How to replace ethernet port in gateway gt5404
Can i fix my rj-45(network)jack myself
Posted on Nov 15, 2012
If your motherboard's ethernet (RJ-45) port is the only problem, you have two options. For a workaround, use a spare PCI or PCI-Express slot and add a network card. Assuming their is nothing wrong further down the line than the port itself, that should get you back on the web / home network.
If however, you do not have a (spare) slot to add a network card, the only alternative is repair. Most manufacturers are good about helping customers with repairs, though of course, at a cost. Even worse with RMAs is the shipping cost, which is often completely billed to you, both ways. For this reason, motherboards are usually cheaper to replace than repair.
Desoldering the RJ-45/USB module from your motherboard may seem like a simple task, but the average joe with a soldering kit simply doesn't have the ability to do this sort of repair without further causing further damage to the board. Leave the repairs to the professionals. If you are trained to do this sort of work, you shouldn't need any advice about how its done.
Posted on Nov 04, 2008
How do i copy data from gateway PC to thumbdrive?
Plug the thumb drive into usb port you will see the drivers load and then a pop up telling you it is ready to use. Open my computer you should see it in as another drive find the files you want to move there and right click on them choose send to and choose thumb drive...that is it, very easy.
Jul 08, 2014 | Gateway GT5404 PC Desktop
Gateway GT5404 Recovery Disk
The recovery disk is model specific and basically garbage. You'd be better off getting an install disc for Windows or another operating system. Many flavors of Linux are available and FREE.
Dec 11, 2012 | Gateway GT5404 PC Desktop
I have windows 7 and I was connected to a wireless router. My computer unexpectidly shut off. Now it says there are no connections available. How do I fix this?
Hi, Have u tried connecting ur computer using an Ethernet cable if possible and see if it's working. You computer might have lost the drivers for the wireless adapter. If its working using Ethernet try do an update for the wireless. Hope this help Regards
Jan 04, 2012 | Gateway GT5404 PC Desktop
My Gateway GT5404 Freezes
1. your hard drive may be at what is called the "end - of - life"
2. I suggest that you try to backup important files if you can get into the pc screen again.
3. PC freezing is sometimes due to a failing power supply, a failing hard drive, and or a depleted CMOS battery.
May 15, 2010 | Gateway GT5404 PC Desktop
My gateway gt5404 says no rgb signal what do I do
With 3 beeps, you are getting a Memory base read/write error, which means your RAM is having a problem.
You can try takng the RAM simm/dimm out and re-seating them back into the slots.
If the issue continues, you will need to replace the bad RAM
Nov 21, 2009 | Gateway GT5404 PC Desktop
What do I need to replace my hard drive on a gateway gt5404 deskt
Here is the support page for your PC, you may wish to contact them about a recovery disc. You can reinstall the OS without it but it's usually cheaper to order the recovery disc (plus it comes with the drivers for your unit).
Feb 22, 2009 | Gateway GT5404 PC Desktop
What do I need to replace my hard drive on a gateway gt5404 desktop
The hardware userguide for your computer will show you how to do everything, step by step:
http://support.gateway.com/s/Manuals/Desktops/8512041.pdf
Cannot find my GT5404 Restore Disc
You are in luck I was able to find a Gateway recovery disc. I will be posting the link as soon as I have it uploaded to my site.
Jan 13, 2009 | Gateway GT5404 PC Desktop
Battery in a gateway gt5404
The battery on a desktop computer is on the mother board. It looks like a large watch battery. Very inexpensive and easy to change. But make sure all power is disconnected before touching *********** board and do not use and sharp object to try to pry the battery out.
Dec 04, 2008 | Gateway GT5404 PC Desktop
Computers & Internet Logo
6,219 people viewed this question
David Payne
David Payne
