Question about Technics SL-1210 Turntable
Rotating back and forth when powered on
I dug an old 1210 out of storage this weekend and noticed that when I powered it on, it would continuously rotate back and forth about 1/4 of a turn instead of rotating like normal. Any idea what could be causing this?
  • 515 Answers
You have drive issues. There is no easy way to fix or to isolate the problem. You'll have to take it to a service technician who can test your unit, and fix the problem. Usually it's one (or all) of the 3 main IC (integrated circuits) which cause this problem.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Posted on Nov 04, 2008
Oven Door Latch Won't Stop Cycling
Contact your power company and request they repair the appliance that was damage due to the surge, it is likely burned out the control panel
Jul 08, 2017 | Kitchen Ranges
Tip
Garmin Nuvi 1210 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1210 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1210 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1210 Guide Download
Garmin Nuvi 1210 QuickStart Download
Garmin Nuvi 1210 Webupdate
Garmin Nuvi 1210 Favorites Backup
on May 15, 2010 | GPS
I have a ~4year old Dometic RV refrigerator that does not start cooling when started after periods of being shut off (as little as 2-3 days). When I turn it on I can hear the fan start but after 2-3 hours...
ammonia absorption refrigerators need continuous heat either by
a heating coil powered by a transformer or, a propane flame
check/replace your gas thermocouple or, transformer to the heating coil located on the refrigerator back
Aug 21, 2013 | Refrigerators
Tub thumps after nail wedges through small hole bottom and stops tub
You could have an unbalanced tub or the piece is rotating around in the outer tub and making the noise. Contact a professional to have the machine taken apart if the noise continues.
Jul 28, 2012 | Frigidaire FEX831CS Top Load Stacked...
Grinding noise front end left side at highway speeds and when turning wheel back and forth at high way speeds
Sounds like front wheel bearings.
Does the sound go away when swaying one way or the other?
If you way left and ot gets louder it should be the right bearing and opposite for swaying right
Jun 12, 2012 | 2004 Ford Explorer
Why is the fellowes blade still rotating even when there is no paper?
It is possible that a small shred of paper is lodged at the sensor underneath the cutting blade.
    • 1 Unplug the paper shredder. Empty the shreds from the collection bin. Pull as much stuck material as possible from the top and bottom of the shredder blades with pliers or use canned air and blow the edges of the blades.
    • 2 Place the paper shredder back on the collection bin base and plug the shredder back in. Rock the shredding direction back and forth between forward and reverse.
    • 3 Make two passes across the cutting blades while drizzling synthetic shredder oil. Switch the direction to forward to run continuously for one minute.
    • 4 Lower two sheets of clean paper into the shredder. The paper removes excess oil, metal fragments and debris from the cutting blades. Blast the blades with compressed air when you notice a build-up of small paper scraps that may cause a jam.
Sep 26, 2011 | Fellowes Intellishred PS-79Ci Shredder
After power on TV the screen shrinks to (50%) and then back out to (100%) back and forth for about 15 minutes
the quetion is:  have you checked your format/aspect settings? if it is on auto-format, picture size will vary due to program you are watching.....or is it a raster/width problem? The thing about the time on digital clocks: daylite saving time usually started last saturday, the federal goverment changed it, the fall back time is now this saturday! Most newer digital clocks auto-change according to old schedule....( not sure if you were aware of this )  let us know whether a width problem or what......
Oct 30, 2007 | Philips 9P5544C 55" Rear Projection...
Technics SL-1210 Turntable Logo
56 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
