Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
RCA 2005 52 inch HDTV
Showing static wavy lines. It goes away but sometimes stays for awhile. Also some popping noise but goes away. Screen also looks like something was spilled. Got a great deal on it. Bought used. What should I do?
  • 1 more comment
  • timinsall Sep 17, 2008
    How do I take the screen out?
    Because of its age should I go ahead and replace the bulb?
    Thanks. You the man Ronnieh49.
    Genius:
  • 2,920 Answers
You ca take the scren out and clean it as far as the other problem u may want to call a service tech in
Posted on Sep 17, 2008
  • 1 more comment
  • Ronnie Houston Sep 17, 2008
    there is trim arouond the front of the tv that pops off and they there are several brackets that hold the scerrn in place that you have to take out so toy can clean the screen and while there you may want to clean the tubes as well as they will be there where you can get to them.the front trim just pops loose and the rest you will be able to see. ron
    i would not replace the bulb until you know for sure that its the problem. i would go ahead and clean the screen and clean the tubes while you are in there but dont try to replace the tubes until you have the tv checked out.just wipe them down really well on the glass part and then if you want to have someone look at it do so but dont overspend it may not be worth the mone to fix
    one thing more.....have a repairman give you an estimate for the repair before you let the do anything and if you think its worth it then go for it if not just let it go....im going to guess at least 400.00 to repair just from what youve said here but it could be a bit less depending on what they find wrong.the tubes alone are about 300 each so as i said dont be in a big hurry,,,,,have it checked first and see what they tell you then you decide from there..its your decision
Wavy lines all over the screen on a 55 in. Mitsubishi DLP 2005 Tv that has intermitent wavy lines around all the edges of the people and edges of the screen. Jerky picture and almost makes you sic...
You probably have a V26 chassis. The only fix to this problem now that parts are no longer available from MITS is to call their Consumer relations dept. at 800-332-2119. If you have a qualified tech come out and estimate the job, Mits will offer you an attractive discount on a new model. To repair your problem would be around $750
Bill W
integrityhomeworx.com
Mar 22, 2011 | Mitsubishi Televison & Video
Hello I have a Dell Dimension 3100 desktop. After
Bad Fan... either the CPU Fan or the Power Supply Fan or the Case Fan. If the PC is older than 4 years it is probably the Power Supply.
Dec 30, 2009 | Dell Dimension 3100 PC Desktop
Monitor does not come on right away, it makes a clicking noise then say no signal analog. after i trun off and on several times it comes on but the screen is wavy for a while
when you say the screen comes on wavy for awhile, im supposing you have a CRT monitor, not the flat panel type. That seems to be the degauss feature when you turn on the monitor which is normal. The no video issue may be a bad video cable or connection the the PC.
Nov 09, 2009 | Computers & Internet
Sometimes when I go to take a picture the screen turns a purplish color and has wavy lines through it - if I do take a picture - that is what it looks like...if I wait awhile, sometimes it will go away and...
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check this link for more info.
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 30/30a/200a/300a/D320/400/ 450/500
Oct 18, 2009 | Canon PowerShot S1 IS Digital Camera
Sony kv35s66: No picture, just sound and red blinking
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Poor playback
Because the cable signal is OK, this eliminates the tuner as your problem and leaves the power supply which is a common problem. It is a switch mode type which often have trouble maintaining control of its output voltages and produce trouble downstream in the video circuitry. Either the power supply is failing which can be wholesale replaced for about a $150, or something somewhere else is failing and loading down the supply causing it to overwork. Usually in this case, you can hear a whine noise if you listen close.
Dec 28, 2007 | Sony SLV-N750 VHS/S-VHS playback VCR
Samsung lnt4065 problem
It sounds like the TV was most likely dropped, and there is probably some breakage! I would call right away to have the set exchanged!
Jerry G.
Nov 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Zenith IQB60M92W 60in Rear Projection
Sounds like some kind of local interference. The first thing I'd try is disconnect the antenna input. If the wavy line goes away, it's probably something coming in through the antenna. Then I would start shutting off the circuit breakers until I was down to just the one the set is plugged into. If it goes away I would start flipping the breakers on, one by one until the noise returned. If you can isolate it to one circuit, start looking at everything that is on that circuit. If all else fails, call a TV tech.
Oct 01, 2005 | Zenith IQB60M92W 60" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
111 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
