little help here...
got this system second hand and tried adding a hard drive to the primary ide slot and couldn't get it to boot. I went into the bios and it saw the ata and the ide hd drives but when you went to the boot sequence you couldn't choose the ata drive.
i also tried putting it on the secondary ide as a slave and had the same problem. tried that on ide1 as well.
does this mother board override the ata slot when you use the ide slot for a hard drive?
this should be a straight forward install but this is getting frustrating.
basic system
p4 3.0
1 gb ram
nvidia 128mb video
80 gb ata hard drive
dvd rom
cd burner
didn't check the bios version but assume original
windows xp pro 32bit
limited software
thanks for a light you might shine on my problem!
steffan
  • calchef Sep 18, 2008
    hey voodoonofx,
    so will that tell the motherboard to boot the sata first?
    i did change to enhanced mode but i don't think i set the other...may have been my
    problem in that case.
    i will try that out and see what happens.
    thanks for your help and i'll let you know
    how it goes.
    thanks for your input.
    calchef
  • Steven Parker
    Steven Parker May 11, 2010
    I don't think it's overriding the SATA on the board when you plug in an IDE drive. I've never seen a board do that. I would try resetting the bios to it's factory defaults, and just try plugging in teh IDE drive. That should get you to be able to boot from the IDE drive. Then add teh SATA drive once you know the IDE drive works.
    Comment back with the motherboard model number, and i'll see if I can help you more.
    Steven
    President:
  • 2,351 Answers
Hi Steffan, to answer your question! Yes, the bios does take away an IDE port when using both SATA & IDE hard disk drives. See the manual for ASUS P4P800S page 1-22 & page 1-23. In reality both drives are ATA. (Though I understood your question above). This board wants you to hook the two types of drives as shown on pg 1-23. Than go to page 2-14 to help you set the bios setting. Than see if you choose the serial ATA SATA drive in the boot configuration section.
See under, IDE Port Settings [Primary P-ATA+S-ATA]. (Set to this in bios).
Parallel = P-ATA = IDE drive.
Serial = S-ATA = SATA drive.
Need the manual? Click on this Asus link; http://support.asus.com/download/download.aspx?modelname=P4P800S&SLanguage=en-us
You'll also need Adobe reader to view the manual. Download Adobe from this link; http://www.adobe.com/products/reader/
If you still have trouble just let me know.
Good luck Steffan!
Mike
Posted on Sep 18, 2008
    Scholar:
  • 95 Answers
Ah, ok. According to the manual, on page 1-23...here's what you need to do.
According to this page, you need to set onboard ide operate mode to "Enchanced Mode", and Enchanged mode support on to "Sata".
  • Steven Parker
    Steven Parker Sep 18, 2008
    By making these changes, it will allow you to have both SATA and IDE drives detected at the same time. After setting the settings, save and exit, then re-enter the bios. You're boot menu should now allow you to choose which drive to boot from.
    Steven
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
Computer did not bootup after adding 2nd harddrive
Did you connect the drive to cable spot closest to the motherboard on the primary IDE channel? is it formatted? Did you try the drive on the Second IDE channel? Can your system support a 160 GIG drive?(if not try partitioning the drive.). Is the power and data cable connected properly?(the red line on the data cable should be closest to the power plug on the drive.)
Apr 11, 2009 | Sony VAIO PCV-RS530G (PCVRS530GFS) PC...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
SECOND HARD DRIVE NOT RECOGNIZED
Change the settings of you IDE drives in your BIOS. Set your secondary boot device to HDD1. Also make sure that your primary HDD is set to master and the secondary HDD is slave. The jumper is found at the back of the hard drive where you connect the power and IDE cables. Try this and post back as to how it went..
Nov 11, 2008 | Seagate 250GB Barracuda 7200.10 ATA-100...
Boot up issues will not boot up from HD
IDE and SATA do not mix unless setup properly.
I would use the SATA one as main hard drive and set the other up as an external one on USB
Try resetting the BIOS to boot from CD
on ter lower part of boot screen will tel you the key to press to access the BIOS setup
Usually one of these keys
F2 CTRL+ESC or DEL
when in BIOS check and set to boot from CD
Nov 07, 2008 | PC Chips PCChips A13G+ v3.0 Motherboard -...
Adding second hard internal hard drive
Sure it will, put the jumper setting on the hdd to cable select mode.
Sep 01, 2008 | Dell Dimension 2300 PC Desktop
Installing a 2 port ATA-133 IDE adapter card to a desktop w/a hard drive & DVD
I don't think you can boot off of the ATA-133 so you will have to boot off of the IDE on the mobo and have the DVD drive jumpered cable select on the 2nd IDE. Boot that way to make sure the system boots. Shut down. Then instll the ATA-133 adapter with NO DRIVES on it and boot. The system should ask you for drivers for the new hardware. Intall the drivers. Shut down. Attach the new drives to the ATA-133. Reboot. You still might have to go into admin in windows and assign drive letters to the new drives. Anyway, if you are trying to boot off of a drive on the ATA-133 adapter, I don't think you can do it. I have mostly used Asus boards with Award Bios and there was no way to point the boot process to an add-on ATA Controller.
Jan 12, 2008 | Promise Ultra133 TX2 ATA Controller
Seagate 160GB SATA Hard Drive Installation.
Hi, Was the original 20Gb HD also a SATA or was it installed as an IDE? Try installing a fresh clean Windows rather than the restore disc. However, you will need the drivers for the SATA 160Gb and press F6 when Windows installers ask you to. Post back how things turn up or should you need further information. Hope this be of some idea/help. Good luck and kind regards.
Sep 08, 2007 | Seagate Barracuda 7200.7 160GB 7200rpm...
Would a SCSI disk and a IDE disk work together?
This solution works on WIN98 and I don?t see a reason why it wont work on you If there is something that you were missing you might want to check with anther expert. This solution is a little complex so I hope ill be able to explain it well enough: 1. Make a boot disk so u can format and install windows. 2. Define the new HD as MASTER and hook it up to "primary IDE" 3. Disconnect the SCSI and pull the board out. 4. Reset the comp from the boot disk u made (HD is connected) 5. Get in "bios settings" and make sure that the new HD is defined as "primary drive" In the 1st IDE 6. Now, perform a FDisk on the new HD, define partitions, do a reset and format the HD Install the operating system you wish to have, make sure it works well. 7. install the SCSI board and its HD make anther reset. 8. now the comp is supposed to make boot and recognize the SCSI, it is possible that you will need to define your system configurations but for that, regretfully, I cannot guide you Although this is not necessarily have to happen. Good luck
Feb 23, 2006 | Cybertron Intel Pentium 4 2.66GHz Serial...
ASUS P4P800S Motherboard Logo
182 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
