Question about Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC
I get codebase error when itry to open my deluxe invoices that i just installed
  • 3 more comments
  • Anonymous Apr 04, 2009
    same problem... codebase error after trying to create new account
  • Anonymous Apr 18, 2009
    I am getting the same message - I used the install wizard to set up the company so I could then go an customize and when I try to get into the program now I get a message that says "codebase error" and the program will not run?
  • bcosner2000 Apr 19, 2009
    same problem for me. XP Prof x64 system.
  • dbren123 Apr 19, 2009
    I am having the same problem as well. I actually uninstalled and reinstalled the program to see if that would help and still receive the same "codebase error" message after I run the setup wizard and try to start the program
  • bcosner2000 Apr 21, 2009
    Unfortunately, didn't work for me with the XP Prof 64-bit system. I may have to setup MS Virtual PC to use this program, or, get another competitor's program to use. -Tis' a shame-
I called technical support at Avanquest (software manufacturer) and spoke to a tech there. Below is what they had me do and it solved my problem, maybe it will work for you. Please note that I am running Windows Vista, so if you are running another Windows version I don't know if this will apply.
Right click on the desktop icon for My Invoices which should have automatically been placed there when you first installed the program.
In the window that opens, left click on the "Properties" tab. A new window will open. Left click on the "Compatability" tab.
In the section "Compatability Mode" check the box next to "Run this program in compatability mode for:"
Open the drop down window and select "Windows XP (Service Pack 2)" and then left click "Apply" and "OK" at the bottom of the window.
Now go in and run the Set Up Wizard again and you should be able to launch the program.
Hope this helps - I know I was really frustrated when I couldn't get this program to work after trying everything else I could think of!
Posted on Apr 20, 2009
Cant open program my invoices and estimates deluxe due to not having "reports.dll"
You need to contact the software developer. It appears it has a glitch. I'd recommend quickbooks for your next invoicing software
Jan 20, 2015 | Avanquest My Invoices & Estimates Deluxe...
Reports.dll was not found
Re-install may help. It's saying the driver for that part is missing. Drivers control how the software or hardware operates. Best place is to contact Avanquest.com and ask for help.
Nov 06, 2013 | Avanquest My Invoices And Estimates Deluxe...
I have an error message on My Invoices & Estimates when trying to save an invoice data saving error: Save Entity exception. It wont let me save it or back out of it... What do i need to do to correct...
Per Avanquest: We have found out that this randomly happens due to an interruption in saving the data in MyInvoices and Estimates Deluxe version 10. We recommend that you do the following steps:
  1. Go to the Task Manager.
  2. On the Applications tab, click on MyInvoices and Estimates.
  3. Click on End Task.
  4. Relaunch MyInvoices and Estimates.
  5. Create a new invoice/estimate and save it.
If that fails to resolve the issue, you should also try the following:
  1. Close MyInvoices and Estimates.
  2. Restart your computer.
  3. Relaunch MyInvoices and Estimates.
Note: The task you need to end is MIED.exe
This worked for me without losing any data other than the invoice I was creating. Always make backups so if your data file is corrupted, you can easily restore it. Hope this helps.
http://support.avanquest.com/support/solutions/articles/1000173898-when-saving-an-invoice-or-estimate-i-get-a-data-saving-error-message-how-can-i-correct-this-
Dec 06, 2012 | Avanquest My Invoices And Estimates Deluxe...
I just installed the program and keep getting error report that the program will not open.
have you restarted your computer, if yes you may need ti reinstall it but you also need a product key to activate and register it as well
Mar 20, 2011 | Avanquest My Invoices And Estimates Deluxe...
I am working on doing a fresh reinstall on a computer for someone, but they need me to save thier "My Invoices & Estimates Deluxe" information & reload it on the computer once I restore...
You have to backup all the require data to an external storage media first. If your are not familar with the software data backup. Ask your principal help or the person who operate on the system, to backup their vital data for to the external storage media, because you don't know which files are important.
Once you have install the OS, On installing "My Invoices & Estimates Deluxe" make sure the name the company file the exact same as the back up file name. If not you will not be able to load the backup files ie. you get errors opening the backup files.
Hope it helps.
Nov 22, 2010 | Avanquest My Invoices And Estimates Deluxe...
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
Printing problem with my invoice and estimate
MyInvoices & Estimates Deluxe
Open Company file error.
Exception: Unable to load DLL 'sqlceme35.dll': The specified module could not be found. (Exception from HRESULT: 0x8007007E)
Jul 27, 2008 | Avanquest My Invoices And Estimates Deluxe...
"My Invoices & Estmates Deluxe" - Repair corrupt '.inv' invoice file
When the program prompts, then creates a backup file for a database, it has a .bak suffix (not amazing). However it also creates a folder in the 'Safe' folder under c:\program files\estimates... All I had to do was locate the most recent version of the db files in the Safe, copy the folder to the c:\documents and settings\...\Invoices directory, and the most recent uncorrupted database was readily available for File Open. Voila.
May 30, 2008 | Avanquest My Invoices And Estimates Deluxe...
Avanquest My Invoices And Estimates Deluxe (gb0u3c0gn0000me066) for PC Logo
783 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
